Porting BSD Mailbox for RPi
Mudit Jain muditjain18011995 at gmail.com
Fri Jun 10 09:40:28 UTC 2016
Hi,
The libbsd one is a concatenation of all the functions, generic as well as
bsp specific into one file.The recent version of FreeBSD implements
it such that bcm_sdhci.c uses generic functions defined in sdhci.c and
builds the driver specific to the bsp. This provides more modularity.
Another difference between the recent version and the libbsd one is in the
structures of *sdhci slot* and *software context.*
So modification of the libbsd version would finally result in the
concatenation of the two files namely , sdhci.c and bcm_sdhci.c from the
recent FreeBSD. Thus I replaced the entire sdhci.c. I had previously asked
regarding this. .
If modification of the libbsd sdhci.c is better alternative, that can be
done.
Mudit
On Fri, Jun 10, 2016 at 6:49 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 09/06/2016 19:20, Mudit Jain wrote:
>> Is this resource structure appropriate for mbox ?
>> Github Link <https://github.com/spark1729/rtems-libbsd/commits/RPI_SD>
> I may have missed something but the sdhci.c source looks like a recent
> version rather than the FreeBSD version libbsd is based on. Why is this?
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160610/7d516f28/attachment-0002.html>
