LM3S69xx BSP Qemu Error
Olufowobi, Habeeb habeeb.olufowobi at bison.howard.edu
Tue May 24 16:53:35 UTC 2016
Hi,
I was able to successfully built the lm3s69xx BSP. While I tried running
the hello.exe on qemu, I got the following hardware error.
Warning: nic stellaris_enet.0 has no peer
qemu: hardware error: ssys_read: Bad offset 0x6c
CPU #0:
R00=00000000 R01=00000000 R02=87800800 R03=c1000000
R04=400fe000 R05=400fe000 R06=07802810 R07=07802810
R08=00000000 R09=00000000 R10=00000000 R11=00000000
R12=00000000 R13=200010d8 R14=000003b5 R15=000003b4
PSR=60000173 -ZC- T svc32
FPSCR: 00000000
Aborted (core dumped)
I am not able to apply the patches in the BSP because they do not apply to
the current qemu.
I hope someone can assist on how to resolve this.
Thanking you for your much-anticipated response.
Best regards,
Habeeb
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160524/6847e3ea/attachment.html>
