Fwd: Build : FAILED 4.12/rtems-or1k.bset on x86_64-apple-darwin17.0.0 (or1k-rtems4.12-gcc-4.9.3-newlib-2.5.0.20170922-x86_64-apple-darwin17.0.0-1)
Fri Oct 27 17:33:39 UTC 2017
Hi
Based on subsequent test results posted, this configuration builds on
CentOS and Windows.
That would seem to make it something that clang doesn't like.
Is there a ticket for this?
--joel
---------- Forwarded message ----------
Date: Fri, Oct 27, 2017 at 8:40 AM
Subject: Build : FAILED 4.12/rtems-or1k.bset on x86_64-apple-darwin17.0.0
To: build at rtems.org
RTEMS Source Builder - Set Builder, 4.12 (8cdc8e42e4e2)
 Command Line: ../source-builder/sb-set-builder
--prefix=/opt/work/rtems/4.12 --keep-going --log=t3.txt --mail
--smtp-host=smtp 4.12/rtems-tier-3
 Python: 2.7.10 (default, Jul 15 2017, 17:16:57) [GCC 4.2.1 Compatible
Apple LLVM 9.0.0 (clang-900.0.31)]
Build Time: 0:07:18.334557
Build FAILED: or1k-rtems4.12-gcc-4.9.3-newlib-2.5.0.20170922-x86_64-
#define HOOK_VECTOR_END(DECL_NAME) HOOK_VECTOR_1(,} DECL_NAME ;)
In file included from ../../gcc-4.9.3/gcc/c/c-decl.c:46:
In file included from ../../gcc-4.9.3/gcc/target.h:175:
../../gcc-4.9.3/gcc/target.def:4769:1: warning: empty macro arguments are a
C99 feature [-Wc99-extensions]
HOOK_VECTOR_END (c)
../../gcc-4.9.3/gcc/target-hooks-macros.h:43:50: note: expanded from macro
'HOOK_VECTOR_END'
../../gcc-4.9.3/gcc/target.def:4922:1: warning: empty macro arguments are a
HOOK_VECTOR_END (cxx)
'HOOK_VECTOR_END'
../../gcc-4.9.3/gcc/target.def:5011:1: warning: empty macro arguments are a
HOOK_VECTOR_END (emutls)
'HOOK_VECTOR_END'
../../gcc-4.9.3/gcc/target.def:5117:1: warning: empty macro arguments are a
HOOK_VECTOR_END (target_option)
'HOOK_VECTOR_END'
../../gcc-4.9.3/gcc/target.def:5349:1: warning: empty macro arguments are a
HOOK_VECTOR_END (C90_EMPTY_HACK)
'HOOK_VECTOR_END'
12 warnings generated.
/usr/bin/c++ -O2 -pipe -fbracket-depth=1024 -I/opt/work/chris/rtems/rsb/
rtems-source-builder.git/rtems/build/tmp/sb-chris/4.12/
rtems-or1k.bset/opt/work/rtems/4.12/include -c  -DIN_GCC_FRONTEND -g -O2
-DIN_GCC  -DCROSS_DIRECTORY_STRUCTURE  -fno-exceptions -fno-rtti
-fasynchronous-unwind-tables -W -Wall -Wno-narrowing -Wwrite-strings
-Wcast-qual -Wmissing-format-attribute -pedantic -Wno-long-long
-Wno-variadic-macros -Wno-overlength-strings   -DHAVE_CONFIG_H -I. -Ic
-I../../gcc-4.9.3/gcc -I../../gcc-4.9.3/gcc/c -I../../gcc-4.9.3/gcc/../include
-I../../gcc-4.9.3/gcc/../libcpp/include -I/opt/work/chris/rtems/rsb/
rtems-source-builder.git/rtems/build/or1k-rtems4.12-gcc-4.9.3-newlib-2.5.0.
