[rtems commit] Use http://www.rtems.org/bugzilla as bug-URL.
Thu Aug 9 13:55:12 UTC 2012
http://bugzilla.rtems.org works.
The rtems.org server has a lot of aliases. mail, wiki,
bugzilla, etc.
git.rtems.org is a separate machine.
On 08/09/2012 08:49 AM, Gedare Bloom wrote:
> Module:    rtems
> Branch:    remotes/upstream/4.10
> Commit:    67aeb83f27573d1869082fa8132f3394fbaa0d7f
> Changeset: http://git.rtems.org/rtems/commit/?id=67aeb83f27573d1869082fa8132f3394fbaa0d7f
> Author:    Ralf Corsépius<ralf.corsepius at rtems.org>
> Date:      Thu Jul 26 06:23:09 2012 +0200
>   c/src/lib/libbsp/arm/csb336/configure.ac        |    2 +-
>   c/src/lib/libbsp/arm/csb337/configure.ac        |    2 +-
>   c/src/lib/libbsp/arm/gdbarmsim/configure.ac     |    2 +-
>   c/src/lib/libbsp/arm/gp32/configure.ac          |    2 +-
>   c/src/lib/libbsp/arm/gumstix/configure.ac       |    2 +-
>   c/src/lib/libbsp/arm/lpc24xx/configure.ac       |    2 +-
>   c/src/lib/libbsp/arm/lpc32xx/configure.ac       |    2 +-
>   c/src/lib/libbsp/arm/rtl22xx/configure.ac       |    2 +-
>   c/src/lib/libbsp/arm/smdk2410/configure.ac      |    2 +-
>   c/src/lib/libbsp/powerpc/beatnik/configure.ac   |    2 +-
>   c/src/lib/libbsp/powerpc/haleakala/configure.ac |    2 +-
>   c/src/lib/libbsp/powerpc/mvme5500/configure.ac  |    2 +-
>   c/src/lib/libbsp/powerpc/virtex/configure.ac    |    2 +-
>   13 files changed, 13 insertions(+), 13 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/csb336/configure.ac b/c/src/lib/libbsp/arm/csb336/configure.ac
> index aa64766..f470c93 100644
> --- a/c/src/lib/libbsp/arm/csb336/configure.ac
> +++ b/c/src/lib/libbsp/arm/csb336/configure.ac
> @@ -3,7 +3,7 @@
>   ## configure.ac,v 1.5 2003/03/11 09:39:07 ralf Exp
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-arm-csb336],[_RTEMS_VERSION],[rtems-bugs at OARcorp.com])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-csb336],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
>   AC_CONFIG_SRCDIR([bsp_specs])
>   RTEMS_TOP(../../../../../..)
> diff --git a/c/src/lib/libbsp/arm/csb337/configure.ac b/c/src/lib/libbsp/arm/csb337/configure.ac
> index 692c1e4..405450b 100644
> --- a/c/src/lib/libbsp/arm/csb337/configure.ac
> +++ b/c/src/lib/libbsp/arm/csb337/configure.ac
> @@ -3,7 +3,7 @@
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-arm-csb337],[_RTEMS_VERSION],[rtems-bugs at OARcorp.com])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-csb337],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/arm/gdbarmsim/configure.ac b/c/src/lib/libbsp/arm/gdbarmsim/configure.ac
> index ee7a744..69dfd82 100644
> --- a/c/src/lib/libbsp/arm/gdbarmsim/configure.ac
> +++ b/c/src/lib/libbsp/arm/gdbarmsim/configure.ac
> @@ -3,7 +3,7 @@
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-arm-gdbarmsim],[_RTEMS_VERSION],[rtems-bugs at OARcorp.com])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-gdbarmsim],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/arm/gp32/configure.ac b/c/src/lib/libbsp/arm/gp32/configure.ac
> index e66e374..0bc5a8c 100644
> --- a/c/src/lib/libbsp/arm/gp32/configure.ac
> +++ b/c/src/lib/libbsp/arm/gp32/configure.ac
> @@ -3,7 +3,7 @@
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-arm-gp32],[_RTEMS_VERSION],[rtems-bugs at OARcorp.com])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-gp32],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/arm/gumstix/configure.ac b/c/src/lib/libbsp/arm/gumstix/configure.ac
> index f369869..3ee6da1 100755
> --- a/c/src/lib/libbsp/arm/gumstix/configure.ac
> +++ b/c/src/lib/libbsp/arm/gumstix/configure.ac
> @@ -3,7 +3,7 @@
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-arm-gumstix],[_RTEMS_VERSION],[rtems-bugs at OARcorp.com])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-gumstix],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/arm/lpc24xx/configure.ac b/c/src/lib/libbsp/arm/lpc24xx/configure.ac
