Regarding running one test
    Gedare Bloom
    gedare at rtems.org
    Sat Feb  4 21:33:49 UTC 2017
After you do a git-pull you should usually re-run bootstrap, delete
your build, and re-run configure and make. This is especially true if
you re-build a toolchain, at least to get started.
On Sat, Feb 4, 2017 at 10:26 AM, Tanu Hari Dixit <tokencolour at gmail.com> wrote:
> Hi Kevin, Kuan-Hsun,
> Thank you for the answer.
> I have run into a problem before trying the above solutions for myself,
> while updating my local copy of the rtems repository with upstream with "git
> pull".
> After I updated the local copy, I built the sparc toolset with
> ../source-builder/sb-set-builder --log=l-sparc-test.txt
> --prefix=$HOME/development/rtems/4.12 4.12/rtems-sparc
> Then I ran  ./bootstrap -c && ./bootstrap -p && ./bootstrap so as to
> bootstrap.
> Then from  builds/erc32_test(subdirectory) I ran
> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$ ../../rtems/configure
> --target=sparc-rtems4.12 --enable-rtemsbsp=erc32 --enable-tests
> --prefix=${HOME}/development/rtems/install_path_test
> And when I ran make, It showed the following error;
> make[2]: Leaving directory
> `/home/thd/development/rtems/src/builds/erc32_test/tools/build'
> make[1]: Leaving directory
> Making all in tools/cpu
> make[1]: Entering directory
> `/home/thd/development/rtems/src/builds/erc32_test/tools/cpu'
> Making all in generic
> make[2]: Entering directory
> `/home/thd/development/rtems/src/builds/erc32_test/tools/cpu/generic'
> make[2]: Nothing to be done for `all'.
> make[2]: Nothing to be done for `all-am'.
> Making all in testsuites/tools
> `/home/thd/development/rtems/src/builds/erc32_test/testsuites/tools'
> `/home/thd/development/rtems/src/builds/erc32_test/testsuites/tools/generic'
> Making all in sparc-rtems4.12/c
> `/home/thd/development/rtems/src/builds/erc32_test/sparc-rtems4.12/c'
> Making all in .
> Making all in erc32
> `/home/thd/development/rtems/src/builds/erc32_test/sparc-rtems4.12/c/erc32'
> make[2]: *** No rule to make target `all'.  Stop.
> make[1]: *** [all-recursive] Error 1
> make: *** [all-recursive] Error 1
> I have ran into this problem more than once. When last time this happened, I
> thought I must have messed up somewhere in the git (or rtems) workflow and
> hence decided to make a clean clone of the rtems repo and continue with it.
> I also tried git reset --hard <hash-number> last time and had no luck.
> Right now, I did not do a hard reset and currently git reflog shows the
> following output:
> 239dd35 HEAD@{0}: pull: Fast-forward
> ffa885a HEAD@{1}: clone: from git://git.rtems.org/rtems.git
> git status shows
> thd at thd-Inspiron-5537:~/development/rtems/src/rtems$ git status
> On branch master
> Your branch is up-to-date with 'origin/master'.
> Changes not staged for commit:
>   (use "git add <file>..." to update what will be committed)
>   (use "git checkout -- <file>..." to discard changes in working directory)
>     modified:   c/src/lib/libbsp/powerpc/acinclude.m4
> no changes added to commit (use "git add" and/or "git commit -a")
> I don't know what I am missing. Do I need to do something before pulling
> from upstream? How do I rectify this? Please help me with this.
> Thank you,
> Tanu Hari Dixit.
> On Sat, Feb 4, 2017 at 6:47 PM, Kuan Hsun Chen
> <kuan-hsun.chen at tu-dortmund.de> wrote:
>> Or alternatively you can prepare simulator like qemu to executed each of
>> it after compiling the source tree.
>> Like this in testsuites/hello/:
>> qemu-system-arm -no-reboot -nographic -M realview-pbx-a9 -m 256M -kernel \
>> hello.exe -smp 4
>> Best,
>> Kuan-Hsun
>> 2017-02-04 14:12 GMT+01:00 Kirspel, Kevin <Kevin-Kirspel at idexx.com>:
>>> I use the rtems tester.
>>> ftp://ftp.rtems.org/pub/rtems/people/chrisj/rtems-tester/rtems-tester.html
>>> Kevin Kirspel
>>> Electrical Engineer - Sr. Staff
>>> Idexx Roswell
>>> 235 Hembree Park Drive
>>> Roswell GA 30076
>>> Tel: (770)-510-4444 ext. 81642
>>> Direct: (770)-688-1642
>>> Fax: (770)-510-4445
>>> -----Original Message-----
>>> From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Tanu Hari Dixit
>>> Sent: Saturday, February 04, 2017 12:23 AM
>>> To: rtems-devel at rtems.org <devel at rtems.org>
>>> Subject: Regarding running one test
>>> Hello all,
>>> How do I run a single test from the testsuites? I want to run one test
>>> from the rtems/testsuites/fstests. How do I go about doing that?
>>> Regards,
>>> Tanu Hari Dixit.
>>> devel mailing list
>>> devel at rtems.org
>>> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwICAg&c=2do6VJGs3LvEOe4OFFM1bA&r=HDiJ93ANMEQ32G5JGdpyUxbdebuwKHBbeiHMr3RbR74&m=zH4W9XS8-wD5iyDXdo5SEtjZwr3gbIp9TJjx8-z2cS8&s=mU8IyO6GG8v94eNhQoI76FuuhiadOCFEoiJ3HdxyrrQ&e=
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> M.Sc. Kuan-Hsun Chen
>> TU Dortmund
>> Department of Computer Science 12
>> Design Automation of Embedded Systems
>> Otto-Hahn-Strasse 16, Room 102
>> 44227 Dortmund
>> Germany
>> Phone:  +49 231 755 6124
>> Mail:   kuan-hsun.chen at tu-dortmund.de
> devel mailing list
> devel at rtems.org