20170922-x86_64-apple-darwin17.0.0-1/build/./gmp
-I/opt/work/chris/rtems/rsb/rtems-source-builder.git/
rtems/build/or1k-rtems4.12-gcc-4.9.3-newlib-2.5.0.20170922-x86_64-apple-darwin17.0.0-1/gcc-4.9.3/gmp
rtems/build/or1k-rtems4.12-gcc-4.9.3-newli!
 b-2.5.0.20170922-x86_64-apple-darwin17.0.0-1/build/./mpfr
rtems/build/or1k-rtems4.12-gcc-4.9.3-newlib-2.5.0.20170922-x86_64-apple-darwin17.0.0-1/gcc-4.9.3/mpfr
darwin17.0.0-1/gcc-4.9.3/mpc/src  -I../../gcc-4.9.3/gcc/../libdecnumber
-I../../gcc-4.9.3/gcc/../libdecnumber/dpd -I../libdecnumber
-I../../gcc-4.9.3/gcc/../libbacktrace    -o c/c-convert.o -MT c/c-convert.o
-MMD -MP -MF c/.deps/c-convert.TPo ../../gcc-4.9.3/gcc/c/c-convert.c
clang: warning: treating 'c' input as 'c++' when in C++ mode, this behavior
is deprecated [-Wdeprecated]
-I../../gcc-4.9.3/gcc/../libbacktrace    -o c/c-aux-info.o -MT
c/c-aux-info.o -MMD -MP -MF c/.deps/c-aux-info.TPo
../../gcc-4.9.3/gcc/c/c-aux-info.c
In file included from ../../gcc-4.9.3/gcc/c/c-typeck.c:40:
../../gcc-4.9.3/gcc/target.def:902:1: warning: empty macro arguments are a
HOOK_VECTOR_END (asm_out)
'HOOK_VECTOR_END'
../../gcc-4.9.3/gcc/target.def:1522:1: warning: empty macro arguments are a
HOOK_VECTOR_END (sched)
'HOOK_VECTOR_END'
../../gcc-4.9.3/gcc/target.def:1552:1: warning: empty macro arguments are a
HOOK_VECTOR_END (simd_clone)
'HOOK_VECTOR_END'
../../gcc-4.9.3/gcc/target.def:1770:1: warning: empty macro arguments are a
HOOK_VECTOR_END (vectorize)
'HOOK_VECTOR_END'
../../gcc-4.9.3/gcc/target.def:2913:1: warning: empty macro arguments are a
HOOK_VECTOR_END (addr_space)
'HOOK_VECTOR_END'
../../gcc-4.9.3/gcc/target.def:4254:1: warning: empty macro arguments are a
HOOK_VECTOR_END (calls)
'HOOK_VECTOR_END'
HOOK_VECTOR_END (c)
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
In file included from ../../gcc-4.9.3/gcc/c/c-convert.c:36:
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
HOOK_VECTOR_END (c)
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
11 warnings generated.
-I../../gcc-4.9.3/gcc/../libbacktrace    -o c/c-objc-common.o -MT
c/c-objc-common.o -MMD -MP -MF c/.deps/c-objc-common.TPo
../../gcc-4.9.3/gcc/c/c-objc-common.c
In file included from ../../gcc-4.9.3/gcc/c/c-decl.c:10543:
./gt-c-c-decl.h:93:7: warning: switch condition has boolean value
[-Wswitch-bool]
      switch (TREE_CODE ((*x).decl) == LABEL_DECL)
./gt-c-c-decl.h:148:7: warning: switch condition has boolean value
[-Wswitch-bool]
      switch (TREE_CODE (&((*x)).generic) == IDENTIFIER_NODE)
./gt-c-c-decl.h:729:7: warning: switch condition has boolean value
[-Wswitch-bool]
./gt-c-c-decl.h:784:7: warning: switch condition has boolean value
[-Wswitch-bool]
./gt-c-c-decl.h:1360:3: warning: switch condition has boolean value
[-Wswitch-bool]
./gt-c-c-decl.h:1426:3: warning: switch condition has boolean value
[-Wswitch-bool]
-I../../gcc-4.9.3/gcc/../libbacktrace    -o c/c-parser.o -MT c/c-parser.o
-MMD -MP -MF c/.deps/c-parser.TPo ../../gcc-4.9.3/gcc/c/c-parser.c
In file included from ../../gcc-4.9.3/gcc/c/c-objc-common.c:33:
In file included from /Applications/Xcode.app/Contents/Developer/Toolchains/
XcodeDefault.xctoolchain/usr/include/c++/v1/new:89:
XcodeDefault.xctoolchain/usr/include/c++/v1/exception:173:5: error: no
member named 'fancy_abort' in namespace 'std::__1'; did you mean simply
'fancy_abort'?
