[PATCH 4/4] score: Add deadlock detection
Tue Jul 5 08:33:19 UTC 2016
The mutex objects use the owner field of the thread queues for the mutex
owner.  Use this and add a deadlock detection to
_Thread_queue_Enqueue_critical() for thread queues with an owner.
Update #2412.
Update #2556.
 cpukit/sapi/src/interrtext.c                       |   5 +-
 cpukit/score/include/rtems/score/interr.h          |   3 +-
 cpukit/score/include/rtems/score/thread.h          |  24 ++
 cpukit/score/include/rtems/score/threadq.h         |  35 +-
 cpukit/score/include/rtems/score/threadqimpl.h     |  33 ++
 cpukit/score/src/coremutexseize.c                  |   9 +
 cpukit/score/src/mutex.c                           |   4 +
 cpukit/score/src/threadqenqueue.c                  | 108 ++++++
 testsuites/sptests/spinternalerror02/init.c        |   4 +-
 .../spinternalerror02/spinternalerror02.scn        |   3 +-
 testsuites/sptests/spmutex01/init.c                | 413 +++++++++++++++++++--
 testsuites/sptests/spmutex01/spmutex01.doc         |   5 +
 testsuites/sptests/spsyslock01/init.c              |  79 ++--
 13 files changed, 638 insertions(+), 87 deletions(-)
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 3ae7315..8408061 100644
--- a/cpukit/sapi/src/interrtext.c
+++ b/cpukit/sapi/src/interrtext.c
@@ -7,7 +7,7 @@
- * Copyright (c) 2012-2015 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2012, 2016 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -54,7 +54,8 @@ static const char *const internal_error_text[] = {
   "INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR",
   "INTERNAL_ERROR_RESOURCE_IN_USE",
   "INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL",
-  "INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL"
+  "INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL",
+  "INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK"
 const char *rtems_internal_error_text( rtems_fatal_code error )
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index ca48db2..cc3dca4 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -163,7 +163,8 @@ typedef enum {
   INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR,
   INTERNAL_ERROR_RESOURCE_IN_USE,
   INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL,
-  INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL
+  INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL,
+  INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK
 } Internal_errors_Core_list;
 typedef CPU_Uint32ptr Internal_errors_t;
diff --git a/cpukit/score/include/rtems/score/thread.h b/cpukit/score/include/rtems/score/thread.h
index 46c222f..54ecd7c 100644
--- a/cpukit/score/include/rtems/score/thread.h
+++ b/cpukit/score/include/rtems/score/thread.h
@@ -264,6 +264,30 @@ typedef struct {
     RBTree_Node RBTree;
   } Node;
+#if defined(RTEMS_SMP)
+   * @brief Control block used to recursively acquire thread queue owners.
+   * @see _Thread_queue_Owner_acquire_recursive().
+  struct {
+     * @brief Chain node to register in Thread_queue_Context::Recursive_owners.
+    Chain_Node Node;
+     * @brief ISR lock context used for _Thread_Lock_acquire_critical().
+    ISR_lock_Context Context;
+     * @brief Lock returned by _Thread_Lock_acquire_critical().
+    void *lock;
+  } Recursive_owner;
+#endif
 #if defined(RTEMS_MULTIPROCESSING)
    * @brief This field is the identifier of the remote object this thread is
diff --git a/cpukit/score/include/rtems/score/threadq.h b/cpukit/score/include/rtems/score/threadq.h
index a4e5292..1a365fa 100644
--- a/cpukit/score/include/rtems/score/threadq.h
+++ b/cpukit/score/include/rtems/score/threadq.h
@@ -42,6 +42,17 @@ extern "C" {
 typedef struct _Thread_Control Thread_Control;
+ * @brief Thread queue deadlock callout.
+ * @param the_thread The thread that detected the deadlock.
+ * @see _Thread_queue_Context_set_deadlock_callout().
