[Patch] Makefile / cfg changes for EXEEXT, LD_PATHS and source subdirectories
Nick Withers nick.withers at anu.edu.au
Fri Jul 5 01:22:56 UTC 2013
Hey all!
I discovered make/Templates/Makefile.leaf the other day and decided it'd
probably be a good idea for me to use that as a base, in place of the
Makefile I'd clobbered together.
There were a few things that slowed me down a bit getting things back to
where I had 'em:
  - My LD_PATHS settings appeared to have no effect
  - I've application sources in subdirectories (not with Makefiles in
them, mind you, just .c / .h) and these weren't created in the
o-optimize / o-debug output directories, making GCC unhappy
  - I didn't want to use the ".exe" extension but that was hardcoded
...So I knocked up the diffs at the end of this email.
Any feedback / concerns / things I've missed? Would it be possible to
merge these (or similar) or a subset in for 4.11? Would you like
individual patches for each "issue" addressed?
Thanks!
P.S.: "ARCH" struck me as a a bit of an unusual variable to use to mean
"object directory" (maybe OBJDIR would be more clear...?). I'd have
thought "ARCH" would refer to the processor architecture, or perhaps the
RTEMS target architecture (maybe it's 'coz the architecture used to be
part of the directory structure?). Happy to submit patches to do so, if
that's the will of the council.
__
Righto, the patch for LD_PATHS [1] (all of these were generated with
"git diff" in the rtems.git root):
____
diff --git a/c/src/make/compilers/gcc-target-default.cfg
b/c/src/make/compilers/gcc-target-default.cfg
index 813bd5c..a70681d 100644
--- a/c/src/make/compilers/gcc-target-default.cfg
+++ b/c/src/make/compilers/gcc-target-default.cfg
@@ -65,13 +65,12 @@ CXXFLAGS += $(CXXFLAGS_OPTIMIZE) $(CXXFLAGS_DEBUG)
 endif
 # List of library paths without -L
-LD_PATHS= $(PROJECT_RELEASE)/lib
+LD_PATHS+= $(PROJECT_RELEASE)/lib
 # ld flag for incomplete link
 LDFLAGS_INCOMPLETE = -r
-# LDFLAGS=$(LDFLAGS_DEBUG) $(LD_PATHS:%=-L%)
-LDFLAGS += $(LDFLAGS_DEBUG)
+LDFLAGS+=$(LDFLAGS_DEBUG) $(LD_PATHS:%=-L%)
 # Stuff to clean and clobber for the compiler and its tools
____
[1] See
http://git.rtems.org/rtems/commit/c/src/make/compilers/gcc-target-default.cfg?id=ea9f76742163cccf98eb326db7459c18d2fad1b6 for why LD_PATHS had been commented ("Now implicitly handled by gcc-spec"). I've got an extra library to pull in, though (RTEMS_gdb_stub), and Makefile.leaf advertises it should be used, so I think putting it back is the right thing to do...?