    _VSTD::abort();
XcodeDefault.xctoolchain/usr/include/c++/v1/__config:392:15: note: expanded
from macro '_VSTD'
#define _VSTD std::_LIBCPP_NAMESPACE
../../gcc-4.9.3/gcc/system.h:685:13: note: 'fancy_abort' declared here
extern void fancy_abort (const char *, int, const char *)
ATTRIBUTE_NORETURN;
1 error generated.
make[2]: *** [c/c-objc-common.o] Error 1
make[2]: *** Waiting for unfinished jobs....
In file included from ../../gcc-4.9.3/gcc/c/c-parser.c:60:
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
HOOK_VECTOR_END (c)
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
'HOOK_VECTOR_END'
../../gcc-4.9.3/gcc/c/c-parser.c:485:10: warning: case value not in
enumerated type 'enum cpp_ttype' [-Wswitch]
    case CPP_KEYWORD:
../../gcc-4.9.3/gcc/c/c-parser.c:131:21: note: expanded from macro
'CPP_KEYWORD'
#define CPP_KEYWORD ((enum cpp_ttype) (N_TTYPES + 1))
../../gcc-4.9.3/gcc/c/c-parser.c:585:10: warning: case value not in
    case CPP_KEYWORD:
'CPP_KEYWORD'
../../gcc-4.9.3/gcc/c/c-parser.c:635:10: warning: case value not in
    case CPP_KEYWORD:
'CPP_KEYWORD'
../../gcc-4.9.3/gcc/c/c-parser.c:1323:10: warning: case value not in
    case CPP_KEYWORD:
'CPP_KEYWORD'
../../gcc-4.9.3/gcc/c/c-parser.c:4854:10: warning: case value not in
    case CPP_KEYWORD:
'CPP_KEYWORD'
../../gcc-4.9.3/gcc/c/c-parser.c:6439:10: warning: case value not in
    case CPP_KEYWORD:
'CPP_KEYWORD'
../../gcc-4.9.3/gcc/c/c-parser.c:7101:10: warning: case value not in
    case CPP_KEYWORD:
'CPP_KEYWORD'
17 warnings generated.
18 warnings generated.
rm gcc.pod
make[1]: *** [all-gcc] Error 2
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex  /opt/work/chris/rtems/rsb/
20170922-x86_64-apple-darwin17.0.0-1/doit
error: building or1k-rtems4.12-gcc-4.9.3-newlib-2.5.0.20170922-x86_64-
  See error report: rsb-report-or1k-rtems4.12-gcc-
4.9.3-newlib-2.5.0.20170922-x86_64-apple-darwin17.0.0-1.txt
Output
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-apple-darwin17.0.0-1
building: autoconf-2.69-x86_64-apple-darwin17.0.0-1
reporting: tools/rtems-autoconf-2.69-1.cfg -> autoconf-2.69-x86_64-apple-
darwin17.0.0-1.txt
darwin17.0.0-1.xml
config: tools/rtems-automake-1.12.6-1.cfg
package: automake-1.12.6-x86_64-apple-darwin17.0.0-1
building: automake-1.12.6-x86_64-apple-darwin17.0.0-1
reporting: tools/rtems-automake-1.12.6-1.cfg ->
automake-1.12.6-x86_64-apple-darwin17.0.0-1.txt
automake-1.12.6-x86_64-apple-darwin17.0.0-1.xml
installing: autoconf-2.69-x86_64-apple-darwin17.0.0-1 ->
installing: automake-1.12.6-x86_64-apple-darwin17.0.0-1 ->
cleaning: autoconf-2.69-x86_64-apple-darwin17.0.0-1
cleaning: automake-1.12.6-x86_64-apple-darwin17.0.0-1
Build Set: Time 0:00:11.313009
Build Set: Time 0:00:19.510436
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-apple-darwin17.0.0-1
building: expat-2.1.0-x86_64-apple-darwin17.0.0-1
