[PATCH] psxclockrealtime01: New test
Fri Oct 13 06:00:46 UTC 2017
Update #3182.
 testsuites/psxtests/Makefile.am                    |   1 +
 testsuites/psxtests/configure.ac                   |   1 +
 testsuites/psxtests/psxclockrealtime01/Makefile.am |  19 ++
 testsuites/psxtests/psxclockrealtime01/init.c      | 304 +++++++++++++++++++++
 .../psxclockrealtime01/psxclockrealtime01.doc      |  16 ++
 .../psxclockrealtime01/psxclockrealtime01.scn      |   2 +
 6 files changed, 343 insertions(+)
 create mode 100644 testsuites/psxtests/psxclockrealtime01/Makefile.am
 create mode 100644 testsuites/psxtests/psxclockrealtime01/init.c
 create mode 100644 testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.doc
 create mode 100644 testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.scn
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index cccdb39118..2a74470d60 100644
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -36,6 +36,7 @@ endif
 _SUBDIRS += psxclock
 if HAS_POSIX
 _SUBDIRS += psxclock01
+_SUBDIRS += psxclockrealtime01
 _SUBDIRS += psxconcurrency01
 _SUBDIRS += psxcond01
 _SUBDIRS += psxcond02
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index 96a0149302..7243bfdbb5 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -140,6 +140,7 @@ psxcleanup01/Makefile
 psxcleanup02/Makefile
 psxclock/Makefile
 psxclock01/Makefile
+psxclockrealtime01/Makefile
 psxconcurrency01/Makefile
 psxcond01/Makefile
 psxcond02/Makefile
diff --git a/testsuites/psxtests/psxclockrealtime01/Makefile.am b/testsuites/psxtests/psxclockrealtime01/Makefile.am
new file mode 100644
index 0000000000..d0b1a76dbe
--- /dev/null
+++ b/testsuites/psxtests/psxclockrealtime01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = psxclockrealtime01
+psxclockrealtime01_SOURCES = init.c
+dist_rtems_tests_DATA = psxclockrealtime01.scn psxclockrealtime01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(psxclockrealtime01_OBJECTS)
+LINK_LIBS = $(psxclockrealtime01_LDLIBS)
+psxclockrealtime01$(EXEEXT): $(psxclockrealtime01_OBJECTS) $(psxclockrealtime01_DEPENDENCIES)
+	@rm -f psxclockrealtime01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/psxtests/psxclockrealtime01/init.c b/testsuites/psxtests/psxclockrealtime01/init.c
index 0000000000..f5a05056a7
--- /dev/null
+++ b/testsuites/psxtests/psxclockrealtime01/init.c
@@ -0,0 +1,304 @@
+ * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+#include <pthread.h>
+#include <semaphore.h>
+#include <stdbool.h>
+#include <time.h>
+#include <unistd.h>
+#ifdef __rtems__
+#include "tmacros.h"
+#else /* __rtems__ */
+#include <assert.h>
+#define rtems_test_assert(x) assert(x)
+#endif /* __rtems__ */
+const char rtems_test_name[] = "PSXCLOCKREALTIME 1";
+typedef struct {
+  int value;
+  pthread_mutex_t mtx;
+  pthread_cond_t cnd;
+} event;
+typedef enum {
+  ACTION_NONE,
+  ACTION_MTX_LOCK,
+  ACTION_CND_WAIT,
+  ACTION_RW_RDLOCK,
+  ACTION_RW_WRLOCK,
+  ACTION_SEM_WAIT,
+  ACTION_TERMINATE
+} test_action;
+typedef struct {
+  pthread_t worker;
+  event action;
+  event done;
+  pthread_mutex_t mtx2;
+  pthread_rwlock_t rw;
+  sem_t sem;
+  int counter[ACTION_TERMINATE + 1];
+} test_context;
+static test_context test_instance;
+static void event_init(event *e)
+  int eno;
+  eno = pthread_mutex_init(&e->mtx, NULL);
+  rtems_test_assert(eno == 0);
+  eno = pthread_cond_init(&e->cnd, NULL);
+static void event_destroy(event *e)
+  int eno;
+  eno = pthread_mutex_destroy(&e->mtx);
+  eno = pthread_cond_destroy(&e->cnd);
+static void event_post(event *e, int value)
+  int eno;
+  eno = pthread_mutex_lock(&e->mtx);
+  e->value = value;
+  eno = pthread_cond_signal(&e->cnd);
+  eno = pthread_mutex_unlock(&e->mtx);
+static int event_get(event *e)
+  int eno;
+  int value;
+  while (true) {
+    value = e->value;
+    if (value != 0) {