> index 0e72093..1f5f7e3 100644
> --- a/c/src/lib/libbsp/arm/lpc24xx/configure.ac
> +++ b/c/src/lib/libbsp/arm/lpc24xx/configure.ac
> @@ -6,7 +6,7 @@
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-arm-lpc24xx],[_RTEMS_VERSION],[rtems-bugs at rtems.com])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-lpc24xx],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/arm/lpc32xx/configure.ac b/c/src/lib/libbsp/arm/lpc32xx/configure.ac
> index 6cfd903..886eb8d 100644
> --- a/c/src/lib/libbsp/arm/lpc32xx/configure.ac
> +++ b/c/src/lib/libbsp/arm/lpc32xx/configure.ac
> @@ -6,7 +6,7 @@
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-arm-lpc32xx],[_RTEMS_VERSION],[rtems-bugs at rtems.com])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-lpc32xx],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/arm/rtl22xx/configure.ac b/c/src/lib/libbsp/arm/rtl22xx/configure.ac
> index a5690b0..8708c79 100644
> --- a/c/src/lib/libbsp/arm/rtl22xx/configure.ac
> +++ b/c/src/lib/libbsp/arm/rtl22xx/configure.ac
> @@ -3,7 +3,7 @@
>   ## $Id$
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-arm-rtl22xx],[_RTEMS_VERSION],[rtems-bugs at rtems.com])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-rtl22xx],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/arm/smdk2410/configure.ac b/c/src/lib/libbsp/arm/smdk2410/configure.ac
> index 6e83ca6..c347b63 100644
> --- a/c/src/lib/libbsp/arm/smdk2410/configure.ac
> +++ b/c/src/lib/libbsp/arm/smdk2410/configure.ac
> @@ -3,7 +3,7 @@
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-arm-smdk2410],[_RTEMS_VERSION],[rtems-bugs at OARcorp.com])
> +AC_INIT([rtems-c-src-lib-libbsp-arm-smdk2410],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/powerpc/beatnik/configure.ac b/c/src/lib/libbsp/powerpc/beatnik/configure.ac
> index 1f170a2..625b71c 100644
> --- a/c/src/lib/libbsp/powerpc/beatnik/configure.ac
> +++ b/c/src/lib/libbsp/powerpc/beatnik/configure.ac
> @@ -3,7 +3,7 @@
>   ## configure.ac,v 1.9.2.3 2003/08/11 14:37:22 ralf Exp
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-powerpc-beatnik],[_RTEMS_VERSION],[rtems-bugs at rtems.com])
> +AC_INIT([rtems-c-src-lib-libbsp-powerpc-beatnik],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/powerpc/haleakala/configure.ac b/c/src/lib/libbsp/powerpc/haleakala/configure.ac
> index 0250507..7d611af 100644
> --- a/c/src/lib/libbsp/powerpc/haleakala/configure.ac
> +++ b/c/src/lib/libbsp/powerpc/haleakala/configure.ac
> @@ -3,7 +3,7 @@ dnl
>   dnl $Id$
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-powerpc-haleakala],[_RTEMS_VERSION],[rtems-bugs at rtems.com])
> +AC_INIT([rtems-c-src-lib-libbsp-powerpc-haleakala],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/powerpc/mvme5500/configure.ac b/c/src/lib/libbsp/powerpc/mvme5500/configure.ac
> index e12dba3..6006649 100644
> --- a/c/src/lib/libbsp/powerpc/mvme5500/configure.ac
> +++ b/c/src/lib/libbsp/powerpc/mvme5500/configure.ac
> @@ -3,7 +3,7 @@
>   ## configure.ac,v 1.9.2.2 2003/03/06 10:42:42 ralf Exp
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-powerpc-mvme5500],[_RTEMS_VERSION],[rtems-bugs at OARcorp.com])
> +AC_INIT([rtems-c-src-lib-libbsp-powerpc-mvme5500],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> diff --git a/c/src/lib/libbsp/powerpc/virtex/configure.ac b/c/src/lib/libbsp/powerpc/virtex/configure.ac
> index f65f56d..09cb1cf 100644
> --- a/c/src/lib/libbsp/powerpc/virtex/configure.ac
> +++ b/c/src/lib/libbsp/powerpc/virtex/configure.ac
> @@ -3,7 +3,7 @@ dnl
>   dnl $Id$
>   AC_PREREQ([2.68])
> -AC_INIT([rtems-c-src-lib-libbsp-powerpc-virtex],[_RTEMS_VERSION],[rtems-bugs at rtems.com])
> +AC_INIT([rtems-c-src-lib-libbsp-powerpc-virtex],[_RTEMS_VERSION],[http://www.rtems.org/bugzilla])
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
Joel Sherrill, Ph.D.             Director of Research&   Development