reporting: devel/expat-2.1.0-1.cfg -> expat-2.1.0-x86_64-apple-
darwin17.0.0-1.txt
darwin17.0.0-1.xml
config: tools/rtems-binutils-2.26-1.cfg
package: or1k-rtems4.12-binutils-2.26-x86_64-apple-darwin17.0.0-1
warning: binutils-2.26-rtems-aarch64-x86-64.patch: no hash found
building: or1k-rtems4.12-binutils-2.26-x86_64-apple-darwin17.0.0-1
reporting: tools/rtems-binutils-2.26-1.cfg -> or1k-rtems4.12-binutils-2.26-
config: tools/rtems-gcc-4.9.3-newlib-2.5.0.20170922-1.cfg
package: or1k-rtems4.12-gcc-4.9.3-newlib-2.5.0.20170922-x86_64-
warning: gcc-4.9.3-or1k.patch: no hash found
building: or1k-rtems4.12-gcc-4.9.3-newlib-2.5.0.20170922-x86_64-
Build FAILED
config: tools/rtems-tools-4.12-1.cfg
package: rtems-tools-HEAD-1
git: reset: git://git.rtems.org/rtems-tools.git
git: fetch: git://git.rtems.org/rtems-tools.git ->
sources/git/rtems-tools.git
git: checkout: git://git.rtems.org/rtems-tools.git => HEAD
git: pull: git://git.rtems.org/rtems-tools.git
building: rtems-tools-HEAD-1
reporting: tools/rtems-tools-4.12-1.cfg -> rtems-tools-HEAD-1.txt
reporting: tools/rtems-tools-4.12-1.cfg -> rtems-tools-HEAD-1.xml
config: tools/rtems-gdb-7.11-1.cfg
package: or1k-rtems4.12-gdb-7.11-x86_64-apple-darwin17.0.0-1
warning: gdb-7.11-or1k.patch: no hash found
warning: gdb-7.11-aarch64-x86-64.patch: no hash found
building: or1k-rtems4.12-gdb-7.11-x86_64-apple-darwin17.0.0-1
reporting: tools/rtems-gdb-7.11-1.cfg -> or1k-rtems4.12-gdb-7.11-x86_
cleaning: expat-2.1.0-x86_64-apple-darwin17.0.0-1
cleaning: or1k-rtems4.12-binutils-2.26-x86_64-apple-darwin17.0.0-1
cleaning: rtems-tools-HEAD-1
cleaning: or1k-rtems4.12-gdb-7.11-x86_64-apple-darwin17.0.0-1
Mailing report: build at rtems.org
Report
RTEMS Tools Project <users at rtems.org> Sat Oct 28 00:33:25 2017
Report: devel/expat-2.1.0-1.cfg
RTEMS Source Builder Repository Status
 Remotes:
   1: origin: ssh://chrisj@dispatch.rtems.org/data/git/rtems-source-
builder.git
 Status:
  Clean
 Head:
  Commit: 8cdc8e42e4e2ce3b14297d2223f84c8344c1eb18
Build Set: (1) devel/expat-2.1.0-1.cfg
Build Set: (2) devel/expat-2.1.0-1.cfg
Package: expat-2.1.0-x86_64-apple-darwin17.0.0-1
 Config: devel/expat-2.1.0-1.cfg
 Summary:
  Expat XML Parser v2.1.0 for target or1k-rtems4.12 on host
 URL:
  http://expat.sourceforge.net/
 Version:
  2.1.0
 Release:
  1
  Sources: 1
    1: http://downloads.sourceforge.net/project/expat/expat/2.1.0/
expat-2.1.0.tar.gz
       sha256: 823705472f816df21c8f6aa026dd162b280806838bb55b3432b0fb1fcca7
eb86
  Patches: 0
 Preparation:
  build_top=$(pwd)
  %setup source expat -q -n expat-2.1.0
  %setup patch expat -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd expat-2.1.0
  # Host and build flags, Cross build if host and build are different and
  # Cxc build if target is deifned and also different.
  # Note, gcc is not ready to be compiled with -std=gnu99 (this needs to be
checked).
