[PATCH 1/2] add atomc_sub and atomic_compare_exchange into smpatomic08
    WeiY
    wei.a.yang at gmail.com
    Sat Aug 31 01:49:17 UTC 2013
 testsuites/smptests/smpatomic08/init.c          |  109 ++++++++++++++++++++++-
 testsuites/smptests/smpatomic08/smpatomic08.scn |    8 ++
 2 files changed, 116 insertions(+), 1 deletion(-)
diff --git a/testsuites/smptests/smpatomic08/init.c b/testsuites/smptests/smpatomic08/init.c
index 19c81e6..92b93cc 100644
--- a/testsuites/smptests/smpatomic08/init.c
+++ b/testsuites/smptests/smpatomic08/init.c
@@ -78,6 +78,8 @@ typedef struct {
   size_t worker_count;
   rtems_id stop_worker_timer_id;
   Atomic_Uint global_uint;
+  Atomic_Uint global_swap;
+  uint_fast32_t global_swap_t;
   uint_fast32_t per_worker_uint[CPU_COUNT];
   uint32_t flag_counter;
   Atomic_Flag global_flag;
@@ -207,9 +209,114 @@ static void test_atomic_flag_fini(test_context *ctx)
   rtems_test_assert(expected_counter == actual_counter);
+static void test_atomic_sub_init(test_context *ctx)
+  _Atomic_Init_uint(&ctx->global_uint, 0xffffffff);
+static void test_atomic_sub_body(test_context *ctx, size_t worker_index)
+  uint_fast32_t counter = 0xffffffff;
+  while (!stop(ctx)) {
+    --counter;
+    _Atomic_Fetch_sub_uint(&ctx->global_uint, 1, ATOMIC_ORDER_RELAXED);
+  ctx->per_worker_uint[worker_index] = 0xffffffff - counter;
+static void test_atomic_sub_fini(test_context *ctx)
+  uint_fast32_t expected_counter = 0;
+  uint_fast32_t actual_counter;
+  size_t worker_index;
+  printf("=== atomic sub test case ==\n");
+  for (worker_index = 0; worker_index < ctx->worker_count; ++worker_index) {
+    uint_fast32_t worker_counter = ctx->per_worker_uint[worker_index];
+    expected_counter += worker_counter;
+    printf(
+      "atomic sub worker %zu counter: %" PRIuFAST32 "\n",
+      worker_index,
+      worker_counter
+  actual_counter = _Atomic_Load_uint(&ctx->global_uint, ATOMIC_ORDER_RELAXED);
+  actual_counter = 0xffffffff - actual_counter;
+  printf(
+    "global counter: expected = %" PRIuFAST32 ", actual = %" PRIuFAST32 "\n",
+    expected_counter,
+    actual_counter
+  rtems_test_assert(expected_counter == actual_counter);
+static void test_atomic_compare_exchange_init(test_context *ctx)
+  _Atomic_Init_uint(&ctx->global_swap, 0);
+  ctx->global_swap_t = 0;
+static void test_atomic_compare_exchange_body(test_context *ctx, size_t worker_index)
+  uint_fast32_t counter = 0;
+    while (_Atomic_Compare_exchange_uint(&ctx->global_swap, &ctx->global_swap_t,
+      worker_index, ATOMIC_ORDER_ACQUIRE, ATOMIC_ORDER_RELEASE)) {
+      /* Wait */
+    ++counter;
+    ++ctx->flag_counter;
+    ctx->global_swap_t = worker_index;
+  ctx->per_worker_uint[worker_index] = counter;
+static void test_atomic_compare_exchange_fini(test_context *ctx)
+  printf("=== atomic compare_exchange test case ==\n");
+    printf(
+      "atomic compare_exchange worker %zu counter: %" PRIuFAST32 "\n",
+      worker_index,
+      worker_counter
+  printf(
+    expected_counter,
+    actual_counter
 static const test_case test_cases[] = {
   { test_atomic_add_init, test_atomic_add_body, test_atomic_add_fini },
-  { test_atomic_flag_init, test_atomic_flag_body, test_atomic_flag_fini }
+  { test_atomic_flag_init, test_atomic_flag_body, test_atomic_flag_fini },
+  { test_atomic_sub_init, test_atomic_sub_body, test_atomic_sub_fini },
+  { test_atomic_compare_exchange_init, test_atomic_compare_exchange_body,
+    test_atomic_compare_exchange_fini },
 #define TEST_COUNT RTEMS_ARRAY_SIZE(test_cases)
diff --git a/testsuites/smptests/smpatomic08/smpatomic08.scn b/testsuites/smptests/smpatomic08/smpatomic08.scn
index 70aeef1..0402978 100644
--- a/testsuites/smptests/smpatomic08/smpatomic08.scn
+++ b/testsuites/smptests/smpatomic08/smpatomic08.scn
@@ -7,4 +7,12 @@ global counter: expected = 54907, actual = 54907
 atomic flag worker 0 counter: 7388
 atomic flag worker 1 counter: 17280
 global flag counter: expected = 24668, actual = 24668
+=== atomic sub test case ==
+atomic sub worker 0 counter: 18583
+atomic sub worker 1 counter: 36324
+global counter: expected = 54907, actual = 54907
+=== atomic compare_exchange test case ==
+atomic compare_exchange worker 0 counter: 5340
+atomic compare_exchange worker 1 counter: 10034
+global counter: expected = 15374, actual = 15374
 *** END OF TEST SMPATOMIC 8 ***
1.7.9.5