+typedef void ( *Thread_queue_Deadlock_callout )(
+  Thread_Control *the_thread
  * @brief Multiprocessing (MP) support callout for thread queue operations.
@@ -50,6 +61,8 @@ typedef struct _Thread_Control Thread_Control;
  *   control is actually a thread proxy if and only if
  *   _Objects_Is_local_id( the_proxy->Object.id ) is false.
  * @param mp_id Object identifier of the object containing the thread queue.
+ * @see _Thread_queue_Context_set_MP_callout().
 typedef void ( *Thread_queue_MP_callout )(
   Thread_Control *the_proxy,
@@ -79,6 +92,17 @@ typedef struct {
   uint32_t expected_thread_dispatch_disable_level;
+   * @brief Invoked in case of a detected deadlock.
+   * Must be initialized for _Thread_queue_Enqueue_critical() in case the
+   * thread queue may have an owner, e.g. for mutex objects.
+  Thread_queue_Deadlock_callout deadlock_callout;
+#if defined(RTEMS_MULTIPROCESSING)
    * @brief Callout to unblock the thread in case it is actually a thread
    * proxy.
@@ -88,9 +112,18 @@ typedef struct {
-#if defined(RTEMS_MULTIPROCESSING)
   Thread_queue_MP_callout mp_callout;
 #endif
+   * @brief Chain with recursive owners.
+   * Internally used on SMP configurations by _Thread_queue_Enqueue_critical().
+   * There is no need to initialize this field.
+  Chain_Control Recursive_owners;
+#endif
 } Thread_queue_Context;
diff --git a/cpukit/score/include/rtems/score/threadqimpl.h b/cpukit/score/include/rtems/score/threadqimpl.h
index 73d4de2..4e8c6e1 100644
--- a/cpukit/score/include/rtems/score/threadqimpl.h
+++ b/cpukit/score/include/rtems/score/threadqimpl.h
@@ -54,6 +54,16 @@ typedef struct {
 } Thread_queue_Syslock_queue;
+ * @brief Sets the thread wait return code to STATUS_DEADLOCK.
+void _Thread_queue_Deadlock_status( Thread_Control *the_thread );
+ * @brief Results in an INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK fatal error.
+void _Thread_queue_Deadlock_fatal( Thread_Control *the_thread );
  * @brief Initializes a thread queue context.
  * @param queue_context The thread queue context to initialize.
@@ -64,6 +74,7 @@ RTEMS_INLINE_ROUTINE void _Thread_queue_Context_initialize(
 #if defined(RTEMS_DEBUG)
   queue_context->expected_thread_dispatch_disable_level = 0xdeadbeef;
+  queue_context->deadlock_callout = _Thread_queue_Deadlock_fatal;
   queue_context->mp_callout = NULL;
 #endif
@@ -91,6 +102,28 @@ _Thread_queue_Context_set_expected_level(
+ * @brief Sets the deadlock callout in the thread queue
+ * context.
+ * A deadlock callout must be provided for _Thread_queue_Enqueue_critical()
+ * operations that operate on thread queues which may have an owner, e.g. mutex
+ * objects.  Available deadlock callouts are _Thread_queue_Deadlock_status()
+ * and _Thread_queue_Deadlock_fatal().
+ * @param queue_context The thread queue context.
+ * @param deadlock_callout The deadlock callout.
+ * @see _Thread_queue_Enqueue_critical().
