imfs.h: warning cast from pointer to integer of different size
Ric Claus claus at slac.stanford.edu
Thu Mar 19 17:10:05 UTC 2015
On Mar 19, 2015, at 5:06 PM, Gedare Bloom <gedare at gwu.edu> wrote:
> On Thu, Mar 19, 2015 at 12:00 PM, Ric Claus <claus at slac.stanford.edu> wrote:
>> On Mar 19, 2015, at 4:30 PM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>>> ----- Joel Sherrill <joel.sherrill at oarcorp.com> schrieb:
>>>> On March 19, 2015 9:52:56 AM CDT, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> On Thu, Mar 19, 2015 at 10:49 AM, Joel Sherrill
>>>>> <joel.sherrill at oarcorp.com> wrote:
>>>>>> Hi
>>>>>> On one platform, we get a warning for this piece of code in imfs.h
>>>>>> static inline ino_t IMFS_node_to_ino( const IMFS_jnode_t *node )
>>>>>> return (ino_t) node;
>>>>>> On this target, "typedef unsigned long ino_t;" and
>>>>>> sizeof(void *) < sizeof(unsigned long) so the cast is safe.
>>>>>> Would we be better off with ino_t being uintptr_t since we
>>>>>> do cast it back and forth?
>>>>>> Any other suggestions?
>>>>> The safest fix is to use the new CPU_Uint32ptr type. This resolves to
>>>>> uintptr_t on most 32-bit+ archs.
>>>> The type ino_t is defined in newlib so this doesn't work.
>>> The only requirement on the ino number is that it uniquely indentifies a node in a file system.  We only have a problem if sizeof(IMFS_jnode_t *) > sizeof(long).
> Using the intermediate cast to uintptr_t is fine. We should keep ino_t
> defined as a long.
>> I’m curious what you all think about doing:
>>  return (const char*)node - (const char*)0;
> This still results in a pointer-type, the return value will be cast to
> ino_t implicitly and give a similar warning.
No, I don’t think so.  The difference of two pointers is the number of elements (chars in this case) between them.
