smp test failures on using grsim
Tue Feb 4 13:50:34 UTC 2014
Hello Jennifer,
I executed the tests on a real NGMP evaluation board.  All tests run
successfully.  See attached log file.
What do you mean with "Locks"?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
[sys]      SESSION: Tue Feb  4 14:40:13 2014
[sys]      GRMON version: v2.0.46 pro version
[sys]      ID: 62402177 (hl)
[sys]      OS: Linux
[sys]      Command line: grmon -usb -u -log log.txt -c run-smptests.grmon
[sys]      GRMON2 LEON debug monitor v2.0.46 pro version
[sys]      Copyright (C) 2013 Aeroflex Gaisler - All rights reserved.
[sys]      For latest updates, go to http://www.gaisler.com/
[sys]      Comments or bug-reports to support at gaisler.com
[usr1]     Detected system:     NGMP FP
[usr1]     Detected frequency:  200 MHz
[term1]    Found 4 CPUs
[term1]    Waking CPU 1
[term1]    CPU 1 is online
[term1]    Waking CPU 2
[term1]    CPU 2 is online
[term1]    Waking CPU 3
[term1]    CPU 3 is online
[term1]    ***  SMP01 TEST ***
[term1]     CPU 3 start task TA0
[term1]     CPU 2 running Task TA0
[term1]     CPU 3 start task TA1
[term1]     CPU 1 running Task TA1
[term1]     CPU 3 start task TA2
[term1]     CPU 0 running Task TA2
[term1]    *** END OF TEST SMP01 ***
[usr1]     CPU 0:  Unknown watchpoint hit
[usr1]             0x0000b4a4: 30800000  ba,a  0x0000B4A4  <rtems_smp_process_interrupt+172>
[usr1]     CPU 1:  Unknown watchpoint hit
[usr1]     CPU 2:  Unknown watchpoint hit
[usr1]     CPU 3:  Program exited normally.
[usr1]     00000000 .text                        0B              [>               ]   0%
[usr1]     00000000 .text                    124.5kB / 124.5kB   [===============>] 100%
[usr1]     0001F1F0 .data                        0B              [>               ]   0%
[usr1]     0001F1F0 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 125.97kB (30.35Mbit/s)
[usr1]     Entry point 0x0
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smp02/smp02.exe loaded
[term1]    ***  SMP02 TEST ***
[term1]     CPU 3 start task TA3
[term1]     CPU 0 Task TA4 Obtain
[term1]     CPU 0 Task TA4 Release
[term1]     CPU 1 Task TA3 Obtain
[term1]     CPU 1 Task TA3 Release
[term1]     CPU 2 Task TA2 Obtain
[term1]     CPU 2 Task TA2 Release
[term1]    *** END OF TEST SMP02 ***
[usr1]             0x0000b3a4: 30800000  ba,a  0x0000B3A4  <rtems_smp_process_interrupt+172>
[usr1]     00000000 .text                    139.3kB / 139.3kB   [===============>] 100%
[usr1]     00022D20 .data                        0B              [>               ]   0%
[usr1]     00022D20 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 140.77kB (31.17Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smp03/smp03.exe loaded
[term1]    ***  SMP03 TEST ***
[term1]      CPU 3 running task Init
[term1]      CPU 2 running task TA1
[term1]      CPU 1 running task TA2
[term1]      CPU 0 running task TA3
[term1]      CPU 0 running task TA4
[term1]    *** END OF TEST SMP03 ***
[usr1]             0x0000b1c4: 30800000  ba,a  0x0000B1C4  <rtems_smp_process_interrupt+172>
[usr1]     00000000 .text                    123.9kB / 123.9kB   [===============>] 100%
[usr1]     0001EF90 .data                        0B              [>               ]   0%
[usr1]     0001EF90 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 125.38kB (31.12Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smp05/smp05.exe loaded
[term1]    4 CPUs IS MORE THAN CONFIGURED -- ONLY USING 2
[term1]    *** TEST SMP05 ***
[term1]     CPU 1 start task TA1
[term1]    Shut down from CPU 0
[term1]     CPU 1 start task TA2
[term1]    *** END OF TEST SMP05 ***
[usr1]     CPU 0:  Program exited normally.
