[PATCH] m32c: Remove this build set
Fri Nov 9 07:42:50 UTC 2018
Update #3599.
 rtems/config/5/rtems-all.bset    |  1 -
 rtems/config/5/rtems-m32c.bset   | 46 ----------------------------------------
 rtems/config/5/rtems-tier-3.bset |  1 -
 3 files changed, 48 deletions(-)
 delete mode 100644 rtems/config/5/rtems-m32c.bset
diff --git a/rtems/config/5/rtems-all.bset b/rtems/config/5/rtems-all.bset
index 446d90a..00ccfae 100644
--- a/rtems/config/5/rtems-all.bset
+++ b/rtems/config/5/rtems-all.bset
@@ -4,7 +4,6 @@
 5/rtems-epiphany
 5/rtems-i386
 5/rtems-lm32
-5/rtems-m32c
 5/rtems-m68k
 5/rtems-microblaze
 5/rtems-mips
diff --git a/rtems/config/5/rtems-m32c.bset b/rtems/config/5/rtems-m32c.bset
deleted file mode 100644
index e7ee926..0000000
--- a/rtems/config/5/rtems-m32c.bset
+++ /dev/null
@@ -1,46 +0,0 @@
-# Tools Set for RTEMS M32C 5 Stable
-%define release 1
-%define rtems_arch m32c
-# The RTEMS base defines.
-%include rtems-base.bset
-# Disable building a C++ compiler.
-%define enable_cxx 0
-# Disable building ICONV support
-%define with_iconv 0
-# Set the build flags to work around the defaults in the
-# compiler that cause ICE.
-%define _targetcflags -g -O0
-%define _targetcxxflags -g -O0
-# If Windows (MinGW) do not build the simulator.
-%define win32-gdb-disable-sim
-# Tools configuration.
-5/rtems-autotools
-devel/expat-2.1.0-1
-tools/rtems-binutils-2.31.1
-tools/rtems-gcc-4.8.3-newlib-2ab57ad59bc35dafffa69cd4da5e228971de069f
-tools/rtems-gdb-8.0.1-1
-tools/rtems-tools-5-1
diff --git a/rtems/config/5/rtems-tier-3.bset b/rtems/config/5/rtems-tier-3.bset
index 0a66121..0fb7622 100644
--- a/rtems/config/5/rtems-tier-3.bset
+++ b/rtems/config/5/rtems-tier-3.bset
@@ -5,7 +5,6 @@
 5/rtems-bfin
 5/rtems-i386
 5/rtems-lm32
-5/rtems-m32c
 5/rtems-m68k
 5/rtems-mips
 5/rtems-moxie
2.16.4