+RTEMS_INLINE_ROUTINE void _Thread_queue_Context_set_deadlock_callout(
+  Thread_queue_Context          *queue_context,
+  queue_context->deadlock_callout = deadlock_callout;
  * @brief Sets the MP callout in the thread queue context.
diff --git a/cpukit/score/src/coremutexseize.c b/cpukit/score/src/coremutexseize.c
index ab743c4..d962961 100644
--- a/cpukit/score/src/coremutexseize.c
+++ b/cpukit/score/src/coremutexseize.c
@@ -64,6 +64,11 @@ Status_Control _CORE_mutex_Seize_slow(
   _Thread_queue_Context_set_expected_level( queue_context, 2 );
 #endif
+  _Thread_queue_Context_set_deadlock_callout(
+    queue_context,
+    _Thread_queue_Deadlock_status
     &the_mutex->Wait_queue.Queue,
     CORE_MUTEX_TQ_OPERATIONS,
@@ -91,6 +96,10 @@ Status_Control _CORE_mutex_Seize_no_protocol_slow(
   if ( wait ) {
     _Thread_queue_Context_set_expected_level( queue_context, 1 );
+      queue_context,
       operations,
diff --git a/cpukit/score/src/mutex.c b/cpukit/score/src/mutex.c
index ed374a0..093d805 100644
--- a/cpukit/score/src/mutex.c
+++ b/cpukit/score/src/mutex.c
@@ -110,6 +110,10 @@ static void _Mutex_Acquire_slow(
   _Thread_Inherit_priority( owner, executing );
+    queue_context,
+    _Thread_queue_Deadlock_fatal
     &mutex->Queue.Queue,
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index 3be7d58..dbd8504 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -34,6 +34,104 @@
 #define THREAD_QUEUE_READY_AGAIN \
   (THREAD_WAIT_CLASS_OBJECT | THREAD_WAIT_STATE_READY_AGAIN)
+#define THREAD_OF_RECURSIVE_OWNER_NODE( node ) \
+  RTEMS_CONTAINER_OF( node, Thread_Control, Wait.Recursive_owner.Node )
+static void _Thread_queue_Owner_release_recursive(
+  Chain_Node *head;
+  Chain_Node *node;
+  head = _Chain_Head( &queue_context->Recursive_owners );
+  node = _Chain_Last( &queue_context->Recursive_owners );
+  while ( head != node ) {
+    Thread_Control *node_thread;
+    node_thread = THREAD_OF_RECURSIVE_OWNER_NODE( node );
+    _Thread_Lock_release_critical(
+      node_thread->Wait.Recursive_owner.lock,
+      &node_thread->Wait.Recursive_owner.Context
+    node = _Chain_Previous( node );
+#else
+  (void) queue_context;
+#endif
+static bool _Thread_queue_Owner_acquire_recursive(
+  Thread_queue_Queue   *queue,
+  Thread_Control       *the_thread,
+  Thread_Control *previous;
+  _Chain_Initialize_empty( &queue_context->Recursive_owners );
+  previous = the_thread;
+#else
+#endif
+  while ( true ) {
+    Thread_Control *owner;
+    owner = queue->owner;
+    if ( owner == NULL ) {
+      break;
+    if ( owner == the_thread ) {
+      _Thread_queue_Owner_release_recursive( queue_context );
+      return false;
+    previous->Wait.Recursive_owner.lock = _Thread_Lock_acquire_critical(
+      owner,
+      &previous->Wait.Recursive_owner.Context
+    _Chain_Append_unprotected(
+      &queue_context->Recursive_owners,
+      &previous->Wait.Recursive_owner.Node
+    previous = owner;
+#endif
+    queue = owner->Wait.queue;
+    if ( queue == NULL ) {
+      break;
+  return true;
+  the_thread->Wait.return_code = STATUS_DEADLOCK;