The patch for source subdirectories:
____
diff --git a/make/main.cfg b/make/main.cfg
index 1a712de..e9219b4 100644
--- a/make/main.cfg
+++ b/make/main.cfg
@@ -40,8 +40,15 @@ ARCH_DEBUG_V = o-debug
 ARCH__V = $(ARCH_OPTIMIZE_V)
 ARCH = $(ARCH_$(VARIANT_V)_V)
+ARCH_DIRS = $(filter-out ./, $(dir $(C_FILES)))
 $(ARCH):
 	test -d ${ARCH} || mkdir $(ARCH)
+ifneq ($(strip ARCH_DIRS),)
+	mkdir -p ${ARCH_DIRS:%=${ARCH}/%}
+endif
 # Default makefile name
 # May be overridden by command line macro assignment
____
...and the far longer patch for EXEEXT (in which I also replaced ".ralf"
with "$(DOWNEXT)" in
c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc):
____
diff --git a/c/src/lib/libbsp/arm/gba/make/custom/gba.cfg b/c/src/lib/libbsp/arm/gba/make/custom/gba.cfg
index ee9be6a..1ae2fb8 100644
--- a/c/src/lib/libbsp/arm/gba/make/custom/gba.cfg
+++ b/c/src/lib/libbsp/arm/gba/make/custom/gba.cfg
@@ -20,6 +20,6 @@ CFLAGS_OPTIMIZE_V = -O2 -g
 define bsp-post-link
 	$(OBJCOPY) -O binary --remove-section=.comment \
 	    --remove-section=.note --strip-unneeded \
-	    $(basename $@).exe $(basename $@)$(DOWNEXT)
+	    $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
 	$(default-bsp-post-link)
 endef
diff --git a/c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg b/c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg
index f287310..a558362 100644
--- a/c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg
+++ b/c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg
@@ -16,6 +16,6 @@ CPU_CFLAGS = -mstructure-size-boundary=32 -mcpu=arm920t -mfpu=vfp -mfloat-abi=so
-	$(OBJCOPY) -O binary $(basename $@).exe $(basename $@)$(DOWNEXT)
+	$(OBJCOPY) -O binary $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
 endef
diff --git a/c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc b/c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc
index 4387c19..362d9f4 100644
--- a/c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc
+++ b/c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc
@@ -12,5 +12,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g
-	$(OBJCOPY) -O binary $(basename $@).exe $(basename $@).ralf
 endef
diff --git a/c/src/lib/libbsp/arm/nds/make/custom/nds.cfg b/c/src/lib/libbsp/arm/nds/make/custom/nds.cfg
index 9e4844d..78172e6 100644
--- a/c/src/lib/libbsp/arm/nds/make/custom/nds.cfg
+++ b/c/src/lib/libbsp/arm/nds/make/custom/nds.cfg
@@ -28,7 +28,7 @@ endif
-	$(OBJCOPY) -O binary $(basename $@).exe $(basename $@).bin
+	$(OBJCOPY) -O binary $(basename $@)$(EXEEXT) $(basename $@).bin
 	$(NDSTOOL) -c $(basename $@).nds -9 $(basename $@).bin \
 	    -7 $(COPROC_ELF_PATH)/coproc.bin
 	rm -f $(basename $@).bin
diff --git a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
index 9751658..6b47ea2 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
+++ b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
@@ -16,7 +16,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g
 # is currently required.
     $(OBJCOPY) -O binary --strip-all \
-    $(SIZE) $(basename $@).exe
+    $(SIZE) $(basename $@)$(EXEEXT)
 endef
diff --git a/c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg b/c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg
index e827d87..9f7428d 100644
--- a/c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg
+++ b/c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg
@@ -46,7 +46,7 @@ define bsp-post-link
 	$(OBJCOPY) -O elf32-i386 \
 	    --remove-section=.note \
-	    --strip-unneeded $(basename $@).exe $(basename $@).nxe
+	    --strip-unneeded $(basename $@)$(EXEEXT) $(basename $@).nxe
 	$(OBJCOPY) -O binary $(basename $@).nxe $(basename $@).bin
 	$(PROJECT_TOOLS)/bin2boot -v $(basename $@)$(DOWNEXT) $(HEADERADDR)\
 	  $(START16FILE) $(START16ADDR) 0 $(basename $@).bin $(RELOCADDR) 0
