[PATCH] score: PR788: Add INTERNAL_ERROR_RESOURCE_IN_USE
Fri Mar 28 13:10:45 UTC 2014
Issue a fatal error in case a thread is deleted which still owns
resources (e.g. a binary semaphore with priority inheritance or ceiling
protocol).  The resource count must be checked quite late since RTEMS
task variable destructors, POSIX key destructors and POSIX cleanup
handler may release resources.  In this context it would be quite
difficult to return an error status to the caller.
An alternative would be to place threads with a non-zero resource count
not on the zombie chain.  Thus we have a resource leak instead of a
fatal error.  The terminator thread can see this error if we return an
RTEMS_RESOURCE_IN_USE status for the rtems_task_delete() for example.
 cpukit/sapi/src/interrtext.c                |    3 +-
 cpukit/score/include/rtems/score/interr.h   |    3 +-
 cpukit/score/src/threadrestart.c            |    8 ++++
 testsuites/sptests/Makefile.am              |    1 +
 testsuites/sptests/configure.ac             |    1 +
 testsuites/sptests/spfatal28/Makefile.am    |   19 ++++++++++
 testsuites/sptests/spfatal28/init.c         |   50 +++++++++++++++++++++++++++
 testsuites/sptests/spfatal28/spfatal28.doc  |   12 ++++++
 testsuites/sptests/spfatal28/spfatal28.scn  |    3 ++
 testsuites/sptests/spfatal28/testcase.h     |   39 +++++++++++++++++++++
 testsuites/sptests/spinternalerror02/init.c |    2 +-
 11 files changed, 138 insertions(+), 3 deletions(-)
 create mode 100644 testsuites/sptests/spfatal28/Makefile.am
 create mode 100644 testsuites/sptests/spfatal28/init.c
 create mode 100644 testsuites/sptests/spfatal28/spfatal28.doc
 create mode 100644 testsuites/sptests/spfatal28/spfatal28.scn
 create mode 100644 testsuites/sptests/spfatal28/testcase.h
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index a18610c..e08414b 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -51,7 +51,8 @@ static const char *const internal_error_text[] = {
   "INTERNAL_ERROR_GXX_KEY_ADD_FAILED",
   "INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED",
   "INTERNAL_ERROR_NO_MEMORY_FOR_HEAP",
-  "INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR"
+  "INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR",
+  "INTERNAL_ERROR_RESOURCE_IN_USE"
 const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 8c647f5..2100c13 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -147,7 +147,8 @@ typedef enum {
   INTERNAL_ERROR_GXX_KEY_ADD_FAILED,
   INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED,
   INTERNAL_ERROR_NO_MEMORY_FOR_HEAP,
-  INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
+  INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR,
+  INTERNAL_ERROR_RESOURCE_IN_USE
 } Internal_errors_Core_list;
 typedef uint32_t Internal_errors_t;
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 4b83ede..02371ac 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -47,6 +47,14 @@ static void _Thread_Make_zombie( Thread_Control *the_thread )
   ISR_lock_Context lock_context;
   Thread_Zombie_control *zombies = &_Thread_Zombies;
+  if ( the_thread->resource_count != 0 ) {
+    _Terminate(
+      INTERNAL_ERROR_CORE,
+      false,
   _Thread_Set_state( the_thread, STATES_ZOMBIE );
   _Thread_queue_Extract_with_proxy( the_thread );
   _Watchdog_Remove( &the_thread->Timer );
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 82b9df4..74276e9 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -30,6 +30,7 @@ SUBDIRS = \
     spsimplesched03 spnsext01 spedfsched01 spedfsched02 spedfsched03 \
     spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
     spregion_err01 sppartition_err01
+SUBDIRS += spfatal28
 SUBDIRS += spthreadlife01
 SUBDIRS += spprofiling01
 SUBDIRS += spcache01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index f2f4b0e..35dc599 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -36,6 +36,7 @@ AM_CONDITIONAL(HAS_CPUSET,test x"${ac_cv_header_sys_cpuset_h}" = x"yes")
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+spfatal28/Makefile
 spthreadlife01/Makefile
 spprofiling01/Makefile
 spcache01/Makefile
diff --git a/testsuites/sptests/spfatal28/Makefile.am b/testsuites/sptests/spfatal28/Makefile.am
new file mode 100644
index 0000000..a20d936
--- /dev/null
+++ b/testsuites/sptests/spfatal28/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spfatal28
+spfatal28_SOURCES = ../spfatal_support/init.c ../spfatal_support/system.h testcase.h
+dist_rtems_tests_DATA = spfatal28.scn spfatal28.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spfatal28_OBJECTS)
+LINK_LIBS = $(spfatal28_LDLIBS)
+spfatal28$(EXEEXT): $(spfatal28_OBJECTS) $(spfatal28_DEPENDENCIES)
+	@rm -f spfatal28$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spfatal28/init.c b/testsuites/sptests/spfatal28/init.c
index 0000000..82df10c
--- /dev/null
+++ b/testsuites/sptests/spfatal28/init.c
@@ -0,0 +1,50 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include "tmacros.h"
+const char rtems_test_name[] = "spfatal28";
+static void test(void)
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spfatal28/spfatal28.doc b/testsuites/sptests/spfatal28/spfatal28.doc
index 0000000..7514dd9
--- /dev/null
+++ b/testsuites/sptests/spfatal28/spfatal28.doc
@@ -0,0 +1,12 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spfatal28
+directives:
+  - rtems_task_delete()
+concepts:
+  - Ensure that deletion of a task with a semaphore in use leads to a fatal
+    error.
diff --git a/testsuites/sptests/spfatal28/spfatal28.scn b/testsuites/sptests/spfatal28/spfatal28.scn
index 0000000..6fcae10
--- /dev/null
+++ b/testsuites/sptests/spfatal28/spfatal28.scn
@@ -0,0 +1,3 @@
+*** BEGIN OF TEST SPFATAL 28 ***
+Fatal error (delete a task with a semaphore in use) hit
+*** END OF TEST SPFATAL 28 ***
diff --git a/testsuites/sptests/spfatal28/testcase.h b/testsuites/sptests/spfatal28/testcase.h
index 0000000..fc72100
--- /dev/null
+++ b/testsuites/sptests/spfatal28/testcase.h
@@ -0,0 +1,39 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#define FATAL_ERROR_TEST_NAME            "28"
+#define FATAL_ERROR_DESCRIPTION          "delete a task with a semaphore in use"
+#define FATAL_ERROR_EXPECTED_SOURCE      INTERNAL_ERROR_CORE
+#define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
+#define FATAL_ERROR_EXPECTED_ERROR       INTERNAL_ERROR_RESOURCE_IN_USE
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+void force_error()
+  rtems_status_code sc;
+  rtems_id id;
+  sc = rtems_semaphore_create(
+    rtems_build_name('S', 'E', 'M', 'A'),
+    0,
+    RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
+    0,
+    &id
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_task_delete(RTEMS_SELF);
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 340a9e3..3302a2c 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -35,7 +35,7 @@ static void test_internal_error_text(void)
     puts( text );
   } while ( text != text_last );
-  rtems_test_assert( error - 3 == INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR );
+  rtems_test_assert( error - 3 == INTERNAL_ERROR_RESOURCE_IN_USE );
 static void test_fatal_source_text(void)
1.7.7