+  _Terminate(
+    INTERNAL_ERROR_CORE,
+    false,
 void _Thread_queue_Enqueue_critical(
   const Thread_queue_Operations *operations,
@@ -52,6 +150,14 @@ void _Thread_queue_Enqueue_critical(
 #endif
+  if (
+    !_Thread_queue_Owner_acquire_recursive( queue, the_thread, queue_context )
+    _Thread_queue_Queue_release( queue, &queue_context->Lock_context );
+    ( *queue_context->deadlock_callout )( the_thread );
+    return;
   _Thread_Lock_set( the_thread, &queue->Lock );
   the_thread->Wait.return_code = STATUS_SUCCESSFUL;
@@ -60,6 +166,8 @@ void _Thread_queue_Enqueue_critical(
   ( *operations->enqueue )( queue, the_thread );
   _Thread_Wait_flags_set( the_thread, THREAD_QUEUE_INTEND_TO_BLOCK );
   cpu_self = _Thread_Dispatch_disable_critical( &queue_context->Lock_context );
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index cbc81a5..eac90a0 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -1,5 +1,5 @@
  *  Donierstr. 4
@@ -36,7 +36,7 @@ static void test_internal_error_text(void)
   } while ( text != text_last );
   rtems_test_assert(
-    error - 3 == INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL
+    error - 3 == INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK
diff --git a/testsuites/sptests/spinternalerror02/spinternalerror02.scn b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
index c6e85b1..ff04560 100644
--- a/testsuites/sptests/spinternalerror02/spinternalerror02.scn
+++ b/testsuites/sptests/spinternalerror02/spinternalerror02.scn
@@ -17,7 +17,7 @@ INTERNAL_ERROR_BAD_STACK_HOOK
 INTERNAL_ERROR_BAD_ATTRIBUTES
 INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY
 OBSOLETE_INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL
-INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE
+INTERNAL_ERROR_THREAD_QUEUE_ENQUEUE_FROM_BAD_STATE
 INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0
 OBSOLETE_INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP
 INTERNAL_ERROR_GXX_KEY_ADD_FAILED
@@ -27,6 +27,7 @@ INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
+INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK
 INTERNAL_ERROR_CORE
diff --git a/testsuites/sptests/spmutex01/init.c b/testsuites/sptests/spmutex01/init.c
index 76d62c0..c363370 100644
--- a/testsuites/sptests/spmutex01/init.c
+++ b/testsuites/sptests/spmutex01/init.c
@@ -16,33 +16,65 @@
   #include "config.h"
 #endif
+#include <threads.h>
+#include <setjmp.h>
+#include <rtems.h>
+#include <rtems/libcsupport.h>
+#ifdef RTEMS_POSIX_API
+#include <errno.h>
+#include <pthread.h>
+#endif
 #include "tmacros.h"
 const char rtems_test_name[] = "SPMUTEX 1";
 #define TASK_COUNT 5
+#define MTX_COUNT 3
 typedef enum {
   REQ_WAKE_UP_MASTER = RTEMS_EVENT_0,
   REQ_WAKE_UP_HELPER = RTEMS_EVENT_1,
-  REQ_MTX_OBTAIN = RTEMS_EVENT_2,
-  REQ_MTX_RELEASE = RTEMS_EVENT_3
+  REQ_MTX_0_OBTAIN = RTEMS_EVENT_2,
+  REQ_MTX_0_RELEASE = RTEMS_EVENT_3,
+  REQ_MTX_1_OBTAIN = RTEMS_EVENT_4,
+  REQ_MTX_1_RELEASE = RTEMS_EVENT_5,
+  REQ_MTX_2_OBTAIN = RTEMS_EVENT_6,
+  REQ_MTX_2_RELEASE = RTEMS_EVENT_7,
