[PATCH] [RSB] Use gcc 5-20150301 snapshot.
Hesham ALMatary heshamelmatary at gmail.com
Tue Mar 10 09:35:51 UTC 2015
Use newlib git repository and gcc snapshot that contains the latest moxie
opcodes. Revert back to dtc-1.2.0 as dtc-1.4.1 would raise a compilation error.
Note: This patch is unstable, and it's meant to be a temporary solution until
the next gcc release,the build process may or may not fail!
Update #2254
 rtems/config/4.11/rtems-moxie.bset | 14 +++++++++++---
 1 file changed, 11 insertions(+), 3 deletions(-)
diff --git a/rtems/config/4.11/rtems-moxie.bset b/rtems/config/4.11/rtems-moxie.bset
index 2e4962d..64c22fc 100644
--- a/rtems/config/4.11/rtems-moxie.bset
+++ b/rtems/config/4.11/rtems-moxie.bset
@@ -16,14 +16,22 @@
 %define win32-gdb-disable-sim
+# Temporary solution until next gcc release to fix ABI changes.
+%source set gcc ftp://ftp.mirrorservice.org/sites/sourceware.org/pub/gcc/snapshots/5-20150301/gcc-5-20150301.tar.bz2
+# Use gcc snapshot the has moxie ABI changes
+%define gcc_version 5-20150301
+%define newlib_version de616601501c4f82968683e80c112604a2d40222
 # Tools configuration.
 4.11/rtems-autotools
 devel/expat-2.1.0-1
-devel/dtc-1.4.1
-tools/rtems-binutils-2.24-1
-tools/rtems-gcc-4.9.2-newlib-git-1
+devel/dtc-1.2.0
+tools/rtems-binutils-git-1
+tools/rtems-gcc-4.9-newlib-git-1
 tools/rtems-gdb-7.8.2-1
 tools/rtems-tools-4.11-1
 tools/rtems-kernel-4.11
2.1.0
