SOCIS2015_EHTESHAMIFAR_FaultTolerance - Invitation to comment
Saeed Ehteshamifar salpha.2004 at gmail.com
Wed Apr 29 16:10:01 UTC 2015
I've resolved all of Gedare's comments and slightly changed my proposal.
Here is the published link to the document:
https://docs.google.com/document/d/1rVEhyHXajAVMcqgrOR-0t84596QUkYOnifoaYpa8QYM/pub
I've also applied via SOCIS website today and mentioned the link above as
for my proposal.
According to the timeline <http://sophia.estec.esa.int/socis/timeline>,
implementation phase begins from June 1st. I don't whether this date is
imposed by ESA or not but as written in my proposal, I can start the
project earlier than 01.06 if I get the admission.
Kind Regards,
SAeeD
On Tue, Apr 28, 2015 at 4:22 PM, Gedare Bloom <gedare at rtems.org> wrote:
> I've made a few comments. As Joel said, make sure you submit your
> application through SOCIS' web site.
> On Tue, Apr 28, 2015 at 9:06 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
> > Have you applied via the socis site?
> > On April 28, 2015 7:30:16 AM CDT, "Saeed Ehteshamifar (via Google Docs)"
> <salpha.2004 at gmail.com> wrote:
> >>Saeed Ehteshamifar has invited you to comment on the following
> >>document:
> >> Hello,
> >>Regarding my previous email for RTEMS fault tolerance (SOCIS15), I've
> >>shared my proposal (in the template format) via this email.
> >>Please have a look and kindly give me your feedbacks.
> >>Should I add an entry in the wiki
> >>(https://devel.rtems.org/wiki/SOCIS/2015) now or after my proposal is
> >>admitted?
> >>Kind Regards,
> >>SAeeD
> >>Open in Docs
> >>This email grants access to this item without logging in. Only forward
> >>it to people you trust.
> >>Google Docs: Create and edit documents online.
> > --joel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150429/64d5a626/attachment-0002.html>
