GSOC 2015: Configuration GUI
Anand Krishnan anandkp92 at gmail.com
Sat Jul 4 13:40:05 UTC 2015
Hi,
Thanks for approving my midterm evaluation.
Anyways, I have added the GUI class for String options. Will work on
StringList now.
Anand.
On Sat, Jun 27, 2015 at 7:16 AM, Anand Krishnan <anandkp92 at gmail.com> wrote:
> Hi,
> The GUI is partially done. The set up for Boolean and Integer options is
> done.
> Find the files here: https://github.com/anandkp92/waf/tree/waf/gui
> [Run gui.py].
> Please let me know if you are facing any issue while running this file or
> any changes I have to make.
> Thanks,
> Anand
> On Thu, Jun 18, 2015 at 12:07 PM, Anand Krishnan <anandkp92 at gmail.com>
> wrote:
>> Hi,
>> On Thu, Jun 18, 2015 at 10:45 AM, Anand Krishnan <anandkp92 at gmail.com>
>> wrote:
>>> On Thu, Jun 18, 2015 at 6:18 AM, Amar Takhar <amar at rtems.org> wrote:
>>>> On 2015-06-18 05:57 +0530, Anand Krishnan wrote:
>>>> > Hi all,
>>>> > I've almost prepared the basic layout for the GUI. Also added some
>>>> dummy event
>>>> > handlers for File Menu.
>>>> > Any more suggestions before fetching the options?
>>>> This is a great start!
>>>> Have you thought about how you are going to lay out the tabs for
>>>> multiple BSP
>>>> configs + the tag headings?
>>>> One option is to do multi-layered tabs along the top.  Another is tabs
>>>> on the
>>>> top and vertically (left side).
>>>> I'll check it out now and post it when I get some good  results
>> I've added the multilayered tabs. I tried both the ways that you
>> mentioned -> along the top and left. And I felt this was better. But I can
>> revert to the other one in no time.
>> link: https://github.com/anandkp92/waf/tree/waf/gui
>>>> Amar.
>>> Thanks,
>>> Anand
>> Anand.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150704/166f584e/attachment.html>
