[PATCH 6/8] Add support for LPC32XX USB driver
Kevin Kirspel kevin-kirspel at idexx.com
Fri Jan 27 05:32:24 UTC 2017
 freebsd/sys/dev/usb/controller/ohci.h      |  2 --
 rtemsbsd/sys/dev/usb/controller/lpc_ohci.c | 19 ++++++++++++++++---
 rtemsbsd/sys/dev/usb/usb_otg_transceiver.h |  1 +
 3 files changed, 17 insertions(+), 5 deletions(-)
 mode change 100644 => 100755 freebsd/sys/dev/usb/controller/ohci.h
 mode change 100644 => 100755 rtemsbsd/sys/dev/usb/usb_otg_transceiver.h
diff --git a/freebsd/sys/dev/usb/controller/ohci.h b/freebsd/sys/dev/usb/controller/ohci.h
old mode 100644
new mode 100755
index d020d99..a650ce1
--- a/freebsd/sys/dev/usb/controller/ohci.h
+++ b/freebsd/sys/dev/usb/controller/ohci.h
@@ -234,9 +234,7 @@ typedef struct ohci_softc {
 	struct ohci_ed *sc_bulk_p_last;
 	struct ohci_ed *sc_isoc_p_last;
 	struct ohci_ed *sc_intr_p_last[OHCI_NO_EDS];
-#ifndef __rtems__
 	void   *sc_intr_hdl;
-#endif /* __rtems__ */
 	device_t sc_dev;
 	bus_size_t sc_io_size;
 	bus_space_tag_t sc_io_tag;
diff --git a/rtemsbsd/sys/dev/usb/controller/lpc_ohci.c b/rtemsbsd/sys/dev/usb/controller/lpc_ohci.c
index 05c169a..4c6ef91 100755
--- a/rtemsbsd/sys/dev/usb/controller/lpc_ohci.c
+++ b/rtemsbsd/sys/dev/usb/controller/lpc_ohci.c
@@ -99,6 +99,7 @@ static void lpc_usb_host_clock_enable(device_t dev, struct ohci_softc *);
 static void lpc_otg_status_and_control(device_t dev, struct ohci_softc *);
 static rtems_interval lpc_usb_timeout_init(void);
 static bool lpc_usb_timeout_not_expired(rtems_interval start);
+static void lpc_usb_delay(uint32_t ms);
 static int lpc_otg_clk_ctrl(device_t dev, struct ohci_softc *sc, uint32_t otg_clk_ctrl);
 static int lpc_otg_i2c_wait_for_receive_fifo_not_empty(struct ohci_softc *sc);
 static int lpc_otg_i2c_wait_for_transaction_done(struct ohci_softc *sc);
@@ -192,6 +193,8 @@ lpc_ohci_attach(device_t dev)
   if (eno != 0) {
     goto fail;
+  //without the delay, _bsd_usbd_setup_device_desc: getting device descriptor at addr 2 failed, USB_ERR_IOERROR
+  lpc_usb_delay(10);
 #endif /* BSP_USB_OTG_TRANSCEIVER_I2C_ADDR */
   lpc_usb_host_clock_enable(dev, sc);
@@ -311,7 +314,17 @@ static bool lpc_usb_timeout_not_expired(rtems_interval start)
   rtems_interval elapsed = rtems_clock_get_ticks_since_boot() - start;
-  return elapsed < rtems_clock_get_ticks_per_second() / 10;
+  return elapsed < (rtems_clock_get_ticks_per_second() / 10);
+  rtems_interval end;
+  end = rtems_clock_get_ticks_since_boot() + RTEMS_MILLISECONDS_TO_TICKS(ms);
+  while (rtems_clock_get_ticks_since_boot() < end) {
+    /* Wait */
@@ -428,7 +441,7 @@ static int ohci_lpc_otg_transceiver_suspend(device_t dev, struct ohci_softc *sc)
 static int
-ohci_lpc_resume(device_t dev)
+lpc_ohci_resume(device_t dev)
   struct ohci_softc *sc = device_get_softc(dev);
   int eno = 0;
@@ -475,7 +488,7 @@ static device_method_t lpc_ohci_methods[] = {
 	DEVMETHOD(device_attach,	lpc_ohci_attach),
 	DEVMETHOD(device_detach,	lpc_ohci_detach),
   DEVMETHOD(device_suspend, bus_generic_suspend),
-  DEVMETHOD(device_resume,  ohci_lpc_resume),
+  DEVMETHOD(device_resume,  lpc_ohci_resume),
 	DEVMETHOD(device_shutdown,	bus_generic_shutdown),
 	/* Bus interface */
diff --git a/rtemsbsd/sys/dev/usb/usb_otg_transceiver.h b/rtemsbsd/sys/dev/usb/usb_otg_transceiver.h
old mode 100644
new mode 100755
index 1e6b738..249d6a7
--- a/rtemsbsd/sys/dev/usb/usb_otg_transceiver.h
+++ b/rtemsbsd/sys/dev/usb/usb_otg_transceiver.h
@@ -88,6 +88,7 @@ struct usb_otg_transceiver {
 	uint16_t vendor_id;
 	uint16_t product_id;
 	uint8_t i2c_addr;
+	void* softc;
 int usb_otg_transceiver_read(
1.9.1