+  REQ_MTX_C11_OBTAIN = RTEMS_EVENT_8,
+  REQ_MTX_C11_RELEASE = RTEMS_EVENT_9,
+  REQ_MTX_POSIX_OBTAIN = RTEMS_EVENT_10,
+  REQ_MTX_POSIX_RELEASE = RTEMS_EVENT_11
 } request_id;
 typedef enum {
+  M,
   A_1,
   A_2_0,
   A_2_1,
-  M,
   H,
   NONE
 } task_id;
+typedef enum {
+  MTX_0,
+  MTX_1,
+  MTX_2
+} mutex_id;
 typedef struct {
-  rtems_id mtx;
+  rtems_id mtx[MTX_COUNT];
+  mtx_t mtx_c11;
+  pthread_mutex_t mtx_posix;
+#endif
   rtems_id tasks[TASK_COUNT];
   int generation[TASK_COUNT];
   int expected_generation[TASK_COUNT];
+  jmp_buf deadlock_return_context;
 } test_context;
 static test_context test_instance;
@@ -109,22 +141,79 @@ static void request(test_context *ctx, task_id id, request_id req)
   sync_with_helper(ctx);
-static void obtain(test_context *ctx)
+static void obtain(test_context *ctx, mutex_id id)
   rtems_status_code sc;
-  sc = rtems_semaphore_obtain(ctx->mtx, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+  sc = rtems_semaphore_obtain(ctx->mtx[id], RTEMS_WAIT, RTEMS_NO_TIMEOUT);
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-static void release(test_context *ctx)
+static void deadlock_obtain(test_context *ctx, mutex_id id)
-  sc = rtems_semaphore_release(ctx->mtx);
+  rtems_test_assert(sc == RTEMS_INCORRECT_STATE);
+static void release(test_context *ctx, mutex_id id)
+  rtems_status_code sc;
+  sc = rtems_semaphore_release(ctx->mtx[id]);
+static void obtain_c11(test_context *ctx)
+  int status;
+  status = mtx_lock(&ctx->mtx_c11);
+  rtems_test_assert(status == thrd_success);
+static void deadlock_obtain_c11(test_context *ctx)
+  if (setjmp(ctx->deadlock_return_context) == 0) {
+    (void) mtx_lock(&ctx->mtx_c11);
+static void release_c11(test_context *ctx)
+  int status;
+  status = mtx_unlock(&ctx->mtx_c11);
+static void obtain_posix(test_context *ctx)
+  int error;
+  error = pthread_mutex_lock(&ctx->mtx_posix);
+  rtems_test_assert(error == 0);
+static void deadlock_obtain_posix(test_context *ctx)
+  int error;
+  rtems_test_assert(error == EDEADLK);
+static void release_posix(test_context *ctx)
+  int error;
+  error = pthread_mutex_unlock(&ctx->mtx_posix);
+#endif
 static void check_generations(test_context *ctx, task_id a, task_id b)
   size_t i;
@@ -179,22 +268,65 @@ static void worker(rtems_task_argument arg)
   while (true) {
     rtems_event_set events = wait_for_events();
-    if ((events & REQ_MTX_OBTAIN) != 0) {
-      obtain(ctx);
+    if ((events & REQ_MTX_0_OBTAIN) != 0) {
+      obtain(ctx, MTX_0);
       ++ctx->generation[id];
-    if ((events & REQ_MTX_RELEASE) != 0) {
-      release(ctx);
+    if ((events & REQ_MTX_0_RELEASE) != 0) {
+      release(ctx, MTX_0);
+    if ((events & REQ_MTX_1_OBTAIN) != 0) {
+      obtain(ctx, MTX_1);
+      ++ctx->generation[id];
+    if ((events & REQ_MTX_1_RELEASE) != 0) {
+      release(ctx, MTX_1);
+    if ((events & REQ_MTX_2_OBTAIN) != 0) {
+      obtain(ctx, MTX_2);
+    if ((events & REQ_MTX_2_RELEASE) != 0) {
+      release(ctx, MTX_2);
+    if ((events & REQ_MTX_C11_OBTAIN) != 0) {
+      obtain_c11(ctx);
