FW: rtems on nios2 collaborative efforts
Hill, Jeff johill at lanl.gov
Thu Jul 12 15:53:26 UTC 2012
Hello,
Attached are some git patch files for RTEMS and Altera Nios2 Softcore. Let me know if you have any questions about these changes/additions or if there is a better format to submit patches in.
Jeff Hill
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Friday, March 30, 2012 7:18 AM
> To: Hill, Jeffrey O; rtems-devel at rtems.org
> Cc: rtemsdev at ixo.de; ruppe at kth.se
> Subject: Re: FW: rtems on nios2 collaborative efforts
> Hello Jeffrey,
> > From: Hill, Jeffrey O
> > Sent: Wednesday, March 28, 2012 4:25 PM
> > To: 'rtemsdev at ixo.de'
> > Cc: 'ruppe at kth.se'; 'rtems-devel at rtems.org'
> > Subject: rtems on nios2 collaborative efforts
> > Hello all,
> > My name is Jeff Hill, I work for LANSCE Accelerator project in Los
> Alamos USA, and I have been working on the nios2 RTEMS source code some
> over the last year and have implemented some new functionality.
> > o Altera Avalon TSE Ethernet driver
> > o Altera Avalon SGDMA driver
> > o RTEMS Ethernet interface driver using Altera Avalon TSE and Altera
> Avalon SGDMA
> > o GDB stub for nios2. This provides RTEMS thread aware debugging, and
> one can attach from a 2nd jtag uart in the design so it doesn't
> necessarily replace, or interfere with the Altera supplied gdb.
> nice.
> > o exception cause detection if the nios2 isn't instantiated with "extra
> exception information"
> I use only the generated code from Altera in this area.  Also our FPGA has
> the
> extra exception information, so I cannot say much to this.
> > o nios2 exception vectoring
> What do you mean with this?  I didn't look at the internal interrupt
> controller
> (IIC) stuff, since we use the external interrupt controller (EIC) with
> shadow
> registers.
> > o termios interface with both polled and interrupt driven interfaces for
> the Altera Avalon JTAG UART
> > o A alternative BSP with simplified auto-configuration based on
> compiling a host tool that directly includes system.h (maybe this wasn't
> really a good idea because I know you have already implemented ptf file
> style auto-configuration, but I couldn't find a ptf file that was being
> generated by QSYS). However, if we can agree on the device parameter macro
> naming scheme used by the BSP device drivers then perhaps both approaches
> can coexist?
> We have probably something similar in a not published BSP which is
> automatically generated from the FPGA specifications.   We use heavily the
> Altera HAL for this.
> > o Moving the BSP device drivers to a common shared subdirectories off of
> libbsp/nios2/shared
> Ok.
> > I am also currently working on the internal interrupt controller ISR
> handler
> > o there appear to be some race conditions in the code I received
> > o possibly the code should be repackaged so all of it is in assembler.
> That might make the race conditions easier to understand?
> > o I have written a code that determines the interrupt vector number
> based on the lowest-bit-set in the interrupt pending register with less
> cpu overhead and more deterministic delay compared with the previous
> assembler loop code (I suspect you may be working on this also).
> > o I have also written some code to mask out interrupts of equal or lower
> interrupt level when the user's isr is running, but allow higher level
> interrupts to preempt.
> I only looked briefly at the IIC code and think that there are a number of
> issues with the current code.  We use the EIC, thus I didn't investigate
> this
> further.  I have also no ability to test this.
> > In any case I just now noticed that there have been some commits in
> September against the NIOS2 support in RTEMS so I decided that I will need
> to sync up with your efforts. I will be looking closely at what you have
> done since my snapshot in February of last year.
> > In summary I am writing this message to see if we might work together
> and make faster progress.
> Ok, great.  You can send patches to rtems-devel at www.rtems.org (e.g. with
> git
> format-patch + git send-email).  Please use one commit for one atomic
> change
> set so the review and integration is easier.
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
Type: application/x-gzip
Desc: nios2-altera-sys-config.tar.gz
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120712/7aa26068/attachment.bin>
