GSoC 2017 -- initial proof
Sun Apr 2 17:53:56 UTC 2017
On Sun, Apr 2, 2017 at 12:33 PM, Tanu Hari Dixit <tokencolour at gmail.com>
wrote:
> Hi Andy,
> Joel and Gedare pointed me to the following:
> https://devel.rtems.org/wiki/Developer/Projects/Open/
> PythonCoverageReporting
> https://devel.rtems.org/ticket/2261
> http://kmiesowicz.blogspot.in/p/esa-socis-2014.html
> Last link is to the work done by a previous student.
> Hope this helps.
> My proposal does not take covoar into consideration. Though, I have
> planned to produce xml reports from rtems-tester that can be
> integrated into coverage testing. Also, I have planned to use this xml
> data to get plots (for visualizing results) as a stretch goal (you can
> look in the "Future Improvements" Section in my proposal).
covoar directly produces the html and text reports we have now. My
recollection is that it doesn't have to be touched and that the trick
is invoking it on a more focused basis than Core vs Developmental.
So invoke covoar from rtems-tester mulitple times on a single run
of the tests rather than twice at most.
Personally, I think Core is still a good description for the core of
the tasking (e.g. score, rtems, sapi, and posix) and that each
directory other than that should be individual. But that's my marketing
view. I could easily be argued that for consistency, it should all
be on a per directory basis.
At some point, we might discuss covoar writing a neutral format
and using Python to do more but that is pure conjecture. I have
no idea what the intermediate format would be. Writing Sphinx
output for reports would be desirable from covoar. :)
--joel
> Regards,
> Tanu Hari Dixit.
> On Sun, Apr 2, 2017 at 6:50 PM, Gedare Bloom <gedare at rtems.org> wrote:
> > Joel's e-mail client messed up my reply thread. ;) Andy, have a read
> > through https://gedare.github.io/pdf/FelShe15A.pdf if you haven't
> > found it already.
> > Getting qemu-couverture to build via RSB and then integrating the
> > coverage scripts into rtems-test, would be a good start to a project.
> > There is a student (Tanu)oar dir who has proposed rtems-test
> improvements, so
> > you two would need to coordinate efforts for this piece to avoid too
> > much duplicated work/waste. Improvements to the reports etc are also
> > welcome, and then of course using the reports to guide code
> > refactoring to improve coverage is somewhat open-ended.
> > -Gedare
> > On Sat, Apr 1, 2017 at 9:34 PM, Joel Sherrill <joel at rtems.org> wrote:
> >> On Apr 1, 2017 7:59 PM, "Andy MacGregor" <amacgregor.2018 at comcast.net>
> >> wrote:
> >> On 03/31/2017 09:52 PM, Gedare Bloom wrote:
> >> Don't forget the deadline is Monday to submit your Final
> >> PDF and proof of enrollment. The "Final" PDF can be submitted multiple
> >> times, so go ahead and submit it when you finish a first draft. Add
> >> your draft proposal to the tracking table at
> >> https://devel.rtems.org/wiki/GSoC/2017 also, to get some possible
> >> feedback.
> >> Thanks for the welcome! (I realize I am late to the GSOC application
> table).
> >> I'm set on improving code coverage of the testsuite, but I found some
> >> questions as I'm starting to look into how its done.
> >> The link on the wiki to the current code status is currently broken, so
> I
> >> tried to generate a sample coverage report for 4.12 using ./do_coverage,
> >> ./run_coverage and ./coverage_cron as suggested on the wiki here but
> without
> >> any luck. Is there an up to date coverage report available?
> >> I modified the VERSIONS-COVERAGE file like the wiki said, and once that
> >> didn't work dug around in the script but fix it myself quickly.
> >> Could updating these coverage analysis scripts be a viable component of
> a
> >> GSOC proposal?
> >> Yes. In fact, the idea was to rework the coverage scripts in shell to be
> >> part of the rtems-tester package and in Python. There is some work on
> this
> >> by a previous student which you can find or one of us can dig out.
> Starting
> >> with it, making it work across multiple BSPs, independent of any hard
> coded
> >> paths, improving the output (we did not get far enough that I recall
> >> worrying about the quality of the output), etc could be a fair amount of
> >> work.
> >> Also we have privately discussed switching the RSB qemu upstream source
> to
> >> GNATCoverage at GitHub. This is a coverage and embedded focused
> downstream
> >> which includes the coverage trace output I used for the qemu support in
> >> covoar. I'm
> >> In addition, I'd like to actually make some improvements the code
> coverage
> >> itself.
> >> The most recent information I could find was these bar graphs from 2009.
> >> If these graphs reflect the current coverage state, I think that
> improving
> >> coverage for the i386/pc386,
> >> would be interesting because there is room for improvement in both the
> >> Baseline and Developmental groups (if these coverage statistics are up
> to
> >> date).
> >> It doesn't matter which BSP you choose for coverage since the code and
> tests
> >> are the same.
> >> This also reminds me of the other improvements we had wanted. We wanted
> to
> >> switch from Baseline and developmental to a more directory oriented
> approach
> >> for the reports. For example, the reports should be at a granularity of
> say
> >> the Dos file system or shell as reports. The way reports are generated
> now
> >> it results in a skewed view when a large body of code is added to the
> >> developmental set. Adding the Dos filesystem resulted in a 15-20% drop
> in
> >> the coverage reported in the Developmental set. That is a bad way to
> report
> >> and misleading. It detracts from the directories which have near 100%
> >> coverage.
> >> Does anyone know of a good reason to choose another BSP over i386/pc386?
> >> Users fly the SPARC leon3 and not the pc386. :)
> >> I've just posted a draft of my proposal to the GSOC page.
> >> If there's any feedback I'll be sure to update my proposal in time.
> >> Dinner time here. Hopefully my feedback makes sense and you can
> incorporate
> >> it.
> >> -Andy MacGregor
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> >> devel mailing list
> >> devel at rtems.org
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170402/7f52c3b2/attachment-0002.html>