  if test "x86_64-apple-darwin17.0.0" != "x86_64-apple-darwin17.0.0" ; then
    # Cross build
    CC=$(echo "x86_64-apple-darwin17.0.0-gcc" | sed -e 's,-std=gnu99 ,,')
    CXX=$(echo "x86_64-apple-darwin17.0.0-g++" | sed -e 's,-std=gnu99 ,,')
    CPPFLAGS="${SB_HOST_CPPFLAGS}"
    CFLAGS="${SB_HOST_CFLAGS}"
    CXXFLAGS="${SB_HOST_CXXFLAGS}"
    LDFLAGS="${SB_HOST_LDFLAGS}"
    # Host
    CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
    CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
    CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
    LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
    CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
    CC_FOR_HOST=$(echo "gcc ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
    CXX_FOR_HOST=$(echo "g++ ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99
    # Build
    CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
    CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
    LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
    CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
    CC_FOR_BUILD=$(echo "/usr/bin/cc ${SB_BUILD_CFLAGS}" | sed -e
's,-std=gnu99 ,,')
    CXX_FOR_BUILD=$(echo "/usr/bin/c++ ${SB_BUILD_CXXFLAGS}" | sed -e
's,-std=gnu99 ,,')
  else
    LDFLAGS="${SB_BUILD_LDFLAGS}"
    CC=$(echo "/usr/bin/cc ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
    CXX=$(echo "/usr/bin/c++ ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99
    CC_FOR_BUILD=${CC}
    CXX_FOR_BUILD=${CXX}
  fi
  export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS
  export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST
CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST
  export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD
LDFLAGS_FOR_BUILD
  ./configure \
  --build=x86_64-apple-darwin17.0.0 --host=x86_64-apple-darwin17.0.0 \
  --verbose \
  --prefix=/opt/work/rtems/4.12 --bindir=/opt/work/rtems/4.12/bin \
  --exec-prefix=/opt/work/rtems/4.12 \
  --includedir=/opt/work/rtems/4.12/include --libdir=/opt/work/rtems/4.12/lib
  --mandir=/opt/work/rtems/4.12/share/man --infodir=/opt/work/rtems/4.
12/share/info
  make -j 4 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  rm -rf $SB_BUILD_ROOT
  cd expat-2.1.0
  make DESTDIR=$SB_BUILD_ROOT install
  cd ${build_top}
 Remotes:
builder.git
 Status:
  Clean
 Head:
 Summary:
 URL:
 Version:
  2.1.0
 Release:
  1
  Sources: 1
expat-2.1.0.tar.gz
eb86
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
  cd expat-2.1.0
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
LDFLAGS_FOR_BUILD
  ./configure \
  --verbose \
12/share/info
  make -j 4 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd expat-2.1.0
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat Oct 28 00:34:33 2017
Report: tools/rtems-binutils-2.26-1.cfg
 Remotes:
builder.git
 Status:
  Clean
 Head:
Build Set: (1) tools/rtems-binutils-2.26-1.cfg
Build Set: (2) tools/rtems-binutils-2.26-1.cfg
Package: or1k-rtems4.12-binutils-2.26-x86_64-apple-darwin17.0.0-1
 Config: tools/rtems-binutils-2.26-1.cfg
 Summary:
  Binutils v2.26 for target or1k-rtems4.12 on host x86_64-apple-darwin17.0.0
 URL:
  http://sources.redhat.com/binutils
 Version:
  2.26
 Release:
  1
  Sources: 1
    1: ftp://ftp.gnu.org/gnu/binutils/binutils-2.26.tar.bz2
       sha512: e77e1b8dbbcbaf9ac2fae95c4403615808af3be03b2e1d32448cd3a7d32c
43273f8bcace3f2de84ec120a982879295673029da306e2885dbf5f990584932cfc7
  Patches: 1
    1: https://git.rtems.org/rtems-tools/plain/tools/4.12/
binutils/binutils-2.26-rtems-aarch64-x86_64.patch
       sha512: 2236cc22dda60d5c18a2ab5abc0f44bf487794f7c0899382bf49233e789e
1fb34ce28b0f7a85069642f7cc06bd34d7634a441a8d92bf890de57bb89cc398349f
    2: https://git.rtems.org/rtems-tools/plain/tools/4.12/
binutils/binutils-2.26-gas-reloc.patch
       sha256: 21f6e887a1e8308cf3dae9a9eba431b6d5afdf8798f48024f90d71fab07c
eeee
 Preparation:
  build_top=$(pwd)
  binutils_source="binutils-2.26"
