IoT Protocol in RTEMS
Tue Mar 14 16:08:33 UTC 2017
On Tue, Mar 14, 2017 at 10:22 AM, punit vara <punitvara at gmail.com> wrote:
> Can I port MQTT from here ?
> https://github.com/zephyrproject-rtos/zephyr/tree/master/subsys/net/lib/
> mqtt
> It has Apache licence. Where do I possibly need to add files ?  Any
> suggestion ?
> Why would Zephyr want their code to support multiple RTOSes? Would
we end up with something that has long-term life as an RTEMS option?
> -- PV
> On Tue, Mar 14, 2017 at 7:50 PM, Joel Sherrill <joel at rtems.org> wrote:
> > On Tue, Mar 14, 2017 at 8:56 AM, Gedare Bloom <gedare at rtems.org> wrote:
> >> On Tue, Mar 14, 2017 at 1:26 AM, punit vara <punitvara at gmail.com>
> wrote:
> >> > Hi
> >> > I think RTEMS don't have any IoT protocol so I propose we should
> >> > implement at least two important IoT protocols
> >> > 1. MQTT (http://docs.oasis-open.org/mqtt/mqtt/v3.1.1/mqtt-v3.1.1.html
> >> > 2. CoAP  (http://coap.technology/)
> >> Why are these 2 important?
> >> The problem to avoid is adopting a network protocol too early, because
> >> there is always a bunch of competing ones, and in the end only a
> >> handful will survive in the long term.
> > MQTT is an OASIS standard which is a good sign. It also has multiple
> > implementations
> > already with this one from the Eclipse Foundation looking very promising
> and
> > appropriate for RTEMS.
> > https://www.eclipse.org/paho/clients/c/embedded/
> > CoAP also looks promising since it has an RFC. And promising
> implementations
> > to investigate.
> > http://coap.technology/impls.html
> > https://github.com/obgm/libcoap is dual licensed as GPL and BSD (why?).
> >> > What's your opinion on this ? :)
> >> This may be a good idea. What is the state of industry and of
> >> standardization in this space? Are there open-source reference
> >> implementations with a useful (BSD/MIT) license?
> > I think those two are worth porting. There are already other ports to
> > embedded
> > environments so RTEMS should join the list.
> > The effort would have to get the RTEMS specific configuration and
> adaptation
> > code upstream, add RSB recipes, and examples with documentation. I would
> > honestly expect the ports to be easy enough where more work needs to be
> > identified. :)
> > --joel
> >> Gedare
> >> > Regards
> >> > Punit Vara
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170314/151504cf/attachment-0002.html>
