[PATCH v2 0/3] Moxie CPU port (resubmission)
Anthony Green green at moxielogic.com
Wed Feb 27 14:11:24 UTC 2013
This is a resubmission of yesterday's moxie port, which was
accidentally based on a slightly older version of RTEMS.  This one is
based against the current git tree.
Thanks,
AG
Anthony Green (3):
  Add Moxie CPU support
  Add sample Moxie BSP for GDB sim
  Common file changes in support of Moxie port
 c/src/ChangeLog                                    |    4 +
 c/src/aclocal/rtems-cpu-subdirs.m4                 |    1 +
 c/src/lib/libbsp/moxie/.cvsignore                  |    8 +
 c/src/lib/libbsp/moxie/ChangeLog                   |    3 +
 c/src/lib/libbsp/moxie/Makefile.am                 |   11 +
 c/src/lib/libbsp/moxie/acinclude.m4                |   10 +
 c/src/lib/libbsp/moxie/configure.ac                |   21 +
 c/src/lib/libbsp/moxie/moxiesim/.cvsignore         |    8 +
 c/src/lib/libbsp/moxie/moxiesim/ChangeLog          |    7 +
 c/src/lib/libbsp/moxie/moxiesim/Makefile.am        |   49 +
 c/src/lib/libbsp/moxie/moxiesim/bsp_specs          |   11 +
 c/src/lib/libbsp/moxie/moxiesim/configure.ac       |   22 +
 .../lib/libbsp/moxie/moxiesim/console/console-io.c |   67 ++
 c/src/lib/libbsp/moxie/moxiesim/console/syscalls.S |   14 +
 c/src/lib/libbsp/moxie/moxiesim/include/.cvsignore |    5 +
 c/src/lib/libbsp/moxie/moxiesim/include/bsp.h      |   47 +
 .../libbsp/moxie/moxiesim/make/custom/moxiesim.cfg |   15 +
 c/src/lib/libbsp/moxie/moxiesim/preinstall.am      |   67 ++
 c/src/lib/libbsp/moxie/moxiesim/start/start.S      |   22 +
 c/src/lib/libbsp/moxie/moxiesim/startup/__main.c   |   22 +
 c/src/lib/libbsp/moxie/moxiesim/startup/linkcmds   |  251 +++++
 .../moxie/moxiesim/startup/moxiebdinstallirq.c     |   22 +
 cpukit/ChangeLog                                   |    6 +
 cpukit/configure.ac                                |    1 +
 cpukit/librpc/src/xdr/xdr_float.c                  |    2 +-
 cpukit/score/cpu/Makefile.am                       |    1 +
 cpukit/score/cpu/moxie/.cvsignore                  |    2 +
 cpukit/score/cpu/moxie/ChangeLog                   |    9 +
 cpukit/score/cpu/moxie/Makefile.am                 |   19 +
 cpukit/score/cpu/moxie/cpu.c                       |  152 +++
 cpukit/score/cpu/moxie/cpu_asm.S                   |  119 +++
 .../score/cpu/moxie/moxie-exception-frame-print.c  |   18 +
 cpukit/score/cpu/moxie/preinstall.am               |   41 +
 cpukit/score/cpu/moxie/rtems/asm.h                 |  116 +++
 cpukit/score/cpu/moxie/rtems/score/cpu.h           | 1092 ++++++++++++++++++++
 cpukit/score/cpu/moxie/rtems/score/moxie.h         |   45 +
 cpukit/score/cpu/moxie/rtems/score/types.h         |   55 +
 37 files changed, 2364 insertions(+), 1 deletion(-)
 create mode 100644 c/src/lib/libbsp/moxie/.cvsignore
 create mode 100644 c/src/lib/libbsp/moxie/ChangeLog
 create mode 100644 c/src/lib/libbsp/moxie/Makefile.am
 create mode 100644 c/src/lib/libbsp/moxie/acinclude.m4
 create mode 100644 c/src/lib/libbsp/moxie/configure.ac
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/.cvsignore
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/ChangeLog
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/Makefile.am
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/bsp_specs
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/configure.ac
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/console/console-io.c
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/console/syscalls.S
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/include/.cvsignore
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/include/bsp.h
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/make/custom/moxiesim.cfg
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/preinstall.am
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/start/start.S
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/startup/__main.c
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/startup/linkcmds
 create mode 100644 c/src/lib/libbsp/moxie/moxiesim/startup/moxiebdinstallirq.c
 create mode 100644 cpukit/score/cpu/moxie/.cvsignore
 create mode 100644 cpukit/score/cpu/moxie/ChangeLog
 create mode 100644 cpukit/score/cpu/moxie/Makefile.am
 create mode 100644 cpukit/score/cpu/moxie/cpu.c
 create mode 100644 cpukit/score/cpu/moxie/cpu_asm.S
 create mode 100644 cpukit/score/cpu/moxie/moxie-exception-frame-print.c
 create mode 100644 cpukit/score/cpu/moxie/preinstall.am
 create mode 100644 cpukit/score/cpu/moxie/rtems/asm.h
 create mode 100644 cpukit/score/cpu/moxie/rtems/score/cpu.h
 create mode 100644 cpukit/score/cpu/moxie/rtems/score/moxie.h
 create mode 100644 cpukit/score/cpu/moxie/rtems/score/types.h
1.8.1.4