diff --git a/c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr.cfg b/c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr.cfg
index d70ff80..c1951d0 100644
--- a/c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr.cfg
+++ b/c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr.cfg
@@ -21,7 +21,7 @@ CPU_CFLAGS =
 CFLAGS_OPTIMIZE_V = -O0 -g
-	$(OBJCOPY) -O binary --strip-all $(basename $@).exe \
+	$(OBJCOPY) -O binary --strip-all $(basename $@)$(EXEEXT) \
 	    -R entry -R exceptions $(basename $@)$(DOWNEXT)
 endef
diff --git a/c/src/lib/libbsp/lm32/milkymist/make/custom/milkymist.cfg b/c/src/lib/libbsp/lm32/milkymist/make/custom/milkymist.cfg
index 5a44658..ae691eb 100644
--- a/c/src/lib/libbsp/lm32/milkymist/make/custom/milkymist.cfg
+++ b/c/src/lib/libbsp/lm32/milkymist/make/custom/milkymist.cfg
@@ -21,7 +21,7 @@ CPU_CFLAGS = -mbarrel-shift-enabled -mmultiply-enabled \
 endef
diff --git a/c/src/lib/libbsp/m68k/av5282/make/custom/av5282.cfg b/c/src/lib/libbsp/m68k/av5282/make/custom/av5282.cfg
index 0bbeaf1..a668d99 100644
--- a/c/src/lib/libbsp/m68k/av5282/make/custom/av5282.cfg
+++ b/c/src/lib/libbsp/m68k/av5282/make/custom/av5282.cfg
@@ -22,5 +22,5 @@ endif
 endef
diff --git a/c/src/lib/libbsp/m68k/genmcf548x/make/custom/genmcf548x.inc b/c/src/lib/libbsp/m68k/genmcf548x/make/custom/genmcf548x.inc
index 843524c..a910bd3 100644
--- a/c/src/lib/libbsp/m68k/genmcf548x/make/custom/genmcf548x.inc
+++ b/c/src/lib/libbsp/m68k/genmcf548x/make/custom/genmcf548x.inc
@@ -15,7 +15,7 @@ CPU_CFLAGS = -mcfv4e -Wa,-memac
 CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
 endef
diff --git a/c/src/lib/libbsp/m68k/idp/make/custom/idp.cfg b/c/src/lib/libbsp/m68k/idp/make/custom/idp.cfg
index 937ce30..d10029a 100644
--- a/c/src/lib/libbsp/m68k/idp/make/custom/idp.cfg
+++ b/c/src/lib/libbsp/m68k/idp/make/custom/idp.cfg
@@ -16,7 +16,7 @@ CPU_CFLAGS = -msoft-float
-	$(OBJCOPY) -O srec $(basename $@).exe $(basename $@).srec
+	$(OBJCOPY) -O srec $(basename $@)$(EXEEXT) $(basename $@).srec
 	sed -e 's/.$$//' -e '/^S0/d' $(basename $@).srec | \
 	    $(PACKHEX) > $(basename $@)$(DOWNEXT)
 	rm -f  $(basename $@).srec
diff --git a/c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg b/c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg
index 4dcb890..9b22a21 100644
--- a/c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg
+++ b/c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg
@@ -18,6 +18,6 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
 endef
diff --git a/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg b/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg
index 6a415a7..90e76e2 100644
--- a/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg
+++ b/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg
@@ -22,6 +22,6 @@ CFLAGS_OPTIMIZE_V = -O2 -fomit-frame-pointer
 endef
diff --git a/c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg b/c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg
index 8a543ac..b5c3c49 100644
--- a/c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg
+++ b/c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg
@@ -22,6 +22,6 @@ endif
 endef
diff --git a/c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg b/c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg
index e68fd28..e1f5734 100644
--- a/c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg
+++ b/c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg
@@ -20,6 +20,6 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
 endef
diff --git a/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg b/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
index a1be91b..bf55e4f 100644
--- a/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
+++ b/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
