[PATCH] RTL: Fix options handle and add a new option to rtems-ld
Peng Fan van.freenix at gmail.com
Sun Aug 10 14:24:19 UTC 2014
Hi,
1. Fix getopt_long usage in rtl host. some shorthand options are not
hanlded correctly, this patch fixes it.
2. Add a new option '--mach-flags'/'-m' to rtems-ld. This optarg of this
option will be passed to xx-rtemsxx-gcc, it will be used the search lib
dirs. Detailed msg is in the commit log of the patch.
Regards,
Peng.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140810/df2d489a/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140810/df2d489a/attachment.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140810/df2d489a/attachment-0001.obj>
