RTEMS_GDB clarification
Dhananjay Balan mb.dhananjay at gmail.com
Fri Jun 28 18:01:39 UTC 2013
Hi,
Need help with a code snippet. I cannot understand the need for
"nesting" in the following.
> rtems.py line 33-47
> def lookup_function (val):
>     "Look-up and return a pretty-printer that can print val."
>     global nesting
>     typename = str(type_from_value(val))
>     for function in pp_dict:
>         if function.search (typename):
>             nesting += 1
>             result = pp_dict[function] (val)
>             nesting -= 1
>             if nesting == 0:
>                 objects.information.invalidate()
>             return result
Thanks,
Dhananjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130628/57ab8e03/attachment.html>
