[PATCH] rtems: Coding style
Wed May 28 15:26:31 UTC 2014
 cpukit/rtems/src/schedulergetprocessorset.c |   28 +++++++++++---------------
 1 files changed, 12 insertions(+), 16 deletions(-)
diff --git a/cpukit/rtems/src/schedulergetprocessorset.c b/cpukit/rtems/src/schedulergetprocessorset.c
index e459b17..016c368 100644
--- a/cpukit/rtems/src/schedulergetprocessorset.c
+++ b/cpukit/rtems/src/schedulergetprocessorset.c
@@ -28,27 +28,23 @@ rtems_status_code rtems_scheduler_get_processor_set(
   cpu_set_t *cpuset
-  rtems_status_code sc;
+  const Scheduler_Control *scheduler;
-  if ( cpuset != NULL ) {
-    const Scheduler_Control *scheduler;
+  if ( cpuset == NULL ) {
+    return RTEMS_INVALID_ADDRESS;
-    if ( _Scheduler_Get_by_id( scheduler_id, &scheduler ) ) {
-      if ( _CPU_set_Is_large_enough( cpusetsize ) ) {
-        _Scheduler_Get_processor_set( scheduler, cpusetsize, cpuset );
+  if ( !_Scheduler_Get_by_id( scheduler_id, &scheduler ) ) {
+    return RTEMS_INVALID_ID;
-        sc = RTEMS_SUCCESSFUL;
-      } else {
-        sc = RTEMS_INVALID_NUMBER;
-    } else {
-      sc = RTEMS_INVALID_ID;
-  } else {
-    sc = RTEMS_INVALID_ADDRESS;
+  if ( !_CPU_set_Is_large_enough( cpusetsize ) ) {
+    return RTEMS_INVALID_NUMBER;
-  return sc;
+  _Scheduler_Get_processor_set( scheduler, cpusetsize, cpuset );
+  return RTEMS_SUCCESSFUL;
 #endif /* defined(__RTEMS_HAVE_SYS_CPUSET_H__) */
1.7.7
