[PATCH v5 2/2] psxtests: Add a mmap dedicated test case
Kevin Kirspel kevin-kirspel at idexx.com
Thu Jun 29 14:36:44 UTC 2017
Updates #2859
 testsuites/psxtests/Makefile.am             |   1 +
 testsuites/psxtests/configure.ac            |   1 +
 testsuites/psxtests/psxmmap01/Makefile.am   |  22 ++
 testsuites/psxtests/psxmmap01/init.c        | 352 ++++++++++++++++++++++++++++
 testsuites/psxtests/psxmmap01/psxmmap01.scn |   0
 testsuites/psxtests/psxmmap01/system.h      |  31 +++
 testsuites/psxtests/psxmmap01/test_driver.c |  67 ++++++
 testsuites/psxtests/psxmmap01/test_driver.h |  14 ++
 testsuites/psxtests/psxmmap01/test_helper.c |  32 +++
 testsuites/psxtests/psxmmap01/test_helper.h |  41 ++++
 10 files changed, 561 insertions(+)
 create mode 100644 testsuites/psxtests/psxmmap01/Makefile.am
 create mode 100644 testsuites/psxtests/psxmmap01/init.c
 create mode 100644 testsuites/psxtests/psxmmap01/psxmmap01.scn
 create mode 100644 testsuites/psxtests/psxmmap01/system.h
 create mode 100644 testsuites/psxtests/psxmmap01/test_driver.c
 create mode 100644 testsuites/psxtests/psxmmap01/test_driver.h
 create mode 100644 testsuites/psxtests/psxmmap01/test_helper.c
 create mode 100644 testsuites/psxtests/psxmmap01/test_helper.h
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 7bcea46..cccdb39 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -85,6 +85,7 @@ _SUBDIRS += psxrwlock01
 _SUBDIRS += psxsem01
 _SUBDIRS += psxshm01
 _SUBDIRS += psxshm02
+_SUBDIRS += psxmmap01
 _SUBDIRS += psxsignal01
 _SUBDIRS += psxsignal02
 _SUBDIRS += psxsignal03
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 1de1312..96a0149 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -190,6 +190,7 @@ psxrwlock01/Makefile
 psxsem01/Makefile
 psxshm01/Makefile
 psxshm02/Makefile
+psxmmap01/Makefile
 psxsignal01/Makefile
 psxsignal02/Makefile
 psxsignal03/Makefile
diff --git a/testsuites/psxtests/psxmmap01/Makefile.am b/testsuites/psxtests/psxmmap01/Makefile.am
new file mode 100644
index 0000000..57b0087
--- /dev/null
+++ b/testsuites/psxtests/psxmmap01/Makefile.am
@@ -0,0 +1,22 @@
+rtems_tests_PROGRAMS = psxmmap01
+psxmmap01_SOURCES = init.c test_helper.c test_driver.c system.h
+dist_rtems_tests_DATA = psxmmap01.scn
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/include
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(psxmmap01_OBJECTS)
+LINK_LIBS = $(psxmmap01_LDLIBS)
+psxmmap01$(EXEEXT): $(psxmmap01_OBJECTS) $(psxmmap01_DEPENDENCIES)
+	@rm -f psxmmap01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxmmap01/init.c b/testsuites/psxtests/psxmmap01/init.c
index 0000000..eb1c747
--- /dev/null
+++ b/testsuites/psxtests/psxmmap01/init.c
@@ -0,0 +1,344 @@
+ * Copyright (c) 2009 Simon L. Nielsen <simon at FreeBSD.org>,
+ *      Bjoern A. Zeeb <bz at FreeBSD.org>
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+#include "pritime.h"
+#include "test_helper.h"
+#include "test_driver.h"
+#include <sys/mman.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <string.h>
+const char rtems_test_name[] = "PSX MMAP01";
+const char test_driver_name[] = "/dev/test_driver";
+static const struct {
+  void  *addr;
+  int ok;
+} map_at_zero_tests[] = {
+  { (void *)0,                    0 },
+  { (void *)1,                    0 },
+  { (void *)(PAGE_SIZE - 1),      0 },
+  { (void *)PAGE_SIZE,            1 },
+  { (void *)-1,                   0 },
+  { (void *)(-PAGE_SIZE),         0 },
+  { (void *)(-1 - PAGE_SIZE),     0 },
+  { (void *)(-1 - PAGE_SIZE - 1), 0 },
+  { (void *)(0x1000 * PAGE_SIZE), 1 },
+#define MAP_AT_ZERO_NITEMS (sizeof(map_at_zero_tests) / sizeof(map_at_zero_tests[0]))
+static void* checked_mmap(
+  int prot,
+  int flags,
+  int fd,
+  int error,
+  const char *msg
+  void *p;
+  int pagesize, err;
+  rtems_test_assert((pagesize = getpagesize()) > 0);
+  p = mmap(NULL, pagesize, prot, flags, fd, 0);
+  if (p == MAP_FAILED) {
+    if (error == 0)
+      mmap_test_assert(0, "%s failed with errno %d\n", msg, errno);
