[PATCH 1/2] psxtests: move pthread_once tests into an extra test.
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Mar 18 15:25:33 UTC 2014
From: Christian Mauderer <Christian.Mauderer at embedded-brains.de>
 testsuites/psxtests/Makefile.am             |  3 ++
 testsuites/psxtests/configure.ac            |  1 +
 testsuites/psxtests/psx01/init.c            | 17 --------
 testsuites/psxtests/psx01/psx01.doc         |  3 --
 testsuites/psxtests/psx01/psx01.scn         |  5 ---
 testsuites/psxtests/psx01/task.c            | 19 --------
 testsuites/psxtests/psxonce01/Makefile.am   | 22 ++++++++++
 testsuites/psxtests/psxonce01/init.c        | 68 +++++++++++++++++++++++++++++
 testsuites/psxtests/psxonce01/psxonce01.doc | 19 ++++++++
 testsuites/psxtests/psxonce01/psxonce01.scn | 11 +++++
 testsuites/psxtests/psxonce01/system.h      | 28 ++++++++++++
 11 files changed, 152 insertions(+), 44 deletions(-)
 create mode 100644 testsuites/psxtests/psxonce01/Makefile.am
 create mode 100644 testsuites/psxtests/psxonce01/init.c
 create mode 100644 testsuites/psxtests/psxonce01/psxonce01.doc
 create mode 100644 testsuites/psxtests/psxonce01/psxonce01.scn
 create mode 100644 testsuites/psxtests/psxonce01/system.h
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index fd4ceac..172599b 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -30,6 +30,9 @@ if HAS_POSIX
 SUBDIRS += psxkey07
 endif
+## POSIX Once is always available
+SUBDIRS += psxonce01
 SUBDIRS += psxrdwrv
 include $(top_srcdir)/../automake/subdirs.am
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index a7b3312..26e4b60 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -168,6 +168,7 @@ psxmsgq03/Makefile
 psxmsgq04/Makefile
 psxmutexattr01/Makefile
 psxobj01/Makefile
+psxonce01/Makefile
 psxpasswd01/Makefile
 psxpasswd02/Makefile
 psxpipe01/Makefile
diff --git a/testsuites/psxtests/psx01/init.c b/testsuites/psxtests/psx01/init.c
index 1d1a9e8..59605b4 100644
--- a/testsuites/psxtests/psx01/init.c
+++ b/testsuites/psxtests/psx01/init.c
@@ -20,18 +20,6 @@
-pthread_once_t nesting_once = PTHREAD_ONCE_INIT;
-void Test_init_routine_nesting( void );
-  int status;
-  puts( "Test_init_routine_nesting: invoked" );
-  status = pthread_once( &nesting_once, Test_init_routine_nesting );
-  rtems_test_assert( status == EINVAL );
 void *POSIX_Init(
   void *argument
@@ -107,11 +95,6 @@ void *POSIX_Init(
   rtems_test_assert( !status );
-  /* once nesting */
-  puts( "Init: pthread_once - SUCCESSFUL (init_routine_nesting executes)" );
-  rtems_test_assert( !status );
   /* create a thread */
   puts( "Init: pthread_create - SUCCESSFUL" );
diff --git a/testsuites/psxtests/psx01/psx01.doc b/testsuites/psxtests/psx01/psx01.doc
index 60cff7c..7766de3 100644
--- a/testsuites/psxtests/psx01/psx01.doc
+++ b/testsuites/psxtests/psx01/psx01.doc
@@ -14,7 +14,6 @@ test set name: psx01
 directives:
   pthread_create
   pthread_equal
-  pthread_once
   sched_get_priority_min
   sched_get_priority_max
   sched_rr_get_interval
@@ -32,5 +31,3 @@ concepts:
 + Verify that thread yielding is operational
 + Verify that pthread_equal works as expected for different combinations of
   legitimate and illegitimate thread id’s
-+ Verify that pthread_once works as expected for different combinations of
-  legitimate and illegitimate thread initiations
diff --git a/testsuites/psxtests/psx01/psx01.scn b/testsuites/psxtests/psx01/psx01.scn
index b187dc9..5811744 100644
--- a/testsuites/psxtests/psx01/psx01.scn
+++ b/testsuites/psxtests/psx01/psx01.scn
@@ -27,9 +27,4 @@ Task_1: pthread_equal - match case passed
 Task_1: pthread_equal - different case passed
 Task_1: pthread_equal - first id bad
 Task_1: pthread_equal - second id bad
-Task_1: pthread_once - EINVAL (NULL once_control)
-Task_1: pthread_once - EINVAL (NULL init_routine)
-Task_1: pthread_once - SUCCESSFUL (init_routine executes)
-Test_init_routine: invoked
-Task_1: pthread_once - SUCCESSFUL (init_routine does not execute)
 *** END OF POSIX TEST 1 ***
diff --git a/testsuites/psxtests/psx01/task.c b/testsuites/psxtests/psx01/task.c
index f7abd5c..e97b039 100644
--- a/testsuites/psxtests/psx01/task.c
+++ b/testsuites/psxtests/psx01/task.c
@@ -35,7 +35,6 @@ void *Task_1_through_3(
   int            status;
-  pthread_once_t once = PTHREAD_ONCE_INIT;
   puts( "Task_1: sched_yield to Init" );
   status = sched_yield();
@@ -72,24 +71,6 @@ void *Task_1_through_3(
   status = pthread_equal( Init_id, (pthread_t) -1 );
