[PATCH] dtc: Update to dtc 1.4.1 and use it on moxie
Joel Sherrill
joel.sherrill at oarcorp.com
Fri Jan 9 21:42:13 UTC 2015
The site referenced in the 1.2.x configuration is no longer accessible.
The new configuration gives both an updated version and a more
permanent location.
bare/config/devel/dtc-1.4.1.cfg | 18 ++++++++++++++++++
rtems/config/4.11/rtems-moxie.bset | 2 +-
rtems/config/unstable/4.11/rtems-moxie.bset | 2 +-
3 files changed, 20 insertions(+), 2 deletions(-)
create mode 100644 bare/config/devel/dtc-1.4.1.cfg
diff --git a/bare/config/devel/dtc-1.4.1.cfg b/bare/config/devel/dtc-1.4.1.cfg
new file mode 100644
index 0000000..eb6cb13
--- /dev/null
+++ b/bare/config/devel/dtc-1.4.1.cfg
@@ -0,0 +1,18 @@
+# DTC (Device Tree Compiler) 1.4.1
+%if %{release} == %{nil}
+%define release 1
+%endif
+%include %{_configdir}/base.cfg
+%define dtc_version 1.4.1
+%hash md5 dtc-%{dtc_version}.tar.gz 629851794f9fc494067d3c02e33068c3
+# The DTC build instructions. We use 1.x.x Release 1.
+%include %{_configdir}/dtc-1-1.cfg
diff --git a/rtems/config/4.11/rtems-moxie.bset b/rtems/config/4.11/rtems-moxie.bset
index d4f7a45..ed3fed2 100644
--- a/rtems/config/4.11/rtems-moxie.bset
+++ b/rtems/config/4.11/rtems-moxie.bset
@@ -21,7 +21,7 @@
4.11/rtems-autotools
devel/expat-2.1.0-1
-devel/dtc-1.2.0
+devel/dtc-1.4.1
tools/rtems-binutils-2.24-1
tools/rtems-gcc-4.9.2-newlib-git-1
tools/rtems-gdb-7.7-1
diff --git a/rtems/config/unstable/4.11/rtems-moxie.bset b/rtems/config/unstable/4.11/rtems-moxie.bset
index 51fde47..be78b0d 100644
--- a/rtems/config/unstable/4.11/rtems-moxie.bset
+++ b/rtems/config/unstable/4.11/rtems-moxie.bset
@@ -15,7 +15,7 @@
# Tools configuration.
expat-2.1.0-1
-dtc-1.2.0
+dtc-1.4.1
tools/rtems-binutils-2.22-1
tools/rtems-gcc-4.8-ss-newlib-2.0.0-1
tools/rtems-gdb-7.5.1-1
1.9.3