+    else {
+      err = errno;
+      mmap_test_assert_equal(error, err,
+          "%s failed with wrong errno %d (expected %d)\n", msg,
+          errno, error);
+  } else {
+    mmap_test_check(error == 0, "%s succeeded\n", msg);
+    munmap(p, pagesize);
+  return p;
+static void mmap_map_at_zero( void )
+  void *p;
+  unsigned int i;
+  for (i = 0; i < MAP_AT_ZERO_NITEMS; i++) {
+    p = mmap((void *)map_at_zero_tests[i].addr, PAGE_SIZE,
+        PROT_READ | PROT_WRITE | PROT_EXEC, MAP_ANON | MAP_FIXED | MAP_PRIVATE,
+        -1, 0);
+      mmap_test_assert( map_at_zero_tests[i].ok == 0,
+          "mmap(%08lX, ...) failed\n", (uint32_t)map_at_zero_tests[i].addr );
+    } else {
+      mmap_test_check( map_at_zero_tests[i].ok == 1,
+          "mmap(%p, ...) succeeded: p=%p\n",
+          map_at_zero_tests[i].addr, p );
+static void mmap_bad_arguments( void )
+  int devfd, pagesize, shmfd, zerofd;
+  void* p;
+  rtems_test_assert((devfd = open(&test_driver_name[0], O_RDONLY)) >= 0);
+  rtems_test_assert((shmfd = shm_open("/shm", O_CREAT | O_RDWR, 0644)) >= 0);
+  rtems_test_assert(ftruncate(shmfd, pagesize) == 0);
+  rtems_test_assert((zerofd = open("/dev/zero", O_RDONLY)) >= 0);
+   * These should normally work on FREEBSD. Test cases below that fail are
+   * due to unsupported features in RTEMS.
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_ANON, -1, 0,
+      "simple MAP_ANON");
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_SHARED, shmfd, 0,
+      "simple shm fd shared");
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_PRIVATE, shmfd, 0,
+      "simple shm fd private");
+  /* RTEMS cannot protect against writes so this will fail */
+  checked_mmap(PROT_READ, MAP_SHARED, zerofd, ENOTSUP,
+      "simple /dev/zero shared");
+    * Repeat with no write protection. Will fail because of unimplemented
+    * mmap handler in /dev/zero.
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_SHARED, zerofd, ENOTSUP,
+  /* RTEMS /dev/zero is a character device so this will fail */
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_PRIVATE, zerofd, EINVAL,
+      "simple /dev/zero private");
+  checked_mmap(PROT_READ, MAP_SHARED, devfd, ENOTSUP,
+      "simple test driver shared");
+    * Repeat with no write protection. Should fail because of unimplemented
+    * mmap handler in /dev/null.
+  p = checked_mmap(PROT_READ | PROT_WRITE, MAP_SHARED, devfd, 0,
+  rtems_test_assert(p == &test_data[0]);
+  /* Extra PROT flags. */
+  checked_mmap(PROT_READ | PROT_WRITE | 0x100000, MAP_ANON, -1, EINVAL,
+      "MAP_ANON with extra PROT flags");
+  checked_mmap(0xffff, MAP_SHARED, shmfd, EINVAL,
+      "shm fd with garbage PROT");
+  /* Undefined flag. */
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_ANON | MAP_RESERVED0080, -1,
+      EINVAL, "Undefined flag");
+  /* Both MAP_SHARED and MAP_PRIVATE */
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_ANON | MAP_PRIVATE |
+      MAP_SHARED, -1, EINVAL, "MAP_ANON with both SHARED and PRIVATE");
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_SHARED, shmfd,
+      EINVAL, "shm fd with both SHARED and PRIVATE");
+  /* At least one of MAP_SHARED or MAP_PRIVATE without ANON */
+  checked_mmap(PROT_READ | PROT_WRITE, 0, shmfd, EINVAL,
+      "shm fd without sharing flag");
+  /* MAP_ANON with sharing flag. Will fail on RTEMS*/
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_ANON | MAP_SHARED, -1, EINVAL,
+      "shared MAP_ANON");
+  /* MAP_ANON with private flag*/
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_ANON | MAP_PRIVATE, -1, 0,
+      "private MAP_ANON");
+  /* MAP_ANON should require an fd of -1. */
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_ANON | MAP_PRIVATE, 0, EINVAL,
+      "MAP_ANON with fd != -1");
+   * Writable MAP_SHARED should fail on read-only descriptors. Will fail
+   * on RTEMS because of unimplemented mmap handler in /dev/null and the fact
+   * that there is no read only protection.
