Error while building rtems
Mon Mar 31 16:32:28 UTC 2014
Hello Marcos,
I fixed this problem.  You should consider to update your tool chain
using the RTEMS Source Builder:
http://www.rtems.org/wiki/index.php/RTEMS_Source_Builder
You should also consider to use --disable-networking if you don't need
network support in your application.
On 03/31/2014 04:45 PM, Marcos Díaz wrote:
> Hi, we were trying to build RTEMS for our bsp, after updating it, and
> it crashed.
> This is the error it gives:
> ../../../../../rtems_cleaned/c/src/libchip/network/dwmac-desc-enh.c:709:3:
> warning: nested extern declaration of '__DEVOLATILE'
> [-Wnested-externs]
> ../../../../../rtems_cleaned/c/src/libchip/network/dwmac-desc-enh.c:709:34:
> error: expected expression before 'void'
>    void *desc_mem = __DEVOLATILE( void *, self->dma_rx );
> We haven't touched anything in libchip. So, what could be the problem?
> we arent using ethernet for our builds.
> Thanks!
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
