GCC -include option and waf
Tue Oct 20 05:33:06 UTC 2015
Hello,
how can I use the "-include file" GCC option with waf? In case I use this:
+    bld.objects(target = "objs07",
+                features = "c",
+                cflags = ['-include
freebsd/sys/contrib/ncsw/build/dflags.h'] + cflags,
I get:
Waf: Entering directory
`/scratch/git-rtems-libbsd/build/powerpc-rtems4.12-qoriq_t4240rdb'
[351/896] c: freebsd/sys/contrib/ncsw/Peripherals/BM/bm.c ->
build/powerpc-rtems4.12-qoriq_t4240rdb/freebsd/sys/contrib/ncsw/Peripherals/BM/bm.c.16.o
cc1: fatal error:  freebsd/sys/contrib/ncsw/build/dflags.h: No such file
or directory
compilation terminated.
Waf: Leaving directory
Build failed
    -> task in 'objs07' failed (exit status 1):
           {task 36571024: c bm.c -> bm.c.16.o}
['/opt/rtems-4.12/bin/powerpc-rtems4.12-gcc', '-qrtems',
'-B/opt/rtems-4.12/powerpc-rtems4.12/lib/',
'-B/opt/rtems-4.12/powerpc-rtems4.12/qoriq_t4240rdb/lib/', '--specs',
'bsp_specs', '-mcpu=e6500', '-mcpu=e6500', '-m32', '-m32',
'-msdata=sysv', '-msdata=sysv', '-fno-common', '-fno-common',
'-std=gnu++11', '-include freebsd/sys/contrib/ncsw/build/dflags.h', ...,
'../../freebsd/sys/contrib/ncsw/Peripherals/BM/bm.c', '-c', '-o',
'freebsd/sys/contrib/ncsw/Peripherals/BM/bm.c.16.o']
E.g. what is the equivalent of $(top_srcdir) or $(srcdir) in waf?
This -include is something else than a simple -I. It instructs GCC to
include the specified file. So, this is a command line #include <...>.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
internal mailing list
internal at rtems.org
http://lists.rtems.org/mailman/listinfo/internal
