GSoC 2015: Raspberry Pi 2 Support
Rohini Kulkarni krohini1593 at gmail.com
Wed Jun 3 06:39:40 UTC 2015
But, I can't say cache configurations have a role here.
I'll push my code to my github project soon.
P.S. The Pi2 board I possess seems to have broken down. It just isn't
turning on. Unable to test further. Will order one immediately.
On 3 Jun 2015 09:03, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
> Hi,
> Alan, your suggestion has resulted in much improvement
> arm_control=0x1000
> This has simply worked! Looks like the other cores were taking up plenty
> of time.
> I was aware from references that the other cores run a WFI, but ya, did
> not get its impact.
> Time for each dhrystone has reduced to 7 from 13 and the no of dhrystones
> per second also increased.
> But this is a change only in the config.txt not actually in the boot code.
> Thanks
> Rohini
> On Wed, Jun 3, 2015 at 7:12 AM, Alan Cudmore <alan.cudmore at gmail.com>
> wrote:
>> The caches are being enabled on the RPI 1 BSP. The same code is being
>> executed by the RPI 2 BSP, but obviously it’s not sufficient for the cache
>> setup.
>> I have been reading through this long thread, and it is very informative:
>> https://www.raspberrypi.org/forums/viewtopic.php?f=72&t=98904
>> I am starting to understand the setup that is required to enable caches
>> on the RPI 2. For example this message near the bottom of page 3 gives a
>> good indication of the speedup available by configuring the MMU and caches
>> correctly:
>> Quote from above thread
>> Enabling I/D caches and branch prediction, just like the julia demo uses,
>> it takes ~12 seconds, or ~21 fps. It's just one core but also a much
>> smaller loop than the julia demo has.
>> Enabling the MMU and mapping memory inner/outer write-back, write
>> allocate and the framebuffer inner write-through, no write allocate + outer
>> write-back, write-allocate it takes ~8 seconds, of 32 fps.
>> PS: 640x480x32 with MMU gets me ~256 fps. Must have a greater L2 cache
>> effect.
>> End of quote
>> The person who posted the above comment (mrvn) posted the code here:
>> https://github.com/mrvn/test/blob/master/mmu.cc
>> Also, it seems that when the Pi 2 starts up, cores 1-3 are put in a wait
>> loop always accessing the bus. By putting this option in the config.txt
>> file you can put the other cores to sleep, speeding up the code on core 1.
>>  arm_control=0x1000
>> It would be worth trying that option to see if the benchmark speeds up.
>> Alan
>> On Jun 2, 2015, at 8:05 AM, Hesham ALMatary <heshamelmatary at gmail.com>
>> wrote:
>> On Tue, Jun 2, 2015 at 12:41 PM, Rohini Kulkarni <krohini1593 at gmail.com>
>> wrote:
>> From what I saw, they have to be enabled separately. Cache/mmu are
>> disabled
>> upon reset.
>> For the existing Raspberry BSP [1] there's a code for MMU/Cache init,
>> however I don't know about Pi2 and where its code is.
>> [1]
>> https://github.com/RTEMS/rtems/tree/master/c/src/lib/libbsp/arm/raspberrypi
>> On 2 Jun 2015 16:59, "Hesham ALMatary" <heshamelmatary at gmail.com> wrote:
>> Hi,
>> Aren't the MMU/Caches enabled by default for RPi [1]?
>> [1]
>> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/arm/shared/mminit.c
>> On Tue, Jun 2, 2015 at 12:18 PM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>> On June 2, 2015 7:01:21 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
>> wrote:
>> Dr. Joel,
>> So we can't say something solely on the basis of this result?
>> I don't think so. If Linux performs the same, then what you did is as
>> good as it gets.
>> However, if Linux is faster then some setting still isn't right.
>> You need a reference measurement to have any confidence. It is possible
>> you did something but didn't actually turn the cache (or all the cache)
>> on.
>> On 2 Jun 2015 16:28, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>> I have not run it under linux on pi2 yet. Will have to run and check
>> the result.
>> On 2 Jun 2015 16:16, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
>> On June 2, 2015 5:58:33 AM EDT, Rohini Kulkarni <krohini1593 at gmail.com>
>> wrote:
>> HI,
>> I tried running the dhrystone benchmark with some changes for
>> cache/mmu
>> set up.