[usr1]             0x0000b19c: 30800000  ba,a  0x0000B19C  <rtems_smp_process_interrupt+172>
[usr1]     CPU 2:  Power down mode
[usr1]     CPU 3:  Power down mode
[usr1]     00000000 .text                    127.0kB / 127.0kB   [===============>] 100%
[usr1]     0001FC30 .data                        0B              [>               ]   0%
[usr1]     0001FC30 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 128.55kB (27.71Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smp07/smp07.exe loaded
[term1]    *** TEST SMP07 ***
[term1]     CPU 1 create and start timer
[term1]     CPU 0 runnng Task TA1  and blocking
[term1]     CPU 0 running Task TA1  after semaphore release
[term1]    *** END OF TEST SMP07 ***
[usr1]             0x0000baf4: 30800000  ba,a  0x0000BAF4  <rtems_smp_process_interrupt+172>
[usr1]     CPU 1:  Program exited normally.
[usr1]     00000000 .text                    145.8kB / 145.8kB   [===============>] 100%
[usr1]     00024730 .data                        0B              [>               ]   0%
[usr1]     00024730 .data                      1.6kB /   1.6kB   [===============>] 100%
[usr1]     Total size: 147.38kB (30.18Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smp08/smp08.exe loaded
[term1]    *** SMP08 TEST ***
[term1]      CPU 3 running task Init - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 2 running task TA01 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 3 running task TA12 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 0 running task TA03 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 1 running task TA02 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 2 running task TA11 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 3 running task TA10 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 0 running task TA09 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 1 running task TA08 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 2 running task TA07 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 3 running task TA06 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 0 running task TA05 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 1 running task TA04 - rtems_clock_get_tod 09:00:00   12/31/1988
[term1]      CPU 1 running task TA01 - rtems_clock_get_tod 09:00:05   12/31/1988
[term1]      CPU 1 running task TA01 - rtems_clock_get_tod 09:00:10   12/31/1988
[term1]      CPU 1 running task TA02 - rtems_clock_get_tod 09:00:10   12/31/1988
[term1]      CPU 1 running task TA01 - rtems_clock_get_tod 09:00:15   12/31/1988
[term1]      CPU 0 running task TA03 - rtems_clock_get_tod 09:00:15   12/31/1988
[term1]      CPU 0 running task TA01 - rtems_clock_get_tod 09:00:20   12/31/1988
[term1]      CPU 0 running task TA02 - rtems_clock_get_tod 09:00:20   12/31/1988
[term1]      CPU 0 running task TA04 - rtems_clock_get_tod 09:00:20   12/31/1988
[term1]      CPU 0 running task TA01 - rtems_clock_get_tod 09:00:25   12/31/1988
[term1]      CPU 0 running task TA05 - rtems_clock_get_tod 09:00:25   12/31/1988
[term1]      CPU 0 running task TA03 - rtems_clock_get_tod 09:00:30   12/31/1988
[term1]      CPU 0 running task TA01 - rtems_clock_get_tod 09:00:30   12/31/1988
[term1]      CPU 1 running task TA02 - rtems_clock_get_tod 09:00:30   12/31/1988
[term1]      CPU 1 running task TA06 - rtems_clock_get_tod 09:00:30   12/31/1988
[term1]    *** END OF SMP08 TEST ***
[usr1]             0x0000be24: 30800000  ba,a  0x0000BE24  <rtems_smp_process_interrupt+172>
[usr1]     CPU 3:  Unknown watchpoint hit
[usr1]     00000000 .text                    126.8kB / 126.8kB   [===============>] 100%
[usr1]     0001FB60 .data                        0B              [>               ]   0%
[usr1]     0001FB60 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 128.34kB (30.92Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smp09/smp09.exe loaded
[term1]    *** TEST SMP09 ***
[term1]     kill 10 clock ticks
[term1]    -------------------------------------------------------------------------------
[term1]                                  CPU USAGE BY THREAD
[term1]    ------------+----------------------------------------+---------------+---------
[term1]     ID         | NAME                                   | SECONDS       | PERCENT
[term1]     0x09010001 | IDLE                                   |      0.369261 |  60.640
[term1]     0x09010002 | IDLE                                   |      0.356773 |  54.620
