[PATCH] Fix declaration of pthread-structs in s-osinte-rtems.ads
Jan Sommer soja-lists at aries.uberspace.de
Sat Oct 31 15:47:35 UTC 2015
Hi,
This patch changes the Ada-declaration of the pthread-related structs such as pthread_attr_t from a field-equivalent declaration to just reserving the right amount of memory.
It is only rtems related and essentially copies the way how the types are defined in s-osinte-linux.ads. It makes the declarations independent of a particular newlib-version and fixes the bug I filed here:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=68169
CC are the rtems developers for discussion.
Best regards,
   Jan
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151031/0cd29ecc/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151031/0cd29ecc/attachment-0001.bin>
