GSoC 2014 | Poring RTEMS for OpenRISC
Hesham Moustafa heshamelmatary at gmail.com
Tue Mar 4 18:22:41 UTC 2014
On Mon, Mar 3, 2014 at 6:54 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Hesham,
> On Mon, Mar 3, 2014 at 11:06 AM, Hesham Moustafa
> <heshamelmatary at gmail.com> wrote:
> > On Mon, Mar 3, 2014 at 5:06 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com
> > wrote:
> >> On Mar 3, 2014 8:23 AM, Gedare Bloom <gedare at rtems.org> wrote:
> >> > Hesham,
> >> > The first question to figure out is why was the older port dropped.
> >> This I can answer. The tool chain rotted and had no maintainer. I also
> >> recall not having a simulator to test on.
> >> The final issue was some discrepancy between multiple openrisc CPU
> >> projects where I thought the focus on the architecture we had a port to
> was
> >> losing interest from them.
> > Thanks Dr Joel, I also wanted to know the answer :)
> > Was this architecture OpenRISC 1000 or another core ?
> If the toolchain is up-to-date and there are simulator and real hw
> architecture supported, then it can be a feasible project to do a
> port.
> Yes the toolchain is up-to-date and I worked on their or1ksim simulator
which can be connected to gdb. They support many boards, one of them is
Atlys FPGA board which I have and worked on and I hope to create a BSP for.
> >> > The second is what is your interest in porting to OpenRISC?
> > Because I have been working on the last few months on FPGA project ( mips
> > microprocessor).
> > I wanted to port an OS to an opensource processor, and OpenRISC
> architecture
> > is mature enough to port a complex RTOS like RTEMS.
> >> And who would use it?
> > People using black box OpenRISC and others interested in Digital design,
> > Computer architecture and
> > HW/SW interfacing. Something like xilinx zynq ? except that both OpenRISC
> > and RTEMS are opensource.
> If OpenRISC has settled on a specific reference architecture and has
> an adequately active community, then a port would be acceptable.
> I think they have. OpenRISC 1000 and 1200 architectures are both well
supported
and used, and their community is active.
> >> Long term a port needs to be to a viable architecture from a "is it
> alive"
> >> view  this includes the cpu, tools, a way for us to test, etc
> > Sure, that's what I hope to work on.
> In order to have a chance that your proposal will be accepted, you
> will need to demonstrate that the openrisc tools work for recent gcc /
> newlib with an adequate simulator. Based on wikipedia, you should be
> able to cross-compile Linux for the OpenRISC to run on Qemu, or you
> may like to just try to get a bare-metal application to run in the
> simulator.
> I have built their latest toolchain, gcc  4.9.0 and binutils 2.24.51.
with newlib. A helloworld program is working fine with or1k-elf-run,
or1k-elf-gdb (which connects to their or1ksim simulator) and qemu.
The questions is, should this project include porting their toolchains to
RTEMS toolchains (with their copyrights) ? or that may cause some
licence/copyrights problems ?
> Gedare
> >> > Gedare
> >> > On Sun, Mar 2, 2014 at 12:39 AM, Hesham Moustafa
> >> > > Hi,
> >> > > I am thinking of porting RTEMS for OpenRISC as a proposal for GSoC
> >> > > project
> >> > > this year.
> >> > > I know there was an older port, but it's not available anymore on
> the
> >> > > current RTEMS mainsteam.
> >> > > Would this project be of useful to RTEMS and suitable for GSoC ?
> >> > > Thanks,
> >> > > Hesham
> >> > > _______________________________________________
> >> > > rtems-devel mailing list
> >> > > rtems-devel at rtems.org
> >> > > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140304/3399ae7e/attachment-0001.html>
