[PATCH] Coverage : Use '.o' files for coverage analysis
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Oct 16 03:36:39 UTC 2018
mistakenly resent this. Sorry about it.
I have made a separate patch for covoar,
I intended to send that one. :)
On Tue, Oct 16, 2018, 9:03 AM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> Use the Object files in cpukit/ instead of the static library
> for Coverage analysis
>  tester/rt/coverage.py                         | 27 ++++--
>  tester/rtems/testing/coverage/symbol-sets.ini | 90 +++++++++----------
>  2 files changed, 66 insertions(+), 51 deletions(-)
> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> index c979332..55cb59a 100644
> --- a/tester/rt/coverage.py
> +++ b/tester/rt/coverage.py
> @@ -244,13 +244,17 @@ class symbol_parser(object):
>                   symbol_config_path,
>                   symbol_select_path,
>                   symbol_set,
> -                 build_dir):
> +                 build_dir,
> +                 bsp_name,
> +                 target):
>          self.symbol_select_file = symbol_select_path
>          self.symbol_file = symbol_config_path
>          self.build_dir = build_dir
>          self.symbol_sets = {}
>          self.symbol_set = symbol_set
>          self.ssets = []
> +        self.bsp_name = bsp_name
> +        self.target = target
>      def parse(self):
>          config = configparser.ConfigParser()
> @@ -264,9 +268,13 @@ class symbol_parser(object):
>              for sset in self.ssets:
>                  lib = path.join(self.build_dir, config.get('libraries',
> sset))
>                  self.symbol_sets[sset] = lib.encode('utf-8')
> +                ss = self.symbol_sets[sset]
> +                ss = ss.replace('@BSP@', self.bsp_name)
> +                ss = ss.replace('@BUILD-TARGET@', self.target)
> +                self.symbol_sets[sset] = ss
>              return self.ssets
>          except:
> -            raise error.general('Symbol set parsing failed')
> +            raise error.general('Symbol set parsing failed for %s' % sset)
>      def write_ini(self, symbol_set):
> @@ -275,11 +283,15 @@ class symbol_parser(object):
>              config.add_section('symbol-sets')
>              config.set('symbol-sets', 'sets', sset)
>              config.add_section(sset)
> -            config.set(sset, 'libraries', self.symbol_sets[sset])
> +            object_files = [o for o in os.listdir(self.symbol_sets[sset])
> if o[-1] == 'o']
> +            object_paths = []
> +            for o in object_files:
> +                object_paths.append(path.join(self.symbol_sets[sset], o))
> +            config.set(sset, 'libraries', ','.join(object_paths))
>              with open(self.symbol_select_file, 'w') as conf:
> -                config.write(conf)
> +                    config.write(conf)
>          except:
> -            raise error.general('symbol parser write failed')
> +            raise error.general('symbol parser write failed for %s' %
> sset)
>  class covoar(object):
> @@ -357,6 +369,7 @@ class coverage_run(object):
>          self.report_format = self.macros['cov_report_format']
>          self.target = self.macros['target']
> +        self.bsp_name = self.macros['bsp'].split('-')[0]
>      def run(self):
>          try:
> @@ -366,7 +379,9 @@ class coverage_run(object):
>              parser = symbol_parser(self.symbol_config_path,
>                                     self.symbol_select_path,
>                                     self.symbol_set,
> -                                   build_dir)
> +                                   build_dir,
> +                                   self.bsp_name,
> +                                   self.target)
>              symbol_sets = parser.parse()
>              for sset in symbol_sets:
>                  parser.write_ini(sset)
> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
> b/tester/rtems/testing/coverage/symbol-sets.ini
> index 2685ef4..8f85533 100644
> --- a/tester/rtems/testing/coverage/symbol-sets.ini
> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
> @@ -29,50 +29,50 @@
>  [symbol-sets]
> -sets =
> score,rtems,sapi,libdl,posix,libirfs,libdosfs,libdevfs,libimfs,libcsupport,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
> +sets =
> score,rtems,sapi,libdl,posix,librfs,libdosfs,libdevfs,libimfs,libbspcmdline,libcpuuse,libstackchk,libfsmount,libstringto,libdevnull,libdumpbuf,libblock
>  [libraries]
> -score         = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
> -rtems         = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
> -sapi          = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/libsapi.a
> -libdl         = @BUILD-TARGET@/c/@BSP@/cpukit/libdl/libdl.a
> -posix         = @BUILD-TARGET@/c/@BSP@/cpukit/posix/libposix.a
> -libirfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/librfs.a
> -libdosfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdosfs.a
> -libdevfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libdevfs.a
> -libimfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libimfs.a
> -#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs/libdefaultfs.a
> -#libjffs2      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/libjffs2.a
> -#dtc           = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt/libfdt.a
> -#libdrvmgr     = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr/libdrvmgr.a
