need patch for old gcc docs for newer makeinfo was Re: Unable to build m68k arch on 4.9
Shashvat Jain shashvatjain2002 at gmail.com
Tue Dec 18 03:49:15 UTC 2018
Hello ,
I was also able to fetch the download now , has this change in the download
link been merged ?
Now i am stuck on the same problem as described by ticket #2581
*https://devel.rtems.org/ticket/2581 <https://devel.rtems.org/ticket/2581>*
Thank you for bringing this up !!
--Shashvat
On Mon, Dec 17, 2018 at 10:37 PM Joel Sherrill <joel at rtems.org> wrote:
> Bringing this back up. I have the sources fetching now but gcc requires a
> patch for the documentation because it was built using an old version of
> makeinfo that is more forgiving. I don't seem to be abl eot find these
> patches. I know we had them.
> I was just going to go through 4.9 and 4.10 to see if I could make them
> build.
> --joel
> On Wed, Dec 12, 2018 at 2:47 PM Joel Sherrill <joel at rtems.org> wrote:
>> Hi
>> How about this in the file ./source-builder/config/gcc-4.3-1.cfg
>> # Packages GCC requires
>> %source set mpfr
>> http://www.mpfr.org/mpfr-%{mpfr_version}/mpfr-%{mpfr_version}.tar.bz2
>> %source set mpc
>> http://www.multiprecision.org/mpc/download/mpc-%{mpc_version}.tar.gz
>> %source set gmp ftp://ftp.gnu.org/gnu/gmp/gmp-%{gmp_version}.tar.bz2
>> The thread starts at the file rtems-m68k.bset. Then it includes a file
>> and I think that includes another one. The file
>> ./source-builder/config/gcc-4.3-1.cfg end of the list.
>> I think the URL for download is
>> http://www.multiprecision.org/downloads/mpc-0.8.2.tar.gz
>> %source set mpc
>> http://www.multiprecision.org/downloads/mpc-%{mpc_version}.tar.gz
>> should work.
>> --joel
>> On Wed, Dec 12, 2018 at 3:55 AM Shashvat Jain <shashvatjain2002 at gmail.com>
>> wrote:
>>> Ping Dr Joel ,
>>> I still do not find a script in the .bset files which has the mpc url ,
>>> so that i can modify it  .
>>> I want to continue debugging 4.9 RSB to close the ticket. #2581
>>> Thank you
>>> On Mon, Dec 10, 2018 at 9:00 PM Shashvat Jain <
>>> shashvatjain2002 at gmail.com> wrote:
>>>> which bset should i look into ,
>>>> i did "grep -r mcp" and found no relevant search displaying url which
>>>> can be changed :(
>>>> config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.3.2-newlib-1.16.0-1.cfg:%hash sha512
>>>> mpc-0.8.2.tar.gz
>>>> dcaac3897adf1411e1199e295e88d7438afc600f412565c3b450b0102b83751eb160f85b7522891195ff0a0a29fccedd07dc011a950969a0979c4e3d4efc1e10
>>>> config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg:%define mpc_version
>>>> 0.8.1
>>>> config/tools/rtems-gcc-4.4.7-newlib-1.18.0-1.cfg:%hash md5
>>>> mpc-%{mpc_version}.tar.gz    5b34aa804d514cc295414a963aedb6bf
>>>> config/tools/rtems-gcc-4.5.3-newlib-2.0.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.5.3-newlib-2.1.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.6.3-newlib-1.20.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.7.2-newlib-1.20.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.7.2-newlib-2.0.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.7.3-newlib-2.0.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg:%define mpc_version    0.8.2
>>>> config/tools/rtems-gcc-4.8-newlib-cvs-1.cfg:%hash md5
>>>> mpc-%{mpc_version}.tar.gz    e98267ebd5648a39f881d66797122fb6
>>>> config/tools/rtems-gcc-4.8-newlib-git-1.cfg:%define mpc_version    0.8.2
>>>> config/tools/rtems-gcc-4.8-newlib-git-1.cfg:%hash md5
>>>> config/tools/rtems-gcc-4.8-ss-newlib-2.0.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.8.0-newlib-cvs-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.8.1-newlib-cvs-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.8.2-newlib-2.1.0-1.cfg:%hash md5
>>>> config/tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.8-newlib-2.2.0-1.cfg:%hash md5