[term1]     0x09010003 | IDLE                                   |      0.341779 |  49.084
[term1]     0x09010004 | IDLE                                   |      0.000000 |   0.000
[term1]     0x0A010001 | UI1                                    |      0.781313 | 100.000
[term1]     0x0A010002 | TA1                                    |      0.481774 |  58.499
[term1]     0x0A010003 | TA2                                    |      0.506908 |  58.691
[term1]     0x0A010004 | TA3                                    |      0.536411 |  59.227
[term1]     TIME SINCE LAST CPU USAGE RESET IN SECONDS:                          0.905672
[term1]    *** END OF TEST SMP09 ***
[usr1]             0x0000b8bc: 30800000  ba,a  0x0000B8BC  <rtems_smp_process_interrupt+172>
[usr1]     00000000 .text                    102.7kB / 102.7kB   [===============>] 100%
[usr1]     00019AC0 .data                        0B              [>               ]   0%
[usr1]     00019AC0 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 104.16kB (29.42Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smpatomic01/smpatomic01.exe loaded
[term1]    *** TEST SMPATOMIC 1 ***
[term1]    === atomic simple add test case ==
[term1]    === atomic simple sub test case ==
[term1]    === atomic simple or test case ==
[term1]    === atomic simple and test case ==
[term1]    === atomic simple exchange test case ==
[term1]    === atomic simple compare exchange test case ==
[term1]    === static and dynamic initialization test case ===
[term1]    === atomic add test case ==
[term1]    worker 0 value: 486600
[term1]    worker 1 value: 1
[term1]    worker 2 value: 1
[term1]    worker 3 value: 1
[term1]    atomic value: expected = 486603, actual = 486603
[term1]    === atomic flag test case ==
[term1]    worker 0 value: 122908
[term1]    worker 1 value: 47533
[term1]    worker 2 value: 2
[term1]    worker 3 value: 2
[term1]    atomic value: expected = 170445, actual = 170445
[term1]    === atomic sub test case ==
[term1]    worker 0 value: 4294479753
[term1]    worker 1 value: 4294967295
[term1]    worker 2 value: 4294967295
[term1]    worker 3 value: 4294967295
[term1]    atomic value: expected = 4294479750, actual = 4294479750
[term1]    === atomic compare exchange test case ==
[term1]    worker 0 value: 33823
[term1]    worker 1 value: 33969
[term1]    worker 2 value: 34042
[term1]    worker 3 value: 33773
[term1]    atomic value: expected = 135607, actual = 135607
[term1]    === atomic or/and test case ==
[term1]    worker 0 value: 0
[term1]    worker 1 value: 2
[term1]    worker 2 value: 0
[term1]    worker 3 value: 8
[term1]    atomic value: expected = 10, actual = 10
[term1]    *** END OF TEST SMPATOMIC 1 ***
[usr1]             0x0000c248: 30800000  ba,a  0x0000C248  <rtems_smp_process_interrupt+172>
[usr1]     00000000 .text                     99.8kB /  99.8kB   [===============>] 100%
[usr1]     00018F50 .data                        0B              [>               ]   0%
[usr1]     00018F50 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 101.30kB (30.73Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smplock01/smplock01.exe loaded
[term1]    *** TEST SMPLOCK 1 ***
[term1]    aquire global lock with local counter
[term1]            processor 0, local counter 766105
[term1]            processor 1, local counter 2777203
[term1]            processor 2, local counter 1
[term1]            processor 3, local counter 1
[term1]            global counter 0, sum of local counter 3543310
[term1]    aquire global lock with global counter
[term1]            processor 0, local counter 559922
[term1]            processor 1, local counter 663370
[term1]            processor 2, local counter 197713
[term1]            processor 3, local counter 201572
[term1]            global counter 1622577, sum of local counter 1622577
[term1]    aquire local lock with local counter
[term1]            processor 0, local counter 2356340
[term1]            processor 1, local counter 2369516
[term1]            processor 2, local counter 2369516
[term1]            processor 3, local counter 2369517
[term1]            global counter 0, sum of local counter 9464889
[term1]    aquire local lock with global counter
[term1]            processor 0, local counter 1400562
[term1]            processor 1, local counter 1407628
[term1]            processor 2, local counter 1407627
[term1]            processor 3, local counter 1407628
