[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri May 18 13:55:17 UTC 2018
On 18 May 2018 at 19:09, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On Fri, 18 May 2018, 12:36 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 18 May 2018 at 12:30, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> Cool, you should run it for the full testsuite and take a look at that
>>> report (takes a while.. around 575 tests)
>>>>> When I try to run the full testsuites it gives the following error .
>> What could be causing this ?
> If you run the full testsuite without the coverage options, does it still
> happen?
No it seems to run fine without coverage.
>> self.__bootstrap_inner()
>>   File "/usr/lib64/python2.7/threading.py", line 817, in
>> __bootstrap_inner
>>     (self.name, _format_exc()))
>> IOError: [Errno 11] Resource temporarily unavailable
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180518/3bda39ef/attachment-0002.html>
