[PATCH 1/4] Add libmm score changes
Hesham AL-Matary heshamelmatary at gmail.com
Sat Jul 13 23:05:18 UTC 2013
From: Hesham ALmatary <heshamelmatary at gmail.com>
 cpukit/score/Makefile.am               |  2 +
 cpukit/score/include/rtems/score/mm.h  | 67 ++++++++++++++++++++++++++++
 cpukit/score/inline/rtems/score/mm.inl | 80 ++++++++++++++++++++++++++++++++++
 cpukit/score/preinstall.am             |  8 ++++
 4 files changed, 157 insertions(+)
 create mode 100644 cpukit/score/include/rtems/score/mm.h
 create mode 100644 cpukit/score/inline/rtems/score/mm.inl
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 3f6e686..58a865b 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -30,6 +30,7 @@ include_rtems_score_HEADERS += include/rtems/score/protectedheap.h
 include_rtems_score_HEADERS += include/rtems/score/interr.h
 include_rtems_score_HEADERS += include/rtems/score/isr.h
 include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
+include_rtems_score_HEADERS += include/rtems/score/mm.h
 include_rtems_score_HEADERS += include/rtems/score/object.h
 include_rtems_score_HEADERS += include/rtems/score/percpu.h
 include_rtems_score_HEADERS += include/rtems/score/priority.h
@@ -90,6 +91,7 @@ include_rtems_score_HEADERS += inline/rtems/score/coremutex.inl
 include_rtems_score_HEADERS += inline/rtems/score/coresem.inl
 include_rtems_score_HEADERS += inline/rtems/score/heap.inl
 include_rtems_score_HEADERS += inline/rtems/score/isr.inl
+include_rtems_score_HEADERS += inline/rtems/score/mm.inl
 include_rtems_score_HEADERS += inline/rtems/score/object.inl
 include_rtems_score_HEADERS += inline/rtems/score/priority.inl
 include_rtems_score_HEADERS += inline/rtems/score/prioritybitmap.inl
diff --git a/cpukit/score/include/rtems/score/mm.h b/cpukit/score/include/rtems/score/mm.h
new file mode 100644
index 0000000..6163be6
--- /dev/null
+++ b/cpukit/score/include/rtems/score/mm.h
@@ -0,0 +1,67 @@
+ * @file
+ * @brief Manages use of MPU/MMU units to provide memory management.
+ * Copyright (c) 2013 Hesham Al-Matary.
+ * Copyright (c) 2013 Gedare Bloom.
+ * http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_SCORE_MM_H
+#define _RTEMS_SCORE_MM_H
+/* @defgroup SuperCoreMM Memory Management Support
+ * @ingroup Score
+#include <inttypes.h>
+#ifdef RTEMS_SMP
+#include <rtems/score/smplock.h>
+#endif
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @brief _Memory_management_Region Flags defs
+#define RTEMS_MM_REGION_PROTECTION_READ_ONLY   0x1
+#define RTEMS_MM_REGION_PROTECTION_WRITE  0x2
+//#define RTEMS_MM_REGION_PROTECTION_EXEC   0x4
+ * @brief A managed _Memory_management_Region.
+typedef struct {
+  char *name;
+  uintptr_t base;
+  size_t size;
+  bool installed;
+  /* points to structure defining the BSP specific MM entry */
+  void *bsp_mme;
+} Memory_management_Entry;
+#ifdef RTEMS_SMP
+SMP_lock_Control mm_lock;
+#endif
+#ifndef __RTEMS_APPLICATION__
+#include <rtems/score/mm.inl>
+#endif
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/score/inline/rtems/score/mm.inl b/cpukit/score/inline/rtems/score/mm.inl
index 0000000..07b1dd7
--- /dev/null
+++ b/cpukit/score/inline/rtems/score/mm.inl
@@ -0,0 +1,80 @@
+ * @file
+ * @brief Inlined Routines from the Memory Management Manager
+ * Copyright (c) 2013 Hesham AL-Matary
+# error "Never use <rtems/score/mm.inl> directly; include <rtems/score/mm.h> instead."
+#endif
+#ifndef _RTEMS_SCORE_MM_INL
+#define _RTEMS_SCORE_MM_INL
+ * @addtogroup SuperCoreMM
+ * @brief Calls _CPU_Memory_management_Initialize.
+RTEMS_INLINE_ROUTINE void _Memory_management_Initialize( void )
+#ifdef RTEMS_SMP
+   _SMP_lock_Initialize( &mm_lock );
+#endif
+  _CPU_Memory_management_Initialize();
+ * @brief Calls _CPU_Memory_management_Install_entry.
+RTEMS_INLINE_ROUTINE void _Memory_management_Install_entry(
+  Memory_management_Entry *mme,
+  uint32_t attr
+#ifdef RTEMS_SMP
+  _SMP_lock_Acquire( &mm_lock );
+#endif
+  _CPU_Memory_management_Install_entry(mme, attr);
+#ifdef RTEMS_SMP
+  _SMP_lock_Release( &mm_lock );
+#endif
+ * @brief Calls _CPU_Memory_management_Uninstall_entry.
+RTEMS_INLINE_ROUTINE void _Memory_management_Uninstall_entry(
+#ifdef RTEMS_SMP
+#endif
+  _CPU_Memory_management_Uninstall_entry(mme);
+#ifdef RTEMS_SMP
+#endif
+#endif
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index dc84b21..100f090 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -103,6 +103,10 @@ $(PROJECT_INCLUDE)/rtems/score/isrlevel.h: include/rtems/score/isrlevel.h $(PROJ
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isrlevel.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isrlevel.h
+$(PROJECT_INCLUDE)/rtems/score/mm.h: include/rtems/score/mm.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mm.h
 $(PROJECT_INCLUDE)/rtems/score/object.h: include/rtems/score/object.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/object.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/object.h
@@ -298,6 +302,10 @@ $(PROJECT_INCLUDE)/rtems/score/isr.inl: inline/rtems/score/isr.inl $(PROJECT_INC
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isr.inl
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isr.inl
+$(PROJECT_INCLUDE)/rtems/score/mm.inl: inline/rtems/score/mm.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mm.inl
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mm.inl
 $(PROJECT_INCLUDE)/rtems/score/object.inl: inline/rtems/score/object.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/object.inl
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/object.inl
1.8.3.1