> -#libi2c        = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c/libi2c.a
> -libcsupport   = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/libcsupport.a
> -libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libbspcmdline.a
> -libcpuuse     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcpuuse.a
> -libstackchk   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstackchk.a
> -libfsmount    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libfsmount.a
> -libstringto   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libstringto.a
> -libdevnull    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdevnull.a
> -libdumpbuf    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdumpbuf.a
> -#libcapture    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libcapture.a
> -#libdummy      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libdummy.a
> -#libmonitor    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmonitor.a
> -#libmouse      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmouse.a
> -#libmw-fb      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libmw-fb.a
> -#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libredirector.a
> -#librtemsfdt   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/librtemsfdt.a
> -#libserdbg     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libserdbg.a
> -#libshell      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libshell.a
> -#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libtestsupport.a
> -#libuntar      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuntar.a
> -#libutf8proc   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libutf8proc.a
> -#libuuid       = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libuuid.a
> -#libxz         = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/libxz.a
> -libblock      = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/libblock.a
> -#libpci        = @BUILD-TARGET@/c/@BSP@/cpukit/libpci/libpci.a
> -#librpc        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/librpc.a
> -#libxdr        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc/libxdr.a
> -#libcrypt      = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt/libcrypt.a
> -#libmd         = @BUILD-TARGET@/c/@BSP@/cpukit/libmd/libmd.a
> -#libstdthreads = @BUILD-TARGET@/c/@BSP@
> /cpukit/libstdthreads/libstdthreads.a
> -#zlib          = @BUILD-TARGET@/c/@BSP@/cpukit/zlib/libz.a
> +score         = @BUILD-TARGET@/c/@BSP@/cpukit/score/src
> +rtems         = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/src
> +sapi          = @BUILD-TARGET@/c/@BSP@/cpukit/sapi/src
> +libdl         = @BUILD-TARGET@/c/@BSP@/cpukit/libdl
> +posix         = @BUILD-TARGET@/c/@BSP@/cpukit/posix/src
> +librfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/rfs
> +libdosfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/dosfs
> +libdevfs      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/devfs
> +libimfs       = @BUILD-TARGET@/c/@BSP@/cpukit/libfs/src/imfs
> +#libdefaultsfs = @BUiLD-TARGET@/c/@BSP@/cpukit/libfs
> +#libjffs2      = @BUILD-TARGET@/c/@BSP@/cpukit/libfs
> +#dtc           = @BUILD-TARGET@/c/@BSP@/cpukit/libfdt
> +#libdrvmgr     = @BUILD-TARGET@/c/@BSP@/cpukit/libdrvmgr
> +#libi2c        = @BUILD-TARGET@/c/@BSP@/cpukit/libi2c
> +#libcsupport   = @BUILD-TARGET@/c/@BSP@/cpukit/libcsupport/src
> +libbspcmdline = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/bspcmdline
> +libcpuuse     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/cpuuse
> +libstackchk   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stackchk
> +libfsmount    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/fsmount
> +libstringto   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/stringto
> +libdevnull    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/devnull
> +libdumpbuf    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc/dumpbuf
> +#libcapture    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libdummy      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libmonitor    = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libmouse      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libmw-fb      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libredirector = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#librtemsfdt   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libserdbg     = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libshell      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libtestsupport= @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libuntar      = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libutf8proc   = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libuuid       = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +#libxz         = @BUILD-TARGET@/c/@BSP@/cpukit/libmisc
> +libblock      = @BUILD-TARGET@/c/@BSP@/cpukit/libblock/src
> +#libpci        = @BUILD-TARGET@/c/@BSP@/cpukit/libpci
> +#librpc        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
> +#libxdr        = @BUILD-TARGET@/c/@BSP@/cpukit/librpc
> +#libcrypt      = @BUILD-TARGET@/c/@BSP@/cpukit/libcrypt
> +#libmd         = @BUILD-TARGET@/c/@BSP@/cpukit/libmd
> +#libstdthreads = @BUILD-TARGET@/c/@BSP@/cpukit/libstdthreads
> +#zlib          = @BUILD-TARGET@/c/@BSP@/cpukit/zlib
> 2.17.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181016/7020bad5/attachment-0002.html>
