[PATCH 24/24] nios2_iss/Makefile.am: Add cache
Wed Sep 3 16:03:25 UTC 2014
 c/src/lib/libbsp/nios2/nios2_iss/Makefile.am | 22 +++++++++++++++++-----
 1 file changed, 17 insertions(+), 5 deletions(-)
diff --git a/c/src/lib/libbsp/nios2/nios2_iss/Makefile.am b/c/src/lib/libbsp/nios2/nios2_iss/Makefile.am
index 1094826..c10cd80 100644
--- a/c/src/lib/libbsp/nios2/nios2_iss/Makefile.am
+++ b/c/src/lib/libbsp/nios2/nios2_iss/Makefile.am
@@ -25,13 +25,22 @@ dist_project_lib_DATA += startup/linkcmds
 noinst_LIBRARIES += libbsp.a
 libbsp_a_SOURCES =
+libbsp_a_CPPFLAGS =
 # startup
-libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
-    ../../shared/bspreset_loop.c ../../shared/bsppost.c startup/bspstart.c \
-    ../../shared/bsppretaskinghook.c ../../shared/bspgetworkarea.c \
-    ../../shared/bootcard.c ../../shared/sbrk.c startup/setvec.c \
-    ../../shared/gnatinstallhandler.c ../../shared/bsppredriverhook.c
+libbsp_a_SOURCES += ../../shared/bspclean.c
+libbsp_a_SOURCES += ../../shared/bsplibc.c
+libbsp_a_SOURCES += ../../shared/bspreset_loop.c
+libbsp_a_SOURCES += ../../shared/bsppost.c
+libbsp_a_SOURCES += startup/bspstart.c
+libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
+libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
+libbsp_a_SOURCES += ../../shared/bootcard.c
+libbsp_a_SOURCES += ../../shared/sbrk.c
+libbsp_a_SOURCES += startup/setvec.c
+libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
+libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
 # clock
 libbsp_a_SOURCES += clock/clock.c ../../../shared/clockdrv_shell.h
 # console
@@ -39,5 +48,8 @@ libbsp_a_SOURCES += console/console.c ../../shared/console-polled.c
 # timer
 libbsp_a_SOURCES += timer/timer.c
+# Cache
+libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/shared/cache.rel
 include $(srcdir)/preinstall.am
 include $(top_srcdir)/../../../../automake/local.am
1.9.3