@@ -31,8 +31,8 @@ define bsp-post-link
 	        return s } ;\
 	        /\.text/ { base = $$4 ; size = $$3 };\
 	        END { printf("0x%x", h2d(base) + h2d(size)) }'\
-	       ` $(basename $@).pxe $(basename $@).exe
+	       ` $(basename $@).pxe $(basename $@)$(EXEEXT)
 	$(NM) -g -n $(basename $@).pxe > $(basename $@).pnum
@@ -41,7 +41,7 @@ define bsp-post-link
 endef
 else
diff --git a/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg b/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg
index 74cdd64..2f63f04 100644
--- a/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg
+++ b/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg
@@ -17,7 +17,7 @@ CPU_CFLAGS = -mcpu=68020
 CFLAGS_OPTIMIZE_V = -Os -g -fomit-frame-pointer -DNDEBUG
diff --git a/c/src/lib/libbsp/m68k/mvme147/make/custom/mvme147.cfg b/c/src/lib/libbsp/m68k/mvme147/make/custom/mvme147.cfg
index 0ba9719..9880587 100644
--- a/c/src/lib/libbsp/m68k/mvme147/make/custom/mvme147.cfg
+++ b/c/src/lib/libbsp/m68k/mvme147/make/custom/mvme147.cfg
@@ -15,7 +15,7 @@ CPU_CFLAGS = -mcpu=68030
diff --git a/c/src/lib/libbsp/m68k/mvme147s/make/custom/mvme147s.cfg b/c/src/lib/libbsp/m68k/mvme147s/make/custom/mvme147s.cfg
index e14de8d..3eaade8 100644
--- a/c/src/lib/libbsp/m68k/mvme147s/make/custom/mvme147s.cfg
+++ b/c/src/lib/libbsp/m68k/mvme147s/make/custom/mvme147s.cfg
diff --git a/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162.cfg b/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162.cfg
index d8a217f..4b343b2 100644
--- a/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162.cfg
+++ b/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162.cfg
@@ -20,7 +20,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
 endef
 # BSP-specific tools
diff --git a/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx.cfg b/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx.cfg
index 81c398e..2a210a9 100644
--- a/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx.cfg
+++ b/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx.cfg
@@ -25,7 +25,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
 endef
diff --git a/c/src/lib/libbsp/m68k/mvme167/make/custom/mvme167.cfg b/c/src/lib/libbsp/m68k/mvme167/make/custom/mvme167.cfg
index a56de0f..21bd9af 100644
--- a/c/src/lib/libbsp/m68k/mvme167/make/custom/mvme167.cfg
+++ b/c/src/lib/libbsp/m68k/mvme167/make/custom/mvme167.cfg
@@ -36,5 +36,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-omit-frame-pointer
 # for more details.
-    $(OBJCOPY) -O binary -R .comment -S $(basename $@).exe $(basename $@)$(DOWNEXT)
+    $(OBJCOPY) -O binary -R .comment -S $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
 endef
diff --git a/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg b/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg
index bb3354a..fb355cb 100644
--- a/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg
+++ b/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg
@@ -16,5 +16,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
-	$(OBJCOPY) -O srec $(basename $@).exe $(basename $@)$(DOWNEXT)
+	$(OBJCOPY) -O srec $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
 endef
diff --git a/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg b/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg
index 939a1e1..817e162 100644
--- a/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg
+++ b/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg
 endef
diff --git a/c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg b/c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg
index caf93a8..3c62a17 100644
--- a/c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg
+++ b/c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg
 endef