+    if ((events & REQ_MTX_C11_RELEASE) != 0) {
+      release_c11(ctx);
+    if ((events & REQ_MTX_POSIX_OBTAIN) != 0) {
+      obtain_posix(ctx);
+    if ((events & REQ_MTX_POSIX_RELEASE) != 0) {
+      release_posix(ctx);
+#endif
-static void test(void)
+static void set_up(test_context *ctx)
-  test_context *ctx = &test_instance;
+  int status;
+  size_t i;
   ctx->tasks[M] = rtems_task_self();
   start_task(ctx, A_1, worker, 1);
@@ -202,61 +334,264 @@ static void test(void)
   start_task(ctx, A_2_1, worker, 2);
   start_task(ctx, H, helper, 3);
-  sc = rtems_semaphore_create(
-    rtems_build_name(' ', 'M', 'T', 'X'),
-    1,
-    RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
-    0,
-    &ctx->mtx
-  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  for (i = 0; i < MTX_COUNT; ++i) {
+    sc = rtems_semaphore_create(
+      rtems_build_name(' ', 'M', 'T', 'X'),
+      1,
+      RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
+      0,
+      &ctx->mtx[i]
+    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  obtain(ctx);
-  request(ctx, A_1, REQ_MTX_OBTAIN);
+  status = mtx_init(&ctx->mtx_c11, mtx_plain);
+    int error;
+    pthread_mutexattr_t attr;
+    error = pthread_mutexattr_init(&attr);
+    error = pthread_mutexattr_setprotocol(&attr, PTHREAD_PRIO_INHERIT);
+    error = pthread_mutex_init(&ctx->mtx_posix, &attr);
+    error = pthread_mutexattr_destroy(&attr);
+#endif
+static void test_inherit(test_context *ctx)
+  request(ctx, A_1, REQ_MTX_0_OBTAIN);
   check_generations(ctx, NONE, NONE);
   assert_prio(ctx, M, 1);
-  release(ctx);
   check_generations(ctx, A_1, NONE);
   assert_prio(ctx, M, 3);
-  request(ctx, A_1, REQ_MTX_RELEASE);
+  request(ctx, A_1, REQ_MTX_0_RELEASE);
-  obtain(ctx);
-  request(ctx, A_2_0, REQ_MTX_OBTAIN);
-  request(ctx, A_2_1, REQ_MTX_OBTAIN);
+static void test_inherit_fifo_for_equal_priority(test_context *ctx)
+  request(ctx, A_2_0, REQ_MTX_0_OBTAIN);
+  request(ctx, A_2_1, REQ_MTX_0_OBTAIN);
-  release(ctx);
   assert_prio(ctx, A_1, 1);
   check_generations(ctx, A_1, A_2_0);
-  request(ctx, A_2_0, REQ_MTX_RELEASE);
+  request(ctx, A_2_0, REQ_MTX_0_RELEASE);
   check_generations(ctx, A_2_0, A_2_1);
-  request(ctx, A_2_1, REQ_MTX_RELEASE);
+  request(ctx, A_2_1, REQ_MTX_0_RELEASE);
   check_generations(ctx, A_2_1, NONE);
-static void Init(rtems_task_argument arg)
+static void test_deadlock_two_classic(test_context *ctx)
-  TEST_BEGIN();
+  request(ctx, A_1, REQ_MTX_1_OBTAIN);
+  check_generations(ctx, A_1, NONE);
+  check_generations(ctx, NONE, NONE);
+  deadlock_obtain(ctx, MTX_1);
+  request(ctx, A_1, REQ_MTX_1_RELEASE);
+static void test_deadlock_three_classic(test_context *ctx)
+  request(ctx, A_2_0, REQ_MTX_2_OBTAIN);
+  check_generations(ctx, A_2_0, NONE);
+  request(ctx, A_2_0, REQ_MTX_1_OBTAIN);
+  deadlock_obtain(ctx, MTX_2);
+  check_generations(ctx, A_1, A_2_0);
+  request(ctx, A_2_0, REQ_MTX_2_RELEASE);
+  request(ctx, A_2_0, REQ_MTX_1_RELEASE);
+static void test_deadlock_c11_and_classic(test_context *ctx)
+  obtain_c11(ctx);
