[rtems-tools commit] python: Provide support to select a valid python version.
Mon Nov 12 11:10:56 UTC 2018
On 12/11/2018 12:07, Sebastian Huber wrote:
> Result: timeout    Time: 0:03:00.250565 ada_ticker.exe
> =>  run: /build/rtems/5/bin/sparc-rtems5-run
> /build/git-build/b-erc32/sparc-rtems5/c/erc32/testsuites/ada/samples/ticker/ada_ticker.exe
> =>  test start: ADA TICKER
> ] *** BEGIN OF TEST ADA TICKER ***
> ] *** TEST VERSION: 5.0.0.9b55081eb6c686e3b5fde13e6c84e021639317d3
> ] *** TEST STATE: EXPECTED-PASS
> ] *** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
> ] *** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB
> 30da0c720b78eba16a3f5272206c07415368617b, Newlib
> 2ab57ad59bc35dafffa69cd4da5e228971de069f)
> ] TA1 - clock_get -  9: 0: 0   12/31/1988
> ] TA2 - clock_get -  9: 0: 0   12/31/1988
> ] TA3 - clock_get -  9: 0: 0   12/31/1988
> ] TA1 - clock_get -  9: 0: 5   12/31/1988
> ] *** TIMEOUT TIMEOUT
> [  5/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
> sparc/erc32: ada_sp01.exe
> Result: timeout    Time: 0:03:00.233552 ada_sp01.exe
> /build/git-build/b-erc32/sparc-rtems5/c/erc32/testsuites/ada/sptests/sp01/ada_sp01.exe
If I run the command directly:
time /build/rtems/5/bin/sparc-rtems5-run
TA2 - clock_get -  9: 0:10   12/31/1988
TA1 - clock_get -  9: 0:10   12/31/1988
TA1 - clock_get -  9: 0:15   12/31/1988
TA3 - clock_get -  9: 0:15   12/31/1988
TA2 - clock_get -  9: 0:20   12/31/1988
TA1 - clock_get -  9: 0:20   12/31/1988
TA1 - clock_get -  9: 0:25   12/31/1988
TA2 - clock_get -  9: 0:30   12/31/1988
TA1 - clock_get -  9: 0:30   12/31/1988
TA3 - clock_get -  9: 0:30   12/31/1988
*** END OF TEST ADA TICKER ***
*** FATAL ***
fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
fatal code: 0 (0x00000000)
RTEMS version: 5.0.0.9b55081eb6c686e3b5fde13e6c84e021639317d3
RTEMS tools: 7.3.0 20180125 (RTEMS 5, RSB
executing thread ID: 0x08a010002
executing thread name: TA1
real    0m0.658s
user    0m0.586s
sys     0m0.073s
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