-  /* exercise pthread_once */
-  puts( "Task_1: pthread_once - EINVAL (NULL once_control)" );
-  status = pthread_once( NULL, Test_init_routine );
-  puts( "Task_1: pthread_once - EINVAL (NULL init_routine)" );
-  status = pthread_once( &once, NULL );
-  puts( "Task_1: pthread_once - SUCCESSFUL (init_routine executes)" );
-  status = pthread_once( &once, Test_init_routine );
-  puts( "Task_1: pthread_once - SUCCESSFUL (init_routine does not execute)" );
   puts( "*** END OF POSIX TEST 1 ***" );
   rtems_test_exit( 0 );
diff --git a/testsuites/psxtests/psxonce01/Makefile.am b/testsuites/psxtests/psxonce01/Makefile.am
new file mode 100644
index 0000000..bb11fe1
--- /dev/null
+++ b/testsuites/psxtests/psxonce01/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxonce01
+psxonce01_SOURCES = init.c system.h ../include/pmacros.h
+dist_rtems_tests_DATA = psxonce01.scn
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/include
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(psxonce01_OBJECTS)
+LINK_LIBS = $(psxonce01_LDLIBS)
+psxonce01$(EXEEXT): $(psxonce01_OBJECTS) $(psxonce01_DEPENDENCIES)
+	@rm -f psxonce01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxonce01/init.c b/testsuites/psxtests/psxonce01/init.c
index 0000000..6fd6579
--- /dev/null
+++ b/testsuites/psxtests/psxonce01/init.c
@@ -0,0 +1,68 @@
+ *  COPYRIGHT (c) 1989-2009.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+pthread_once_t nesting_once = PTHREAD_ONCE_INIT;
+void Test_init_routine_nesting( void );
+  int status;
+  puts( "Test_init_routine_nesting: invoked" );
+  status = pthread_once( &nesting_once, Test_init_routine_nesting );
+  rtems_test_assert( status == EINVAL );
+void Test_init_routine( void );
+  puts( "Test_init_routine: invoked" );
+rtems_task Init(rtems_task_argument argument)
+  int status;
+  pthread_once_t once = PTHREAD_ONCE_INIT;
+  puts( "\n\n*** TEST POSIX ONCE 01 ***" );
+  /* once nesting */
+  puts( "Init: pthread_once - SUCCESSFUL (init_routine_nesting executes)" );
+  rtems_test_assert( !status );
+  /* exercise pthread_once */
+  puts( "Init: pthread_once - EINVAL (NULL once_control)" );
+  status = pthread_once( NULL, Test_init_routine );
+  puts( "Init: pthread_once - EINVAL (NULL init_routine)" );
+  status = pthread_once( &once, NULL );
+  puts( "Init: pthread_once - SUCCESSFUL (init_routine executes)" );
+  status = pthread_once( &once, Test_init_routine );
+  puts( "Init: pthread_once - SUCCESSFUL (init_routine does not execute)" );
+  puts( "*** END OF TEST POSIX ONCE 01 ***" );
+  rtems_test_exit( 0 );
diff --git a/testsuites/psxtests/psxonce01/psxonce01.doc b/testsuites/psxtests/psxonce01/psxonce01.doc
index 0000000..10bae5b
--- /dev/null
+++ b/testsuites/psxtests/psxonce01/psxonce01.doc
@@ -0,0 +1,19 @@
+#  COPYRIGHT (c) 1989-2009.
+#  On-Line Applications Research Corporation (OAR).
+#  Copyright (c) 2013 Annelies Odermann <annelies.odermann at gmail.com>
+#  Copyright (c) 2014 embedded brains GmbH.
+#  The license and distribution terms for this file may be
+#  found in the file LICENSE in this distribution or at
+#  http://www.rtems.com/license/LICENSE.
+This file describes the directives and concepts tested by this test set.
+test set name: psxonce01
+directives:
+  pthread_once
+concepts:
++ Verify that pthread_once works as expected for different combinations of
+  legitimate and illegitimate thread initiations
diff --git a/testsuites/psxtests/psxonce01/psxonce01.scn b/testsuites/psxtests/psxonce01/psxonce01.scn
index 0000000..2c5d47d
--- /dev/null
+++ b/testsuites/psxtests/psxonce01/psxonce01.scn
@@ -0,0 +1,11 @@
+*** TEST POSIX ONCE 01 ***
+Init: pthread_once - SUCCESSFUL (init_routine_nesting executes)
+Test_init_routine_nesting: invoked
+Init: pthread_once - EINVAL (NULL once_control)
+Init: pthread_once - EINVAL (NULL init_routine)
+Init: pthread_once - SUCCESSFUL (init_routine executes)
+Test_init_routine: invoked
+Init: pthread_once - SUCCESSFUL (init_routine does not execute)
+*** END OF TEST POSIX ONCE 01 ***
diff --git a/testsuites/psxtests/psxonce01/system.h b/testsuites/psxtests/psxonce01/system.h
index 0000000..1e230eb
--- /dev/null
+++ b/testsuites/psxtests/psxonce01/system.h
@@ -0,0 +1,28 @@
+/*  system.h
+ *  This include file contains information that is included in every
+ *  function in the test set.
+ *  COPYRIGHT (c) 1989-1999.
+/* functions */
+#include <pmacros.h>
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
+/* end of include file */
1.8.4.5