+  request(ctx, A_1, REQ_MTX_C11_OBTAIN);
+  deadlock_obtain(ctx, MTX_0);
+  release_c11(ctx);
+  request(ctx, A_1, REQ_MTX_C11_RELEASE);
+static void test_deadlock_classic_and_c11(test_context *ctx)
+  deadlock_obtain_c11(ctx);
+static void test_deadlock_posix_and_classic(test_context *ctx)
+  request(ctx, A_1, REQ_MTX_POSIX_OBTAIN);
+  request(ctx, A_1, REQ_MTX_POSIX_RELEASE);
+#endif
+static void test_deadlock_classic_and_posix(test_context *ctx)
+  deadlock_obtain_posix(ctx);
+#endif
+static void tear_down(test_context *ctx)
+  size_t i;
+  for (i = 1; i < TASK_COUNT; ++i) {
+    sc = rtems_task_delete(ctx->tasks[i]);
+    sc = rtems_semaphore_delete(ctx->mtx[i]);
+  mtx_destroy(&ctx->mtx_c11);
+    int error;
+    error = pthread_mutex_destroy(&ctx->mtx_posix);
+#endif
-  test();
+static void Init(rtems_task_argument arg)
+  test_context *ctx = &test_instance;
+  rtems_resource_snapshot snapshot;
+  TEST_BEGIN();
+  rtems_resource_snapshot_take(&snapshot);
+  set_up(ctx);
+  test_inherit(ctx);
+  test_inherit_fifo_for_equal_priority(ctx);
+  test_deadlock_two_classic(ctx);
+  test_deadlock_three_classic(ctx);
+  test_deadlock_c11_and_classic(ctx);
+  test_deadlock_classic_and_c11(ctx);
+  test_deadlock_posix_and_classic(ctx);
+  test_deadlock_classic_and_posix(ctx);
+  tear_down(ctx);
+  rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
   TEST_END();
   rtems_test_exit(0);
+static void fatal_extension(
+  rtems_fatal_source source,
+  bool is_internal,
+  rtems_fatal_code error
+  if (
+    source == INTERNAL_ERROR_CORE
+      && !is_internal
+      && error == INTERNAL_ERROR_THREAD_QUEUE_DEADLOCK
+    longjmp(ctx->deadlock_return_context, 1);
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
 #define CONFIGURE_MAXIMUM_TASKS TASK_COUNT
-#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 3
+#define CONFIGURE_MAXIMUM_POSIX_MUTEXES 1
+#endif
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INITIAL_EXTENSIONS \
+  { .fatal = fatal_extension }, \
+  RTEMS_TEST_INITIAL_EXTENSION
 #define CONFIGURE_INIT_TASK_PRIORITY 3
diff --git a/testsuites/sptests/spmutex01/spmutex01.doc b/testsuites/sptests/spmutex01/spmutex01.doc
index 7951024..7bcb850 100644
--- a/testsuites/sptests/spmutex01/spmutex01.doc
+++ b/testsuites/sptests/spmutex01/spmutex01.doc
@@ -4,6 +4,10 @@ test set name: spmutex01
 directives:
+  - mtx_lock()
+  - mtx_unlock()
+  - pthread_mutex_lock()
+  - pthread_mutex_unlock()
   - rtems_semaphore_create()
   - rtems_semaphore_obtain()
   - rtems_semaphore_release()
@@ -12,3 +16,4 @@ concepts:
   - Ensure that priority inheritance mechanism works.
   - Ensure that thread priority queueing discipline works.
+  - Ensure that deadlock detection works in various combinations.
diff --git a/testsuites/sptests/spsyslock01/init.c b/testsuites/sptests/spsyslock01/init.c
index 5bf5d6a..1e0d4818 100644
--- a/testsuites/sptests/spsyslock01/init.c
+++ b/testsuites/sptests/spsyslock01/init.c
@@ -1,5 +1,5 @@
- * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2015, 2016 embedded brains GmbH.  All rights reserved.