+      e->value = 0;
+      break;
+    eno = pthread_cond_wait(&e->cnd, &e->mtx);
+  return value;
+static void *worker(void *arg)
+  test_context *ctx;
+  test_action action;
+  ctx = arg;
+  while ((action = event_get(&ctx->action)) != ACTION_TERMINATE) {
+    int eno;
+    int rv;
+    struct timespec to;
+    rv = clock_gettime(CLOCK_REALTIME, &to);
+    rtems_test_assert(rv == 0);
+    to.tv_sec += 3600;
+    switch (action) {
+      case ACTION_MTX_LOCK:
+        eno = pthread_mutex_timedlock(&ctx->mtx, &to);
+        rtems_test_assert(eno == ETIMEDOUT);
+        break;
+      case ACTION_CND_WAIT:
+        eno = pthread_mutex_lock(&ctx->mtx2);
+        eno = pthread_cond_timedwait(&ctx->cnd, &ctx->mtx2, &to);
+        eno = pthread_mutex_unlock(&ctx->mtx2);
+        break;
+      case ACTION_RW_RDLOCK:
+        eno = pthread_rwlock_timedrdlock(&ctx->rw, &to);
+        break;
+      case ACTION_RW_WRLOCK:
+        eno = pthread_rwlock_timedwrlock(&ctx->rw, &to);
+        break;
+      case ACTION_SEM_WAIT:
+        errno = 0;
+        rv = sem_timedwait(&ctx->sem, &to);
+        rtems_test_assert(rv == -1);
+        rtems_test_assert(errno == ETIMEDOUT);
+        break;
+      default:
+        rtems_test_assert(0);
+        break;
+    ++ctx->counter[action];
+    event_post(&ctx->done, 1);
+  return ctx;
+static void test(test_context *ctx)
+  int eno;
+  int rv;
+  void *status;
+  event_init(&ctx->action);
+  event_init(&ctx->done);
+  eno = pthread_mutex_init(&ctx->mtx, NULL);
+  eno = pthread_mutex_lock(&ctx->mtx);
+  eno = pthread_mutex_init(&ctx->mtx2, NULL);
+  eno = pthread_cond_init(&ctx->cnd, NULL);
+  eno = pthread_rwlock_init(&ctx->rw, NULL);
+  eno = pthread_rwlock_wrlock(&ctx->rw);
+  rv = sem_init(&ctx->sem, 0, 0);
+  eno = pthread_create(&ctx->worker, NULL, worker, ctx);
+  for (action = ACTION_MTX_LOCK; action <= ACTION_SEM_WAIT; ++action) {
+    struct timespec now;
+    event_post(&ctx->action, action);
+    rv = sleep(1);
+    rv = clock_gettime(CLOCK_REALTIME, &now);
+    now.tv_sec += 7200;
+    rv = clock_settime(CLOCK_REALTIME, &now);
+    event_get(&ctx->done);
+  event_post(&ctx->action, ACTION_TERMINATE);
+  eno = pthread_join(ctx->worker, &status);
+  rtems_test_assert(status == ctx);
+  event_destroy(&ctx->action);
+  event_destroy(&ctx->done);
+  eno = pthread_mutex_unlock(&ctx->mtx);
+  eno = pthread_mutex_destroy(&ctx->mtx);
+  eno = pthread_mutex_destroy(&ctx->mtx2);
+  eno = pthread_cond_destroy(&ctx->cnd);
+  eno = pthread_rwlock_unlock(&ctx->rw);
+  eno = pthread_rwlock_destroy(&ctx->rw);
+  rv = sem_destroy(&ctx->sem);
+    rtems_test_assert(ctx->counter[action] == 1);
+#ifdef __rtems__
+static void *POSIX_Init(void *arg)
+  TEST_BEGIN();
+  test(&test_instance);
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
+int main(void)
+  return 0;
diff --git a/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.doc b/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.doc
index 0000000000..5669df84e8
--- /dev/null
+++ b/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.doc
@@ -0,0 +1,16 @@
+This file describes the directives and concepts tested by this test set.
+test set name: psxclockrealtime01
+directives:
+  - pthread_mutex_timedlock()
+  - pthread_cond_timedwait()
+  - pthread_rwlock_timedrdlock()
+  - pthread_rwlock_timedwrlock()
+  - sem_timedwait()
+concepts:
+  - Ensure that absolute CLOCK_REALTIME timeouts expire due to external clock
+    changes.
diff --git a/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.scn b/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.scn
index 0000000000..df2801b674
--- /dev/null
+++ b/testsuites/psxtests/psxclockrealtime01/psxclockrealtime01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST PSXCLOCKREALTIME 1 ***
+*** END OF TEST PSXCLOCKREALTIME 1 ***
2.12.3
