index 657b2f4..e69de29 100644
Wed Dec 23 16:20:09 UTC 2015
Sebastian.. anymore comments?
Liam.. try to stick to the top of file comments and grouping commands.
A comment that essentially is repetitive of the name of a method adds
no value or insight.
The commands that you will need to use are something like this sequence:
git checkout -b BRANCH
git add <FILES THAT CHANGED>
git commit
  # editor will pop up so you can describe change
git checkout master
git pull
git checkout BRANCH
git rebase -i master
# the above makes sure you are up to date
git format-patch -o TMPDIR master
# generates patch files relative to master branch into TMPDIR
Email those patches.
I hope that sequence helps. I am adding more time to the GCI task.
On Tue, Dec 22, 2015 at 11:51 PM, Sebastian Huber <
> On 23/12/15 01:17, Zaphod Beeblebrox wrote:
>> + at ingroup xilinx-zynq_i2c
>> + at brief Disable cadence interrupts
>>   static void cadence_i2c_disable_interrupts(volatile cadence_i2c *regs)
>>     regs->irqdisable = 0xffff;
> Could we please not add trivial Doxygen comments like this.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151223/e1e671c5/attachment-0002.html>