+      "MAP_SHARED of read-only /dev/zero");
+   * Character devices other than /dev/zero do not support private
+   * mappings. RTEMS cannot protect against writes so this will fail with
+   * ENOTSUP
+  checked_mmap(PROT_READ, MAP_PRIVATE, devfd, ENOTSUP,
+      "MAP_PRIVATE of test driver");
+  checked_mmap(PROT_READ | PROT_WRITE, MAP_PRIVATE, devfd, EINVAL,
+  close(devfd);
+  close(shmfd);
+  close(zerofd);
+static void mmap_dev_zero_private( void )
+  char *p1, *p2, *p3;
+  int fd, pagesize;
+  /*int i*/
+  rtems_test_assert((fd = open("/dev/zero", O_RDONLY)) >= 0);
+  /* This should not return MAP_FAILED but does on RTEMS */
+  p1 = mmap(NULL, pagesize, PROT_READ | PROT_WRITE, MAP_PRIVATE, fd, 0);
+  /*rtems_test_assert(p1 != MAP_FAILED);*/
+  rtems_test_assert(p1 == MAP_FAILED);
+  p2 = mmap(NULL, pagesize, PROT_READ | PROT_WRITE, MAP_PRIVATE, fd, 0);
+  /*rtems_test_assert(p2 != MAP_FAILED);*/
+  rtems_test_assert(p2 == MAP_FAILED);
+  /* These tests can not run due to failures above */
+  /*for (i = 0; i < pagesize; i++)
+    mmap_test_assert_equal(0, p1[i], "byte at p1[%d] is %x", i, p1[i]);
+  rtems_test_assert(memcmp(p1, p2, pagesize) == 0);
+  p1[0] = 1;
+  rtems_test_assert(p2[0] == 0);
+  p2[0] = 2;
+  rtems_test_assert(p1[0] == 1);*/
+  p3 = mmap(NULL, pagesize, PROT_READ | PROT_WRITE, MAP_PRIVATE, fd, 0);
+  /*rtems_test_assert(p3 != MAP_FAILED);*/
+  rtems_test_assert(p3 == MAP_FAILED);
+  /*rtems_test_assert(p3[0] == 0);
+  munmap(p1, pagesize);
+  munmap(p2, pagesize);
+  munmap(p3, pagesize);*/
+  close(fd);
+static void mmap_dev_zero_shared( void )
+  int fd, pagesize;
+  /*int i*/
+  rtems_test_assert((fd = open("/dev/zero", O_RDWR)) >= 0);
+  p1 = mmap(NULL, pagesize, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0);
+  p2 = mmap(NULL, pagesize, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0);
+  p1[0] = 1;
+  p2[0] = 2;
+  p3 = mmap(NULL, pagesize, PROT_READ | PROT_WRITE, MAP_SHARED, fd, 0);
+  close(fd);
+void *POSIX_Init(
+  void *argument
+  int rv;
+  TEST_BEGIN();
+  rv = IMFS_make_generic_node(
+    &test_driver_name[0],
+    S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO,
+    &node_control,
+    NULL
+  rtems_test_assert(rv == 0);
+  puts( "Init: mmap - map at zero" );
+  mmap_map_at_zero();
+  puts( "Init: mmap - bad arguments" );
+  mmap_bad_arguments();
+   * The following test does not work on RTEMS because /dev/zero is
+   * implemented as a character device which does not support MAP_PRIVATE.
+  puts( "Init: mmap - /dev/zero private" );
+  mmap_dev_zero_private();
+   * The following test does not work on RTEMS because /dev/zero does not
+   * implemented the mmap handler.
+  puts( "Init: mmap - /dev/zero shared" );
+  mmap_dev_zero_shared();
+  TEST_END();
+  rtems_test_exit(0);
+  return 0;
diff --git a/testsuites/psxtests/psxmmap01/psxmmap01.scn b/testsuites/psxtests/psxmmap01/psxmmap01.scn
index 0000000..e69de29
diff --git a/testsuites/psxtests/psxmmap01/system.h b/testsuites/psxtests/psxmmap01/system.h
index 0000000..2241f88
--- /dev/null
+++ b/testsuites/psxtests/psxmmap01/system.h
@@ -0,0 +1,31 @@
+ * Copyright (c) 2017 Kevin Kirspel.