  source_dir_binutils=${binutils_source}
  %setup source binutils -q -n ${binutils_source}
  %setup patch binutils -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
    # Cross-build (Xc) if no target or the host and target match.
    # Canadian-cross (Cxc) if build, host and target are all different.
    if test -z "or1k-rtems4.12" -o "x86_64-apple-darwin17.0.0" ==
"or1k-rtems4.12" ; then
      build_dir="build-xc"
    else
      build_dir="build-cxc"
    fi
  else
    build_dir="build"
  fi
  mkdir -p ${build_dir}
  cd ${build_dir}
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
LDFLAGS_FOR_BUILD
  ../${source_dir_binutils}/configure \
  --target=or1k-rtems4.12 \
  --verbose --disable-nls \
  --enable-deterministic-archives \
  --disable-lto \
  --without-included-gettext \
  --disable-win32-registry \
  --disable-werror \
12/share/info
  make -j 4 all
  cd ${build_top}
 Install:
  cd ${build_top}
  /bin/rm -rf $SB_BUILD_ROOT
  cd ${build_dir}
  /bin/rm -rf $SB_BUILD_ROOT/opt/work/rtems/4.12/share/info/configure.info*
  /bin/rm -f $SB_BUILD_ROOT/opt/work/rtems/4.12/share/info/dir
  touch $SB_BUILD_ROOT/opt/work/rtems/4.12/share/info/dir
  mkdir -p $SB_BUILD_ROOT/opt/work/rtems/4.12/share/locale
  /bin/rm -f ${SB_BUILD_ROOT}/opt/work/rtems/4.12/lib/libiberty*
  if test ! -f ${SB_BUILD_ROOT}/opt/work/rtems/4.12/bin/or1k-rtems4.12-dlltool;
then
  /bin/rm -f ${SB_BUILD_ROOT}/opt/work/rtems/4.12/share/man/man1/
or1k-rtems4.12-dlltool*
  fi
  if test ! -f ${SB_BUILD_ROOT}/opt/work/rtems/4.12/bin/or1k-rtems4.12-nlmconv;
then
or1k-rtems4.12-nlmconv*
  fi
  if test ! -f ${SB_BUILD_ROOT}/opt/work/rtems/4.12/bin/or1k-rtems4.12-windres;
then
or1k-rtems4.12-windres*
  fi
  if test ! -f ${SB_BUILD_ROOT}/opt/work/rtems/4.12/bin/or1k-rtems4.12-windmc;
then
or1k-rtems4.12-windmc*
  fi
  cd ${build_top}
 Remotes:
builder.git
 Status:
  Clean
 Head:
 Summary:
 URL:
 Version:
  2.26
 Release:
  1
  Sources: 1
  Patches: 1
eeee
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
    else
    fi
  else
    build_dir="build"
  fi
  cd ${build_dir}
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
LDFLAGS_FOR_BUILD
  --disable-lto \
  --disable-werror \
12/share/info
  make -j 4 all
  cd ${build_top}
 Install:
  cd ${build_top}
  cd ${build_dir}
then
  fi
then
  fi
then
  fi
then
  fi
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat Oct 28 00:37:48 2017
Report: tools/rtems-tools-4.12-1.cfg
 Remotes:
builder.git
 Status:
  Clean
 Head:
Build Set: (1) tools/rtems-tools-4.12-1.cfg
Build Set: (2) tools/rtems-tools-4.12-1.cfg
Package: rtems-tools-HEAD-1
 Config: tools/rtems-tools-4.12-1.cfg
 Summary:
  RTEMS Tools HEAD for host x86_64-apple-darwin17.0.0
 URL:
  http://www.rtems.org/
 Version:
  HEAD
 Release:
  1
  Sources: 1
    1: git://git.rtems.org/rtems-tools.git?reset=hard?fetch?branch=HEAD?pull
       No checksum
  Patches: 0
 Preparation:
  build_top=$(pwd)
  rtems_tools_source="rtems-tools.git"
  source_dir_rtems_tools=${rtems_tools_source}
  %setup source rtems-tools -q -n ${rtems_tools_source}
  %setup patch rtems-tools -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
  RT_HOST="-host=x86_64-apple-darwin17.0.0"
  else
  RT_HOST=
  fi
