nios tools build failure
Fri Nov 21 16:18:53 UTC 2014
Hi
Patch doesn't apply. I am guessing it isn't needed with 4.9.2 anymore.
 cd gcc-4.9.2
+ /bin/chmod -R a+rX,g-w,o-w .
+ /bin/cat
/users/joel/rtems-4.11-work/rtems-source-builder/rtems/patches/RTEMS-Add-Nios-2-support.patch
+ /usr/bin/patch -p1
patching file gcc/config.gcc
Hunk #1 succeeded at 2165 with fuzz 2 (offset 9 lines).
The next patch would create the file gcc/config/nios2/rtems.h,
which already exists!  Assume -R? [n]
Apply anyway? [n]
Skipping patch.
1 out of 1 hunk ignored
The next patch would create the file gcc/config/nios2/t-rtems,
Apply anyway? [n]