diff --git a/c/src/lib/libbsp/nios2/nios2_iss/make/custom/nios2_iss.cfg b/c/src/lib/libbsp/nios2/nios2_iss/make/custom/nios2_iss.cfg
index e8fb39d..8254eec 100644
--- a/c/src/lib/libbsp/nios2/nios2_iss/make/custom/nios2_iss.cfg
+++ b/c/src/lib/libbsp/nios2/nios2_iss/make/custom/nios2_iss.cfg
@@ -21,7 +21,7 @@ CPU_CFLAGS = -mno-hw-mul -mno-hw-div
 endef
diff --git a/c/src/lib/libbsp/powerpc/haleakala/make/custom/haleakala.cfg b/c/src/lib/libbsp/powerpc/haleakala/make/custom/haleakala.cfg
index 41cd98e..67ffe58 100644
--- a/c/src/lib/libbsp/powerpc/haleakala/make/custom/haleakala.cfg
+++ b/c/src/lib/libbsp/powerpc/haleakala/make/custom/haleakala.cfg
@@ -20,5 +20,5 @@ CFLAGS_OPTIMIZE_V = -O1 -g
 endef
diff --git a/c/src/lib/libbsp/powerpc/mbx8xx/make/custom/mbx8xx.inc b/c/src/lib/libbsp/powerpc/mbx8xx/make/custom/mbx8xx.inc
index c1a2235..4795de7 100644
--- a/c/src/lib/libbsp/powerpc/mbx8xx/make/custom/mbx8xx.inc
+++ b/c/src/lib/libbsp/powerpc/mbx8xx/make/custom/mbx8xx.inc
@@ -49,7 +49,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
 LDFLAGS += $(MBX8xx_LDFLAGS)
-	cp $(basename $@).exe $(basename $@)$(DOWNEXT)
+	cp $(basename $@)$(EXEEXT)  $(basename $@)$(DOWNEXT)
 	$(STRIP) $(basename $@)$(DOWNEXT)
 endef
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg
index fc775d1..8ff97b3 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg
@@ -17,11 +17,11 @@ CFLAGS_OPTIMIZE_V = -O2 -g -mmultiple -mstring -mstrict-align
- 	$(OBJCOPY) -O binary -R .comment -S $(basename $@).exe rtems
+ 	$(OBJCOPY) -O binary -R .comment -S $(basename $@)$(EXEEXT) rtems
  	gzip -vf9 rtems
  	$(LD) -o $(basename $@)$(DOWNEXT) \
 	    $ $(PROJECT_RELEASE)/lib/bootloader.o \
-	    --just-symbols=$(basename $@).exe \
+	    --just-symbols=$(basename $@)$(EXEEXT) \
  	    -b binary rtems.gz -T $(PROJECT_RELEASE)/lib/ppcboot.lds \
  	    -Map $(basename $@).map && chmod 755 $@
  	rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg
index 2411501..6c7f597 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg
@@ -16,11 +16,11 @@ CFLAGS_OPTIMIZE_V = -O2 -g -mmultiple -mstring -mstrict-align
  	gzip -vf9 rtems
  	rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg
index 93e14ab..d724b5d 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg
  	gzip -vf9 rtems
  	rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg
index d7dac3a..ee00561 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg
@@ -17,10 +17,10 @@ CFLAGS_OPTIMIZE_V = -O2 -g
  	gzip -vf9 rtems
  	$(LD) -o $(basename $@)$(DOWNEXT)  $(PROJECT_RELEASE)/lib/bootloader.o \
  	rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg
index cef17e5..1dd1744 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg
@@ -18,15 +18,15 @@ CFLAGS_OPTIMIZE_V = -O2 -g
 ifdef PURE_BINARY
 endef
 else
  	gzip -vf9 rtems
  	rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg
index 3922767..e5f11fc 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg
 ifdef PURE_BINARY
 endef
 else
  	gzip -vf9 rtems
  	rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/make/custom/mvme3100.cfg b/c/src/lib/libbsp/powerpc/mvme3100/make/custom/mvme3100.cfg
index 3ea5c2b..ddd6d23 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/make/custom/mvme3100.cfg
+++ b/c/src/lib/libbsp/powerpc/mvme3100/make/custom/mvme3100.cfg
@@ -17,5 +17,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g
 endef
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/make/custom/mvme5500.cfg b/c/src/lib/libbsp/powerpc/mvme5500/make/custom/mvme5500.cfg
index b4727bc..4c59a07 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/make/custom/mvme5500.cfg
+++ b/c/src/lib/libbsp/powerpc/mvme5500/make/custom/mvme5500.cfg
@@ -19,7 +19,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g
 endef
