[PATCH 1/5] libmm score API
Hesham AL-Matary heshamelmatary at gmail.com
Mon Aug 26 00:14:51 UTC 2013
 cpukit/score/Makefile.am                  |  2 +
 cpukit/score/include/rtems/score/mm.h     | 52 ++++++++++++++++++++
 cpukit/score/include/rtems/score/mmimpl.h | 80 +++++++++++++++++++++++++++++++
 cpukit/score/preinstall.am                |  8 ++++
 4 files changed, 142 insertions(+)
 create mode 100644 cpukit/score/include/rtems/score/mm.h
 create mode 100644 cpukit/score/include/rtems/score/mmimpl.h
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index c9d2d47..b94af80 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -37,6 +37,8 @@ include_rtems_score_HEADERS += include/rtems/score/interr.h
 include_rtems_score_HEADERS += include/rtems/score/isr.h
 include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
 include_rtems_score_HEADERS += include/rtems/score/isrlock.h
+include_rtems_score_HEADERS += include/rtems/score/mm.h
+include_rtems_score_HEADERS += include/rtems/score/mmimpl.h
 include_rtems_score_HEADERS += include/rtems/score/freechain.h
 include_rtems_score_HEADERS += include/rtems/score/object.h
 include_rtems_score_HEADERS += include/rtems/score/objectimpl.h
diff --git a/cpukit/score/include/rtems/score/mm.h b/cpukit/score/include/rtems/score/mm.h
new file mode 100644
index 0000000..43f6fc9
--- /dev/null
+++ b/cpukit/score/include/rtems/score/mm.h
@@ -0,0 +1,52 @@
+ * @file
+ * @brief Manages use of MPU/MMU units to provide memory management.
+ * Copyright (c) 2013 Hesham Al-Matary.
+ * Copyright (c) 2013 Gedare Bloom.
+ * http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_SCORE_MM_H
+#define _RTEMS_SCORE_MM_H
+/* @defgroup SuperCoreMM Memory Management Support
+ * @ingroup Score
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @brief _Memory_management_Region Flags defs
+#define RTEMS_MM_REGION_NO_PROTECTION           0x0
+#define RTEMS_MM_REGION_PROTECTION_READ_ONLY    0x1
+#define RTEMS_MM_REGION_PROTECTION_WRITE        0x2
+#define RTEMS_MM_REGION_NO_ACCESS               0x3
+//#define RTEMS_MM_REGION_PROTECTION_EXEC   0x4
+void _Memory_management_Initialize( void );
+void _Memory_management_Set_attributes(
+  uintptr_t base,
+  size_t size,
+  uint32_t attr
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/score/include/rtems/score/mmimpl.h b/cpukit/score/include/rtems/score/mmimpl.h
index 0000000..7eecef0
--- /dev/null
+++ b/cpukit/score/include/rtems/score/mmimpl.h
@@ -0,0 +1,80 @@
+ * @file
+ * @brief Inlined Routines from the Memory Management Manager
+ * Copyright (c) 2013 Hesham AL-Matary
+#ifndef _RTEMS_SCORE_MMIMPL_H
+#define _RTEMS_SCORE_MMIMPL_H
+#ifdef RTEMS_SMP
+#include <rtems/score/smplock.h>
+#endif
+#include <stdint.h>
+#include <stdlib.h>
+#include <rtems/score/mm.h>
+#include <libcpu/mm.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup SuperCoreMM
+#ifdef RTEMS_SMP
+SMP_lock_Control mm_lock;
+#endif
+ * @brief Calls _CPU_Memory_management_Initialize.
+#ifdef RTEMS_SMP
+  _SMP_lock_Initialize( &mm_lock );
+#endif
+  _CPU_Memory_management_Initialize();
+ * @brief Calls _CPU_Memory_management_Set_attributes.
+  uintptr_t base,
+  size_t size,
+  uint32_t attr
+#ifdef RTEMS_SMP
+  _SMP_lock_Acquire( &mm_lock );
+#endif
+  _CPU_Memory_management_Set_attributes(base, size, attr);
+#ifdef RTEMS_SMP
+  _SMP_lock_Release( &mm_lock );
+#endif
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 79a18b5..4b3bfcf 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -131,6 +131,14 @@ $(PROJECT_INCLUDE)/rtems/score/isrlock.h: include/rtems/score/isrlock.h $(PROJEC
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isrlock.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isrlock.h
+$(PROJECT_INCLUDE)/rtems/score/mm.h: include/rtems/score/mm.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mm.h
+$(PROJECT_INCLUDE)/rtems/score/mmimpl.h: include/rtems/score/mmimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mmimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mmimpl.h
 $(PROJECT_INCLUDE)/rtems/score/freechain.h: include/rtems/score/freechain.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/freechain.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/freechain.h
1.8.3.1