>>>> config/tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.9-newlib-2.2.0-1.cfg:%hash md5
>>>> config/tools/rtems-gcc-4.9-newlib-git-1.cfg:%define mpc_version    0.8.2
>>>> config/tools/rtems-gcc-4.9-newlib-git-1.cfg:%hash md5
>>>> config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg:%define mpc_version    0.8.2
>>>> config/tools/rtems-gcc-4.9-newlib-cvs-1.cfg:%hash md5
>>>> config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg:%define mpc_version
>>>> 0.8.2
>>>> config/tools/rtems-gcc-4.9.0-newlib-2.1.0-1.cfg:%hash md5
>>>> config/tools/rtems-gcc-6-20151101-newlib-2.2.0.20151023-1.cfg:%define
>>>> mpc_version    0.8.1
>>>> config/tools/rtems-gcc-6-20160117-newlib-2.3.0.20160104-1.cfg:%define
>>>> mpc_version    0.8.1
>>>> config/tools/rtems-gcc-6-20160117-newlib-2.3.0.20160104-1.cfg:%hash
>>>> sha512 mpc-0.8.1.tar.gz
>>>> 14cb9ae3d33caed24d5ae648eed28b2e00ad047a8baeff25981129af88245b4def2948573d7a00d65c5bd34e53524aa6a7351b76703c9f888b41830c1a1daae2
>>>> config/tools/rtems-gcc-6-20160124-newlib-2.3.0.20160104-1.cfg:%define
>>>> mpc_version    0.8.1
>>>> config/tools/rtems-gcc-6-20160124-newlib-2.3.0.20160104-1.cfg:%hash
>>>> config/tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1.cfg:%define
>>>> mpc_version    0.8.1
>>>> config/tools/rtems-gcc-6-20160228-newlib-2.3.0.20160226-1.cfg:%hash
>>>> config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg:%define
>>>> mpc_version    0.8.1
>>>> config/tools/rtems-gcc-6-20160327-newlib-2.4.0-1.cfg:%hash sha512
>>>> mpc-0.8.1.tar.gz
>>>> config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg:%define
>>>> mpc_version    0.8.1
>>>> config/tools/rtems-gcc-6-20160526-newlib-2.4.0.20160527-1.cfg:%hash
>>>> config/tools/rtems-gcc-6-20160609-newlib-2.4.0.20160527-1.cfg:%define
>>>> mpc_version    0.8.1
>>>> config/tools/rtems-gcc-6-20160609-newlib-2.4.0.20160527-1.cfg:%hash
>>>> config/tools/rtems-gcc-6.0.1-RC-20160415-newlib-2.4.0-1.cfg:%define
>>>> mpc_version    0.8.1
>>>> config/tools/rtems-gcc-6.0.1-RC-20160415-newlib-2.4.0-1.cfg:%hash
>>>> On Mon, Dec 10, 2018 at 8:28 AM Shashvat Jain <
>>>>> sorry , wrong question
>>>>> I found the link to download the tar file
>>>>> where should i place it ?
>>>>> On Mon, Dec 10, 2018 at 8:21 AM Shashvat Jain <
>>>>>> Have a safe flight!
>>>>>> How do i change the link after i find new one ?
>>>>>> and
>>>>>> it is a Resolve wiki page task
>>>>>> I think you can take care of it on the phone itself :)
>>>>>> Thanks for the update !!
>>>>>> On Mon, Dec 10, 2018 at 6:48 PM Joel Sherrill <joel at rtems.org> wrote:
>>>>>>> I'm in an airport waiting for the next flight. I will try to review
>>>>>>> before the deadline of claiming another task. But it depends on when I get
>>>>>>> access with my computer again.
>>>>>>> On Mon, Dec 10, 2018, 8:16 AM Shashvat Jain <
>>>>>>> shashvatjain2002 at gmail.com wrote:
>>>>>>>> i will check that out
>>>>>>>> sir  ,
>>>>>>>> will you be able to review my task? , it is a resolve one again :)
>>>>>>>> On Mon, Dec 10, 2018 at 6:36 PM Joel Sherrill <joel at rtems.org>
>>>>>>>> wrote:
>>>>>>>>> Go to the MPC site and look for the download link. They moved
>>>>>>>>> them. It should be a simple change.
>>>>>>>>> On Mon, Dec 10, 2018, 7:55 AM Shashvat Jain <
>>>>>>>>>> Hello ,
>>>>>>>>>> I was trying to build m68k with rtems-source-builder at branch
>>>>>>>>>> 4.9
>>>>>>>>>> but i face an error different than the one described in the
>>>>>>>>>> ticket #2581
>>>>>>>>>> One of the dowload links are unavailable , i have attached the
>>>>>>>>>> log of the report
>>>>>>>>>> in the attachments..the internet connection is working , this
>>>>>>>>>> happens again and again.
>>>>>>>>>> Please look into the issue
>>>>>>>>>> Thank you
>>>>>>>>>> Regards
>>>>>>>>>> --Shashvat
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181218/00cb2a8f/attachment-0002.html>