  *  Dornierstr. 4
@@ -21,7 +21,7 @@
 #include <sys/lock.h>
 #include <limits.h>
-#include <pthread.h>
 #include <time.h>
@@ -35,8 +35,6 @@ const char rtems_test_name[] = "SPSYSLOCK 1";
 #define EVENT_MTX_PRIO_INV RTEMS_EVENT_2
-#define EVENT_MTX_DEADLOCK RTEMS_EVENT_3
 #define EVENT_REC_MTX_ACQUIRE RTEMS_EVENT_4
 #define EVENT_REC_MTX_RELEASE RTEMS_EVENT_5
@@ -56,7 +54,6 @@ typedef struct {
   rtems_id mid;
   rtems_id low;
   struct _Mutex_Control mtx;
-  struct _Mutex_Control deadlock_mtx;
   struct _Mutex_recursive_Control rec_mtx;
   struct _Condition_Control cond;
   struct _Semaphore_Control sem;
@@ -65,6 +62,7 @@ typedef struct {
   int eno[2];
   int generation[2];
   int current_generation[2];
 } test_context;
@@ -298,6 +296,19 @@ static void test_mtx_timeout_recursive(test_context *ctx)
   send_event(ctx, idx, EVENT_REC_MTX_RELEASE);
+static void test_mtx_deadlock(test_context *ctx)
+  struct _Mutex_Control *mtx = &ctx->mtx;
+  _Mutex_Acquire(mtx);
+  _Mutex_Release(mtx);
 static void test_condition(test_context *ctx)
   struct _Condition_Control *cond = &ctx->cond;
@@ -493,21 +504,6 @@ static void mid_task(rtems_task_argument arg)
   rtems_test_assert(0);
-#ifdef RTEMS_POSIX_API
-static void deadlock_cleanup(void *arg)
-  struct _Mutex_Control *deadlock_mtx = arg;
-   * The thread terminate procedure will dequeue us from the wait queue.  So,
-   * one release is sufficient.
-  _Mutex_Release(deadlock_mtx);
-  _Mutex_Destroy(deadlock_mtx);
-#endif
 static void high_task(rtems_task_argument idx)
@@ -553,22 +549,6 @@ static void high_task(rtems_task_argument idx)
-    if ((events & EVENT_MTX_DEADLOCK) != 0) {
-      struct _Mutex_Control *deadlock_mtx = &ctx->deadlock_mtx;
-      pthread_cleanup_push(deadlock_cleanup, deadlock_mtx);
-#endif
-      _Mutex_Initialize(deadlock_mtx);
-      _Mutex_Acquire(deadlock_mtx);
-      pthread_cleanup_pop(0);
-#endif
     if ((events & EVENT_REC_MTX_ACQUIRE) != 0) {
       _Mutex_recursive_Acquire(&ctx->rec_mtx);
@@ -670,6 +650,7 @@ static void test(void)
   test_prio_inv_recursive(ctx);
   test_mtx_timeout_normal(ctx);
   test_mtx_timeout_recursive(ctx);
+  test_mtx_deadlock(ctx);
   test_condition(ctx);
   test_condition_timeout(ctx);
   test_sem(ctx);
@@ -677,15 +658,11 @@ static void test(void)
   test_futex(ctx);
   test_sched();
-  send_event(ctx, 0, EVENT_MTX_DEADLOCK);
   sc = rtems_task_delete(ctx->mid);
   sc = rtems_task_delete(ctx->high[0]);
-#endif
   sc = rtems_task_delete(ctx->high[1]);
@@ -707,6 +684,24 @@ static void Init(rtems_task_argument arg)
   rtems_test_exit(0);
+  bool is_internal,
+  if (
+      && !is_internal
 #define CONFIGURE_MICROSECONDS_PER_TICK US_PER_TICK
@@ -714,7 +709,9 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_MAXIMUM_TASKS 4
 #define CONFIGURE_INIT_TASK_PRIORITY 4
 #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
1.8.4.5
