[rtems commit] Return the amount of data written when an error occurs rather than
Sat Jul 27 14:30:43 UTC 2013
Chris (and everyone else), let us try to keep the first line of commit
messages brief so they fit on the first line. This makes reading the
"short log" and email subjects much easier.
-Gedare
On Sat, Jul 27, 2013 at 9:52 AM, Chris Johns <chrisj at rtems.org> wrote:
> Module:    rtems
> Branch:    master
> Commit:    681f198539eb42616de5ba8919034f86863926c5
> Changeset: http://git.rtems.org/rtems/commit/?id=681f198539eb42616de5ba8919034f86863926c5
> Author:    Chris Johns <chrisj at rtems.org>
> Date:      Sat Jul 27 23:57:05 2013 +1000
> the error.
> The change lets the mrfs_fsrdwr test pass.
>  cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c |   12 +++++++++---
>  1 files changed, 9 insertions(+), 3 deletions(-)
> diff --git a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> index 7f2968c..a811ee5 100644
> --- a/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> +++ b/cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
> @@ -3,7 +3,7 @@
>   * @brief RTEMS RFS File Handlers
>   * @ingroup rtems_rfs
>   * This file contains the set of handlers used to process operations on
>   * RFS file nodes.
> @@ -55,7 +55,7 @@ rtems_rfs_rtems_file_open (rtems_libio_t* iop,
>    if (rtems_rfs_rtems_trace (RTEMS_RFS_RTEMS_DEBUG_FILE_OPEN))
>      printf("rtems-rfs: file-open: path:%s ino:%" PRId32 " flags:%04i mode:%04" PRIu32 "\n",
> -           pathname, ino, flags, mode);
> +           pathname, ino, flags, (uint32_t) mode);
>    rtems_rfs_rtems_lock (fs);
> @@ -233,7 +233,13 @@ rtems_rfs_rtems_file_write (rtems_libio_t* iop,
>      rc = rtems_rfs_file_io_start (file, &size, false);
>      if (rc)
> -      write = rtems_rfs_rtems_error ("file-write: write open", rc);
> +       * If we have run out of space and have written some data return that
> +       * amount first as the inode will have accounted for it. This means
> +       * there was no error and the return code from can be ignored.
> +      if (!write)
> +        write = rtems_rfs_rtems_error ("file-write: write open", rc);
>        break;
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
