Errors while building USB DWC OTG driver
Deval Shah deval.maker at gmail.com
Wed May 25 13:54:06 UTC 2016
On Wed, May 25, 2016 at 7:12 PM, Sebastian Huber <
> On 25/05/16 14:59, Deval Shah wrote:
>> On Wed, May 25, 2016 at 3:07 PM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de <mailto:
>> sebastian.huber at embedded-brains.de>> wrote:
>>     If you get
>>     On 25/05/16 10:19, Deval Shah wrote:
>>         I got the following result.
>>         nm: 'a.out': No such file
>>     from
>>     nm `find build -name '*bcm283x_dwc_fdt*.o`
>>     the this is the first issue you have to resolve. Read the man
>>     pages of nm and find to figure out what these commands do.
>>     You must have object files for all your driver modules.
>> I understood the problem. Driver for bcm283x is no getting built. Is
>> there any documentation availible for porting a driver to rtems-libbsd ? So
>> that I can verify necessary steps for the code I cherry-picked or if
>> required do the process from scratch.
> See "How to import code from FreeBSD" in libbsd.txt.
Great ! Thanks a lot.
> Please improve the documentation while you work on this.
Surely I will.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20160525/0892d242/attachment-0002.html>
