Build error on rtems master
Thu Feb 2 21:08:55 UTC 2017
On Thu, Feb 2, 2017 at 1:52 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Maybe the default-configuration.c should set max processors to 1?
I would prefer it not be set at all in non-SMP builds.
> On Thu, Feb 2, 2017 at 2:51 PM, Joel Sherrill <joel at rtems.org> wrote:
> > That sounds like a reasonable error and fix. Please send a patch
> > to the mailing list.
> > I assume the build of all BSPs I just started is likely to fail if
> > I didn't enable SMP. :)
> > --joel
> > On Thu, Feb 2, 2017 at 1:07 PM, Kirspel, Kevin <Kevin-Kirspel at idexx.com>
> > wrote:
> >> I’m getting a build error with the latest master due to the changes
> >> removing CONFIGURE_SMP_APPLICATION.  The default-configuration.c file
> sets
> >> CONFIGURE_SMP_MAXIMUM_PROCESSORS to 32 thus enabling the internal
> >> _CONFIGURE_SMP_APPLICATION define on targets without SMP.  I had to add
> a
> >> #if defined(RTEMS_SMP)
> >> guard around
> >> #if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1
> >>   #define _CONFIGURE_SMP_APPLICATION
> >> #endif
> >> to get it to compile.  I was building for the xilinx_zynq_a9_qemu BSP.
> >> Kevin Kirspel
> >> Electrical Engineer - Sr. Staff
> >> Idexx Roswell
> >> 235 Hembree Park Drive
> >> Roswell GA 30076
> >> Tel: (770)-510-4444 ext. 81642
> >> Direct: (770)-688-1642
> >> Fax: (770)-510-4445
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170202/8611b92f/attachment-0002.html>