[term1]            global counter 2726585, sum of local counter 5623445
[term1]    aquire global lock with busy section
[term1]            processor 0, local counter 509770
[term1]            processor 1, local counter 514650
[term1]            processor 2, local counter 510752
[term1]            processor 3, local counter 511129
[term1]            global counter 0, sum of local counter 2046301
[term1]    *** END OF TEST SMPLOCK 1 ***
[usr1]             0x0000ba78: 30800000  ba,a  0x0000BA78  <rtems_smp_process_interrupt+172>
[usr1]     00000000 .text                     98.6kB /  98.6kB   [===============>] 100%
[usr1]     00018A90 .data                        0B              [>               ]   0%
[usr1]     00018A90 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 100.11kB (22.78Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smpmigration01/smpmigration01.exe loaded
[term1]    *** TEST SMPMIGRATION 1 ***
[term1]    runner 0
[term1]            cpu 0 tokens 31607
[term1]            cpu 0 cycles 126485
[term1]            cpu 1 tokens 31607
[term1]            cpu 1 cycles 132749
[term1]    runner 1
[term1]            cpu 0 cycles 126425
[term1]            cpu 1 cycles 131618
[term1]    runner 2
[term1]            cpu 0 cycles 126428
[term1]            cpu 1 cycles 131868
[term1]    *** END OF TEST SMPMIGRATION 1 ***
[usr1]             0x0000b67c: 30800000  ba,a  0x0000B67C  <rtems_smp_process_interrupt+172>
[usr1]     00000000 .text                    102.6kB / 102.6kB   [===============>] 100%
[usr1]     00019A70 .data                        0B              [>               ]   0%
[usr1]     00019A70 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 104.06kB (31.57Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smppsxsignal01/smppsxsignal01.exe loaded
[term1]    *** TEST SMPPSXSIGNAL 1 ***
[term1]    *** END OF TEST SMPPSXSIGNAL 1 ***
[usr1]             0x0000c160: 30800000  ba,a  0x0000C160  <rtems_smp_process_interrupt+172>
[usr1]     00000000 .text                     98.9kB /  98.9kB   [===============>] 100%
[usr1]     00018B70 .data                        0B              [>               ]   0%
[usr1]     00018B70 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 100.33kB (32.88Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smpschedule01/smpschedule01.exe loaded
[term1]    *** TEST SMPSCHEDULE 1 ***
[term1]    *** END OF TEST SMPSCHEDULE 1 ***
[usr1]             0x0000b7a4: 30800000  ba,a  0x0000B7A4  <rtems_smp_process_interrupt+172>
[usr1]     00000000 .text                    100.1kB / 100.1kB   [===============>] 100%
[usr1]     00019070 .data                        0B              [>               ]   0%
[usr1]     00019070 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 101.58kB (30.82Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smpsignal01/smpsignal01.exe loaded
[term1]    *** TEST SMPSIGNAL 1 ***
[term1]    *** END OF TEST SMPSIGNAL 1 ***
[usr1]             0x0000bc18: 30800000  ba,a  0x0000BC18  <rtems_smp_process_interrupt+172>
[usr1]     00000000 .text                     99.1kB /  99.1kB   [===============>] 100%
[usr1]     00018C50 .data                        0B              [>               ]   0%
[usr1]     00018C50 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 100.55kB (30.51Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smpswitchextension01/smpswitchextension01.exe loaded
[term1]    *** TEST SMPSWITCHEXTENSION 1 ***
[term1]    toggler 0
[term1]            toggles 125898
[term1]    toggler 1
[term1]            toggles 125897
[term1]    extension 0
[term1]            context switches 125899
[term1]    extension 1
[term1]            context switches 125898
[term1]    extension 2
[term1]    extension switches 41967
[term1]    *** END OF TEST SMPSWITCHEXTENSION 1 ***
[usr1]             0x0000b710: 30800000  ba,a  0x0000B710  <rtems_smp_process_interrupt+172>
[usr1]     00018F00 .data                        0B              [>               ]   0%
[usr1]     00018F00 .data                      1.5kB /   1.5kB   [===============>] 100%
[usr1]     Total size: 101.22kB (29.61Mbit/s)
[usr1]     Image /scratch/git-build/b-smp-ngmp/sparc-rtems4.11/c/ngmp/testsuites/smptests/smpunsupported01/smpunsupported01.exe loaded
[term1]    4 CPUs IS MORE THAN CONFIGURED -- ONLY USING 1
[term1]    *** TEST SMPUNSUPPORTED 1 ***
[term1]    *** END OF TEST SMPUNSUPPORTED 1 ***
[usr1]     CPU 1:  Power down mode