>> However, the output shows a reduction in performance.
>> The time to run through the dhrystone has increased from 12 to 13 and
>> dhrystones run per second decreased.
>> According to this result, things were better with caches disabled.
>> I have been working on this since two days and could not figure out an
>> improvement. Any pointers?
>> How did it do under Linux on the Pi2?
>> Thanks.
>> On Thu, May 28, 2015 at 8:41 PM, Rohini Kulkarni
>> Hi All,
>> I have to implement the cache coherency support for Cortex A7. But for
>> A7 MPCore, unlike for A9, I am not able to find any register
>> description for the Snoop Control Unit from the TRM.
>> I need help here on how to proceed.
>> Additionally for A9 there is a single bit for A9 in the Auxiliary
>> Control Register which enables cache broadcast operations. The
>> register
>> format is different for A7 and again I am unable to find how to
>> achieve
>> the same for A7.
>> Thanks!
>> On Tue, May 5, 2015 at 10:42 PM, Joel Sherrill
>> On 5/5/2015 11:11 AM, Rohini Kulkarni wrote:
>> Hi,
>> I am working with the code for bsp hooks. I am referring to existing
>> ARM multicore bsp codes, zync mainly.
>> 1. There are existing hooks for the raspberry pi. Where should the
>> code
>> for the  Pi2 hooks be added?
>> The Pi and Pi2 are remarkably similar so Pi2 should be placed inside
>> the Pi BSP directory.
>> There is already a Pi2 variant of that code built. But we know
>> specific
>> places where there
>> are variances. Depending on the scope of what is different, it can be
>> as simple as
>> a cpp conditional in a .h to select a value or two implementations of
>> a
>> single method
>> and the Makefile.am picking the right file to build based on the board
>> variant.
>> The big question to always ask is: Is this specific to the Pi2 and
>> incompatible with the Pi?
>> Since the Pi BSP is still missing capabilities, it is likely code
>> common to both will
>> be added this summer. For example, did the mailbox interface change? I
>> don't know
>> but would guess that it didn't.  Each new capability added needs that
>> added.
>> And any differences need to be analyzed to pick the least intrusive
>> way
>> to provide
>> alternate implementations. Or enable special code like the Pi2 SMP
>> support which
>> is dependent on --enable-smp and being a Pi2.
>> 2. Am I right in understanding that I will have to implement A7
>> specific functions as have been for A9? I am referring specifically to
>> the arm-a9mpcore-start.h
>> Yes.
>> If the code is very similar between the a7 and a9, then a discussion
>> on devel@ should occur to decide the best way to minimize duplication.
>> If you end up with a7 specific code, you should follow the location
>> and
>> naming patterns already established. That places it in
>> libbsp/arm/shared/...
>> so it can be used by any BSP with the right SMP core.
>> I am referring to existing codes to locate and get hold of what needs
>> to be done in the hooks. However, being new to such implementations, I
>> am taking longer to understand the details. Any suggestions that might
>> help here are welcome
>> The answer will depend on the factors listed above. When code can
>> be shared, we want to share it across as many BSPs as makes sense.
>> When it is unique to a specific BSP **variant** (e.g. Pi vs Pi2), then
>> you want to find the way to account for the variation in the least
>> intrusive code way possible.
>> Thanks!
>> On 1 May 2015 12:45, "Rohini Kulkarni" <krohini1593 at gmail.com> wrote:
>> Hi,
>> Excited to be a part of  this edition of GSoC! Thanks to everybody for
>> helping me get here and congratulations to all the participating
>> students!
>> So, now getting to work, firstly I wish to know, specifically from my
>> mentors, any changes that must be made to my proposed project or
>> schedule.
>> Secondly, are there any specifics for the development blog that we
>> need
>> to create for the project? Over time what is the blog expected to
>> convey.
>> Also, I have to create a new wiki page for my project as none exists.
>> I
>> want to know how to add one.
>> Rohini Kulkarni
>> -- Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research Ask me about
>> RTEMS: a free RTOS Huntsville AL 35805 Support Available (256)
>> 722-9985
>> Rohini Kulkarni
>> Rohini Kulkarni
>> --joel
>> --joel
>> devel mailing list
>> devel at rtems.org
>> Hesham
>> Hesham
>> devel mailing list
>> devel at rtems.org
> Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150603/fbbe20fa/attachment-0002.html>