+#include <pmacros.h>
+#include <unistd.h>
+#include <errno.h>
+void *POSIX_Init(
+  void *argument
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS     1
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
+#define CONFIGURE_MAXIMUM_POSIX_SHMS 1
+#define CONFIGURE_MEMORY_OVERHEAD 10
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxmmap01/test_driver.c b/testsuites/psxtests/psxmmap01/test_driver.c
index 0000000..87719b9
--- /dev/null
+++ b/testsuites/psxtests/psxmmap01/test_driver.c
@@ -0,0 +1,67 @@
+#endif
+#include <rtems/libio.h>
+char test_data[PAGE_SIZE];
+static int handler_fstat(
+  const rtems_filesystem_location_info_t *loc,
+  struct stat *buf
+  buf->st_mode = S_IFCHR | S_IRWXU | S_IRWXG | S_IRWXO;
+  return 0;
+static ssize_t handler_mmap(
+  rtems_libio_t *iop,
+  void **addr,
+  size_t len,
+  int prot,
+  off_t off
+  if ( len <= sizeof(test_data) ) {
+    *addr = test_data;
+  } else {
+    *addr = NULL;
+  return 0;
+static const rtems_filesystem_file_handlers_r node_handlers = {
+  .open_h = rtems_filesystem_default_open,
+  .close_h = rtems_filesystem_default_close,
+  .read_h = rtems_filesystem_default_read,
+  .write_h = rtems_filesystem_default_write,
+  .ioctl_h = rtems_filesystem_default_ioctl,
+  .lseek_h = rtems_filesystem_default_lseek,
+  .fstat_h = handler_fstat,
+  .ftruncate_h = rtems_filesystem_default_ftruncate,
+  .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
+  .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
+  .fcntl_h = rtems_filesystem_default_fcntl,
+  .poll_h = rtems_filesystem_default_poll,
+  .kqfilter_h = rtems_filesystem_default_kqfilter,
+  .mmap_h = handler_mmap,
+  .readv_h = rtems_filesystem_default_readv,
+  .writev_h = rtems_filesystem_default_writev
+const IMFS_node_control node_control = IMFS_GENERIC_INITIALIZER(
+  &node_handlers,
+  IMFS_node_initialize_default,
+  IMFS_node_destroy_default
diff --git a/testsuites/psxtests/psxmmap01/test_driver.h b/testsuites/psxtests/psxmmap01/test_driver.h
index 0000000..5afdb9b
--- /dev/null
+++ b/testsuites/psxtests/psxmmap01/test_driver.h
@@ -0,0 +1,14 @@
+#include <rtems.h>
+#include <rtems/imfs.h>
+#include <rtems/libcsupport.h>
+extern const IMFS_node_control node_control;
+extern char test_data[PAGE_SIZE];
diff --git a/testsuites/psxtests/psxmmap01/test_helper.c b/testsuites/psxtests/psxmmap01/test_helper.c
index 0000000..cab8e91
--- /dev/null
+++ b/testsuites/psxtests/psxmmap01/test_helper.c
@@ -0,0 +1,32 @@
+#endif
+#include <stdio.h>
+#include <stdarg.h>
+void fail_check(
+  const char *file,
+  const size_t line,
+  const char *fmt,
+    va_list ap;
+    printf( "%s: %d: ", file, line );
+    va_start(ap, fmt);
+    vprintf(fmt, ap);
+    va_end(ap);
diff --git a/testsuites/psxtests/psxmmap01/test_helper.h b/testsuites/psxtests/psxmmap01/test_helper.h
index 0000000..65ca3c1
--- /dev/null
+++ b/testsuites/psxtests/psxmmap01/test_helper.h
@@ -0,0 +1,41 @@
+#define mmap_test_assert(__exp, fmt, ...) \
+  do { \
+    if (!(__exp)) { \
+      fail_check(__FILE__, __LINE__, fmt, ##__VA_ARGS__); \
+      rtems_test_exit(0); \
+  } while (0)
+#define mmap_test_check(__exp, fmt, ...) \
+  do { \
+    if (!(__exp)) { \
+    } else { \
+      rtems_test_assert(__exp); \
+  } while (0)
+#define mmap_test_assert_equal(expected, actual, fmt, ...) \
+    mmap_test_assert((expected) == (actual), "%s != %s: " fmt, \
+                  #expected, #actual, ##__VA_ARGS__)
+#define mmap_test_check_equal(expected, actual, fmt, ...) \
+    mmap_test_check((expected) == (actual), "%s != %s: " fmt, \
+extern void fail_check(
+  const char *file,
+  const char *fmt,
1.9.1
