[PATCH] rtems-test-check: Make exclude work again.
Stavros Passas stavros.passas at movidius.com
Tue Jan 17 15:34:15 UTC 2017
Hi Joel,
Yesterday, with the creation of the ticket about the issue, (
https://devel.rtems.org/ticket/2867)
I also uploaded the patch that was fixing it -- after Chris's suggestion
over email.
The patch was created with my full credentials, so you can take them from
here:
https://devel.rtems.org/attachment/ticket/2867/fix-2867.patch
Best Regards,
   Stavros
On 17 January 2017 at 14:08, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Jan 16, 2017 at 5:12 PM, Chris Johns <chrisj at rtems.org> wrote:
>> This change looks wrong. Moving test loop out of the if testdata block
>> means variables in the test loop are not defined. I consider it a script
>> bug to assume it is ok to reference a variable that is not declared
>> because it is ambiguous if this intended behavior or a bug.
>> Starvos sent me this change a few days ago and it looks good. I am
>> hoping he will make a patch we can merge so he can have the credit ..
>> diff --git a/tools/build/rtems-test-check b/tools/build/rtems-test-check
>> index e02f8e9..108b788 100755
>> --- a/tools/build/rtems-test-check
>> +++ b/tools/build/rtems-test-check
>> @@ -32,7 +32,11 @@ done
>>  case ${mode} in
>>   exclude)
>> -   output=${tests}
>> +   if test -f $testdata; then
>> +     output=""
>> +   else
>> +     output="${tests}"
>> +   fi
>>   flags)
>>     if [ $test_count != 1 ]; then
>> Are you in a position to test this change?
> I am starting a test sweep of this now. I will need Starvos's proper
> name and email to commit it though.
> --joel
>> Chris
>> On 17/1/17 6:24 am, Joel Sherrill wrote:
>> > closes #2867.
>> >  tools/build/rtems-test-check | 90 ++++++++++++++++++++++--------
>> >  1 file changed, 45 insertions(+), 45 deletions(-)
>> > index e02f8e9..e8acde0 100755
>> > @@ -32,7 +32,6 @@ done
>> >  case ${mode} in
>> >   exclude)
>> > -   output=${tests}
>> >   flags)
>> > @@ -99,52 +98,53 @@ if test -f $testdata; then
>> >      testdata=$ntd
>> >    done
>> > -  for t in ${tests};
>> > -  do
>> > -    case ${mode} in
>> > -      exclude)
>> > -        allow="yes"
>> > -        for dt in ${excluded_tests};
>> > -        do
>> > -          if test ${t} = ${dt}; then
>> > -            allow="no"
>> > -          fi
>> > -        done
>> > -        if test ${allow} = yes; then
>> > -          output="${output} ${t}"
>> > -        fi
>> > -      flags)
>> > -        allow="no"
>> > -        for et in ${expected_fails};
>> > -        do
>> > -          if test ${t} = ${et}; then
>> > -            allow="yes"
>> > -          fi
>> > -        done
>> > -          output="-DTEST_STATE_EXPECTED_FAIL=1"
>> > -        fi
>> > -        allow="no"
>> > -        for it in ${indeterminates};
>> > -        do
>> > -          if test ${t} = ${it}; then
>> > -            allow="yes"
>> > -          fi
>> > -        done
>> > -          output="${output} -DTEST_STATE_INDETERMINATE=1"
>> > -        fi
>> > -        echo "error: invalid mode" 1>&2
>> > -        echo "INVALID-TEST-DATA"
>> > -        exit 1
>> > -    esac
>> > -  done
>> >  fi
>> > +for t in ${tests};
>> > +do
>> > +  case ${mode} in
>> > +    exclude)
>> > +      allow="yes"
>> > +      for dt in ${excluded_tests};
>> > +      do
>> > +     if test ${t} = ${dt}; then
>> > +       allow="no"
>> > +     fi
>> > +      done
>> > +      if test ${allow} = yes; then
>> > +     output="${output} ${t}"
>> > +      fi
>> > +    flags)
>> > +      allow="no"
>> > +      for et in ${expected_fails};
>> > +      do
>> > +     if test ${t} = ${et}; then
>> > +       allow="yes"
>> > +     fi
>> > +      done
>> > +     output="-DTEST_STATE_EXPECTED_FAIL=1"
>> > +      fi
>> > +      allow="no"
>> > +      for it in ${indeterminates};
>> > +      do
>> > +     if test ${t} = ${it}; then
>> > +       allow="yes"
>> > +     fi
>> > +      done
>> > +     output="${output} -DTEST_STATE_INDETERMINATE=1"
>> > +      fi
>> > +      echo "error: invalid mode" 1>&2
>> > +      echo "INVALID-TEST-DATA"
>> > +      exit 1
>> > +  esac
>> > +done
>> >  echo ${output}
>> >  exit 0
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170117/e4e35f63/attachment-0002.html>
