[PATCH] user: Fix typos in the User Manual.
Mon Feb 5 03:37:00 UTC 2018
Close #3004
 user/installation/releases.rst | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/user/installation/releases.rst b/user/installation/releases.rst
index 92fce78..0d5150c 100644
--- a/user/installation/releases.rst
+++ b/user/installation/releases.rst
@@ -53,8 +53,8 @@ shosted here. It has excellent internet access and performance.
    By default all the BSPs for an architecture are built. If you only wish to
    have a specific BSP built you can specify the BSP list by providing to the
-   RSB the option ``--with-rtemsbsp``. For example to build two BSPs for the
-   SPARC architecture you can supply ``--with-rtemsbsp="erc32 sis"``. This can
+   RSB the option ``--enable-rtemsbsp``. For example to build two BSPs for the
+   SPARC architecture you can supply ``--enable-rtemsbsp="erc32 sis"``. This can
    speed the build time up for some architectures that have a lot of BSPs.
 Once you have built the tools and kernel you can move to the Packages section
@@ -112,7 +112,7 @@ you have unpacked the tar file:
  $ tar Jxf rtems-source-builder-4.11.0.tar.xz
  $ mv rtems-source-builder-4.11.0 4.110
- $ cd 4.11.0
+ $ cd 4.11.0/rtems
 Build a tool chain for the SPARC architecure. We are using the SPARC
 architecture in our example because GDB has a good simulator that lets us run
2.14.1