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg b/c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg
index 177f88f..b768855 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg
+++ b/c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg
@@ -16,5 +16,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
 endef
diff --git a/c/src/lib/libbsp/powerpc/score603e/make/custom/score603e.cfg b/c/src/lib/libbsp/powerpc/score603e/make/custom/score603e.cfg
index 7b03438..a657bb3 100644
--- a/c/src/lib/libbsp/powerpc/score603e/make/custom/score603e.cfg
+++ b/c/src/lib/libbsp/powerpc/score603e/make/custom/score603e.cfg
@@ -22,7 +22,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
-	$(OBJCOPY) -O srec $(basename $@).exe $(basename $@).s1
+	$(OBJCOPY) -O srec $(basename $@)$(EXEEXT) $(basename $@).s1
 	sed -e 's/.$$//' $(basename $@).s1 | \
 	  $(PACKHEX) >$(basename $@)$(DOWNEXT)
 	rm -f $(basename $@).s1
diff --git a/c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg b/c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg
index 22ae7fb..cde7f4a 100644
--- a/c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg
+++ b/c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg
@@ -23,6 +23,6 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
 endef
diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/make/custom/tqm8xx.inc b/c/src/lib/libbsp/powerpc/tqm8xx/make/custom/tqm8xx.inc
index 119bc28..da32441 100644
--- a/c/src/lib/libbsp/powerpc/tqm8xx/make/custom/tqm8xx.inc
+++ b/c/src/lib/libbsp/powerpc/tqm8xx/make/custom/tqm8xx.inc
@@ -15,7 +15,7 @@ CPU_CFLAGS = -mcpu=860 -Dmpc860 \
 endef
diff --git a/c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg b/c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg
index a91530c..96aa7cc 100644
--- a/c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg
+++ b/c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg
@@ -19,5 +19,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
 endef
diff --git a/c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg b/c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg
index 333b144..713c297 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg
+++ b/c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg
@@ -14,6 +14,6 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
 # Miscellaneous additions go here
 endef
diff --git a/c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg b/c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg
index b4a7bd3..9601fbc 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg
+++ b/c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg
 endef
diff --git a/c/src/make/leaf.cfg b/c/src/make/leaf.cfg
index dd0defe..8d3f52e 100644
--- a/c/src/make/leaf.cfg
+++ b/c/src/make/leaf.cfg
@@ -8,11 +8,8 @@ ifndef LINKCMDS
 LINKCMDS=$(PROJECT_RELEASE)/lib/linkcmds
 endif
-## what to do about $(EXEEXT) --> $(EXEEXT)
-##    -o $(basename $@)$(EXEEXT)             OR
-DOWNEXT=.ralf
+EXEEXT?=.exe
+DOWNEXT?=.ralf
 define bsp-link-c
 	$(LINK.c) $(CPU_CFLAGS) $(AM_CFLAGS) $(AM_LDFLAGS) \
diff --git a/make/leaf.cfg b/make/leaf.cfg
index 90cda37..6ebf4bd 100644
--- a/make/leaf.cfg
+++ b/make/leaf.cfg
@@ -78,20 +78,17 @@ clean: clean-am
 .PHONY: clean clean-am
 endif
-DOWNEXT=.ralf
+EXEEXT?=.exe
+DOWNEXT?=.ralf
 define bsp-link-c
-	    -o $(basename $@).exe $(LINK_OBJS) $(LINK_LIBS)
+	    -o $(basename $@)$(EXEEXT) $(LINK_OBJS) $(LINK_LIBS)
 endef
 define bsp-link-cxx
 	$(LINK.cc) $(CPU_CFLAGS) $(AM_CFLAGS) $(AM_LDFLAGS) \
 endef
 define default-bsp-post-link
@@ -102,7 +99,7 @@ endef
 ifndef bsp-post-link
 endef
 endif
____
Nick Withers
Embedded Systems Programmer
Room 2.26, Building 57
Department of Nuclear Physics
Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
eMail: nick.withers at anu.edu.au
Phone: +61 2 6125 2091
Mobile: +61 414 397 446