  cd ${source_dir_rtems_tools}
  ./waf distclean configure ${RT_HOST} --prefix=/opt/work/rtems/4.12
  ./waf
  cd ${build_top}
 Install:
  build_top=$(pwd)
  SB_BUILD_ROOT_WAF=$SB_BUILD_ROOT
  ./waf --destdir=$SB_BUILD_ROOT_WAF install
  cd ${build_top}
 Remotes:
builder.git
 Status:
  Clean
 Head:
 Summary:
 URL:
 Version:
  HEAD
 Release:
  1
  Sources: 1
       No checksum
  Patches: 0
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
  else
  RT_HOST=
  fi
  ./waf
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd ${build_top}
RTEMS Tools Project <users at rtems.org> Sat Oct 28 00:40:12 2017
Report: tools/rtems-gdb-7.11-1.cfg
 Remotes:
builder.git
 Status:
  Clean
 Head:
Build Set: (1) tools/rtems-gdb-7.11-1.cfg
Build Set: (2) tools/rtems-gdb-7.11-1.cfg
Package: or1k-rtems4.12-gdb-7.11-x86_64-apple-darwin17.0.0-1
 Config: tools/rtems-gdb-7.11-1.cfg
 Summary:
  GDB v7.11 for target or1k-rtems4.12 on host x86_64-apple-darwin17.0.0
 URL:
  http://www.gnu.org/software/gdb/
 Version:
  7.11
 Release:
  1
  Sources: 1
    1: http://ftp.gnu.org/gnu/gdb/gdb-7.11.tar.xz
       sha256: 7a434116cb630d77bb40776e8f5d3937bed11dea56bafebb4d2bc5dd389f
e5c1
  Patches: 1
    1: https://github.com/openrisc/binutils-gdb/releases/
download/gdb-7.11-or1k-release/gdb-7.11-or1k.patch
       No checksum
    2: https://git.rtems.org/rtems-tools/plain/tools/4.12/gdb/
gdb-7.11-aarch64-x86_64.patch
       sha512: 20fc58f6979afd27b4cb0d94f1d5784a5d429ca78d66956e14cd21ad7dc2
3899
    3: https://git.rtems.org/rtems-tools/plain/tools/4.12/gdb/
gdb-7.11-sis-leon2-leon3.diff
       sha512: 0b8b2a23c7d1592315fe0130188f457c80f8b1e26645535bed091a5e0671
682dc44a1987d00e6939a1b1c562c7579404db43183e666c29c2b479446aa61ca4f6
 Preparation:
  build_top=$(pwd)
  gdb_source="gdb-7.11"
  source_dir_gdb=${gdb_source}
  %setup source gdb -q -n ${gdb_source}
  %setup patch gdb -p1
  cd ${build_top}
 Build:
  build_top=$(pwd)
    else
    fi
  else
    build_dir="build"
  fi
  cd ${build_dir}
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
LDFLAGS_FOR_BUILD
  GDB_LIBS_STATIC="-lexpat"
  else
  GDB_LIBS=""
  fi
  LIBS_STATIC=${GDB_LIBS_STATIC} \
  LIBS=${GDB_LIBS} \
  ../${source_dir_gdb}/configure \
  --disable-werror \
  --disable-sim \
  --without-zlib \
  --with-expat \
  --with-guile=no \
  --with-python \
12/share/info
  make -j 4 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd ${build_dir}
  cd ${build_top}
 Remotes:
builder.git
 Status:
  Clean
 Head:
 Summary:
 URL:
 Version:
  7.11
 Release:
  1
  Sources: 1
e5c1
  Patches: 1
       No checksum
3899
 Preparation:
  build_top=$(pwd)
  cd ${build_top}
 Build:
  build_top=$(pwd)
    else
    fi
  else
    build_dir="build"
  fi
  cd ${build_dir}
checked).
    # Cross build
    # Host
    # Build
's,-std=gnu99 ,,')
's,-std=gnu99 ,,')
  else
    CC_FOR_BUILD=${CC}
  fi
LDFLAGS_FOR_BUILD
  else
  GDB_LIBS=""
  fi
  LIBS=${GDB_LIBS} \
  --disable-werror \
  --disable-sim \
  --without-zlib \
  --with-expat \
  --with-guile=no \
  --with-python \
12/share/info
  make -j 4 all
  cd ${build_top}
 Install:
  build_top=$(pwd)
  cd ${build_dir}
  cd ${build_top}
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20171027/78292274/attachment-0001.html>
