ANN: mingw64/mingw-w64 x86_64
Ralf Corsepius ralf.corsepius at rtems.org
Tue May 1 06:25:48 UTC 2012
On 04/24/2012 06:31 PM, Ralf Corsepius wrote:
> Hi,
> As some of you already might know, with the upcoming release of Fedora
> 17, Fedora is switching its mingw toolchains from i686-pc-mingw32
> to i686-w64-mingw32 and x86_64-w64-mingw32 [1]
> As this step has pretty massive impacts on the way I am building the
> mingw toolchains, as an initial experiment, I have started to build
> x86_64-w64-mingw32 -> rtems (64bit Windows)
> toolchains.
> ATM, they are available under ftp://ftp.rtems.org/pub/rtems/mingw64
> (Whether this location will remain permanent is not clear yet).
I just changed the location and added another toolchain variant:
* ftp://ftp.rtems.org/pub/rtems/mingw64/x86_64:
- 64bit Windows, x86_64-w64-mingw32
- This directory now contains the packages which had been under
* ftp://ftp.rtems.org/pub/rtems/mingw64/i686:
- 32bit Windows, i686-w64-mingw32
- These packages are supposed to eventually replace the i686-pc-mingw32
   compiled packages which currently can be found under
   ftp://ftp.rtems.org/pub/rtems/mingw32
Note:
- Both sets of packages can not be installed in parallel.
When wanting to install them, you need to decide for one of these (32bit
or 64bit).
- Mixing i686-pc-mingw32 with i686-w64-mingw32 packages is untested.
Ralf
