How to download the required tar file?
Danxue Huang danxue.huang at gmail.com
Fri May 11 18:43:30 UTC 2018
Yes! I am trying to run hello world at Ubuntu in a VM.
On Fri, May 11, 2018 at 1:37 PM, Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On Fri, 11 May 2018, 23:59 Danxue Huang, <danxue.huang at gmail.com> wrote:
>> Hey Vijay,
>> Thank you so much for answering my question! Please don't feel sorry
>> about that, it's great that I also got you to help me so I can figure out
>> my problem faster :D
>> I double checked the files in my machine, there are no such files like
>> "kernel", "erc32" and "testsuites", do you know why do I miss these files?
>> Or how can I get these files? Thank you!
> maybe I didn't understand the current status of set up.
> are you trying to run hello world ?
>> Best,
>> Dannie
>> On Fri, May 11, 2018 at 12:57 PM, Vijay Kumar Banerjee <
>>> Hello Dannie,
>>> I guess you're looking for the testsuites direcotry under the build
>>> directory.
>>> It can be found somewhere like this
>>> $HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites
>>> If you're looking for the c code then you can find it under the
>>> RTEMS_ROOT directory.
>>> In my set up the root directory is here:
>>> $HOME/development/rtems/kernel/rtems/testsuites
>>> You can refer to this link to understand the directory structure
>>> properly .
>>> https://docs.rtems.org/branches/master/develenv/directory.html
>>> Hopefully it was helpful.
>>> regards,
>>> Vijay
>>> PS: Apologies to Chris, if it was disrespectful to respond to a question
>>> that was addressed to him. I certainly didn't mean any disrespect.
>>> On 11 May 2018 at 22:33, Danxue Huang <danxue.huang at gmail.com> wrote:
>>>> Chris,
>>>> I have managed to build the tools, but I got another question about
>>>> testing. I am supposed to have a "testsuites" folder in my machine from the
>>>> instruction but I did not find it. So I make a "test.exe" file by myself,
>>>> the output of running "test.exe" is as below.
>>>> dannie at dannie-VirtualBox:~/development/rtems/4.11/sparc-rtems4.11$
>>>> sparc-rtems4.11-gdb test.exe
>>>> GNU gdb (GDB) 7.9
>>>> Copyright (C) 2015 Free Software Foundation, Inc.
>>>> License GPLv3+: GNU GPL version 3 or later <
>>>> http://gnu.org/licenses/gpl.html>
>>>> This is free software: you are free to change and redistribute it.
>>>> There is NO WARRANTY, to the extent permitted by law.  Type "show
>>>> copying"
>>>> and "show warranty" for details.
>>>> This GDB was configured as "--host=x86_64-linux-gnu
>>>> --target=sparc-rtems4.11".
>>>> Type "show configuration" for configuration details.
>>>> For bug reporting instructions, please see:
>>>> <http://www.gnu.org/software/gdb/bugs/>.
>>>> Find the GDB manual and other documentation resources online at:
>>>> <http://www.gnu.org/software/gdb/documentation/>.
>>>> For help, type "help".
>>>> Type "apropos word" to search for commands related to "word"...
>>>> "/home/dannie/development/rtems/4.11/sparc-rtems4.11/test.exe": not in
>>>> executable format: File format not recognized
>>>> (gdb) tar sim
>>>> Connected to the simulator.
>>>> (gdb) load
>>>> No executable file specified.
>>>> Use the "file" or "exec-file" command.
>>>> (gdb) r
>>>> Starting program:
>>>> warning: No executable file specified.
>>>> warning: No program loaded.
>>>> [Inferior 1 (process 42000) exited normally]
>>>> (gdb) quit
>>>> Now I think the gdb session is working, but the "test.exe" is not
>>>> executable since it is coded by myself (there are bugs in it). Is there any
>>>> way I can get the testing files?
>>>> Thank you so much!
>>>> -Dannie
>>>> On Fri, May 11, 2018 at 12:07 AM, Chris Johns <chrisj at rtems.org> wrote:
>>>>> On 11/5/18 4:01 pm, Danxue Huang wrote:
>>>>> > Hi there,
>>>>> > I got stuck on 2.5 installing a tar file ( I have attached the
>>>>> website below).
>>>>> You can skip that section. It does not really belong in the Quick
>>>>> Start chapter.
>>>>> > https://docs.rtems.org/branches/master/rsb/quick-start.html#building
>>>>> > <https://docs.rtems.org/branches/master/rsb/quick-
>>>>> start.html#building>
>>>>> > The tar file is supposed that I have downloaded in my machine, but
>>>>> there is not
>>>>> > a required .bz2 file "rtems-4.11-sparc-rtems4.11-1.tar.bz2", all my
>>>>> files ends
>>>>> > at .bz2 are as below.
>>>>> > ./development/rtems/src/rtems-source-builder/rtems/sources/
>>>>> gmp-5.0.5.tar.bz2
>>>>> binutils-2.26.tar.bz2
>>>>> rtems-tools-25863503edb513e7501481ff2074c02bf219f519.tar.bz2
>>>>> binutils-2.30.tar.bz2
>>>>> gmp-6.1.0.tar.bz2
>>>>> gcc-4.9.3.tar.bz2
>>>>> mpfr-3.0.1.tar.bz2
>>>>> mpfr-3.1.4.tar.bz2
>>>>> > Is there any other way I can download the required tar file? Thank
>>>>> you!
>>>>> You should not needed it.
>>>>> Have you managed to build the tools?
>>>>> Chris
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180511/48254901/attachment-0002.html>
