[PATCH] bsps: Provide <bsp/fdt.h> for every BSP
Tue Mar 7 14:12:19 UTC 2017
Add bsp_fdt_map_intr() intended for the libbsd FDT support.
 c/src/lib/libbsp/Makefile.am                      |  1 +
 c/src/lib/libbsp/powerpc/qoriq/Makefile.am        |  1 -
 c/src/lib/libbsp/powerpc/qoriq/include/bsp.h      |  4 +++-
 c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c |  7 +++++-
 c/src/lib/libbsp/preinstall.am                    |  4 ++++
 c/src/lib/libbsp/shared/include/fdt.h             | 27 ++++++++++++++++++++++-
 c/src/lib/libbsp/shared/src/bsp-fdt.c             |  7 ++++--
 7 files changed, 45 insertions(+), 6 deletions(-)
diff --git a/c/src/lib/libbsp/Makefile.am b/c/src/lib/libbsp/Makefile.am
index c54fdcb..85ddbe2 100644
--- a/c/src/lib/libbsp/Makefile.am
+++ b/c/src/lib/libbsp/Makefile.am
@@ -37,6 +37,7 @@ include_bspdir = $(includedir)/bsp
 include_bsp_HEADERS =
 include_bsp_HEADERS += shared/include/default-initial-extension.h
 include_bsp_HEADERS += shared/include/fatal.h
+include_bsp_HEADERS += shared/include/fdt.h
 include_bsp_HEADERS += shared/include/console-termios.h
 include_bsp_HEADERS += shared/include/gpio.h
diff --git a/c/src/lib/libbsp/powerpc/qoriq/Makefile.am b/c/src/lib/libbsp/powerpc/qoriq/Makefile.am
index 64ef08d..93473ab 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/qoriq/Makefile.am
@@ -22,7 +22,6 @@ include_bsp_HEADERS = include/irq.h \
 	../../shared/include/irq-generic.h \
 	../../shared/include/irq-info.h \
 	../../shared/include/bootcard.h \
-	../../shared/include/fdt.h \
 	../../shared/include/utility.h \
 	../shared/include/start.h \
 	../shared/include/tictac.h \
diff --git a/c/src/lib/libbsp/powerpc/qoriq/include/bsp.h b/c/src/lib/libbsp/powerpc/qoriq/include/bsp.h
index d1fd907..7469ab1 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/qoriq/include/bsp.h
@@ -7,7 +7,7 @@
- * Copyright (c) 2010-2015 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2010, 2017 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -37,6 +37,8 @@ extern "C" {
 #define BSP_FEATURE_IRQ_EXTENSION
+#define BSP_FDT_IS_SUPPORTED
 #define QORIQ_CHIP(alpha, num) ((alpha) * 10000 + (num))
 #define QORIQ_CHIP_P1020 QORIQ_CHIP('P', 1020)
diff --git a/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c b/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c
index cbe1970..7aba178 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c
@@ -7,7 +7,7 @@
  *  Dornierstr. 4
@@ -169,3 +169,8 @@ void bsp_start(void)
   qoriq.lcc.bptr &= ~BPTR_EN;
 #endif
+uint32_t bsp_fdt_map_intr(uint32_t intr)
+  return intr - 16;
diff --git a/c/src/lib/libbsp/preinstall.am b/c/src/lib/libbsp/preinstall.am
index bbcb7c5..505803f 100644
--- a/c/src/lib/libbsp/preinstall.am
+++ b/c/src/lib/libbsp/preinstall.am
@@ -26,6 +26,10 @@ $(PROJECT_INCLUDE)/bsp/fatal.h: shared/include/fatal.h $(PROJECT_INCLUDE)/bsp/$(
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/fatal.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/fatal.h
+$(PROJECT_INCLUDE)/bsp/fdt.h: shared/include/fdt.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/fdt.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/fdt.h
 $(PROJECT_INCLUDE)/bsp/console-termios.h: shared/include/console-termios.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/console-termios.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/console-termios.h
diff --git a/c/src/lib/libbsp/shared/include/fdt.h b/c/src/lib/libbsp/shared/include/fdt.h
index a4c7df6..44298f4 100644
--- a/c/src/lib/libbsp/shared/include/fdt.h
+++ b/c/src/lib/libbsp/shared/include/fdt.h
@@ -1,5 +1,5 @@
- * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2015, 2017 embedded brains GmbH.  All rights reserved.
  *  Dornierstr. 4
@@ -15,14 +15,39 @@
 #ifndef LIBBSP_SHARED_FDT_H
 #define LIBBSP_SHARED_FDT_H
+#include <bsp.h>
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
+ * BSPs that implement the FDT support functions must define
+ * BSP_FDT_IS_SUPPORTED.
 void bsp_fdt_copy(const void *src);
+ * @brief Returns the FDT of the BSP.
+ * @return The FDT of the BSP.
 const void *bsp_fdt_get(void);
+ * @brief Maps the interrupt number of the FDT to the interrupt vector used by
+ * the interrupt management.
+ * This function is used by the libbsd to implement the OFW_BUS_MAP_INTR bus
+ * method.
+ * @param[in] intr The FDT interrupt number.
+ * @return The interrupt vector of the FDT interrupt number.
+uint32_t bsp_fdt_map_intr(uint32_t intr);
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/shared/src/bsp-fdt.c b/c/src/lib/libbsp/shared/src/bsp-fdt.c
index 635cb85..faf59be 100644
--- a/c/src/lib/libbsp/shared/src/bsp-fdt.c
+++ b/c/src/lib/libbsp/shared/src/bsp-fdt.c
@@ -1,5 +1,5 @@
  *  Dornierstr. 4
@@ -16,10 +16,13 @@
 #include <libfdt.h>
-#include <bsp.h>
 #include <bsp/fdt.h>
 #include <bsp/linker-symbols.h>
+#ifndef BSP_FDT_IS_SUPPORTED
+#warning "BSP FDT support indication not defined"
+#endif
 #ifndef BSP_FDT_BLOB_SIZE_MAX
 #define BSP_FDT_BLOB_SIZE_MAX 0
 #endif
1.8.4.5
