compile error in RTEMS header when using -std=c99?
Cudmore, Alan P. (GSFC-5820) alan.p.cudmore at nasa.gov
Wed Sep 12 18:45:39 UTC 2018
Hello,
We are building our RTEMS applications with -std=c99 and other compiler warning switches.
On the latest RTEMS master and RTEMS 5 toolchain ( from yesterday ), when I include the -std=c99 compiler switch, the compilation fails in an RTEMS header.
Is it not recommended to use the “-std= “ switches when building RTEMS applications, or is this something that we should fix? We are able to use the “-std=c99” switches in 4.11. I noticed that the timestamp.h file did change between 4.11 and 5.x.
Details of the error are below.
Thanks,
Alan
It is reproducible with the “hello_world_c” example as follows:
Command from unmodified examples-v2 Makefile:
sparc-rtems5-gcc --pipe -B/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/ -specs bsp_specs -qrtems   -Wall  -O2 -g -ffunction-sections -fdata-sections    -mcpu=leon3       -c   -o o-optimize/test.o test.c
Command with -std=c99 added:
sparc-rtems5-gcc --pipe -B/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/ -specs bsp_specs -qrtems  -std=c99 -Wall  -O2 -g -ffunction-sections -fdata-sections    -mcpu=leon3       -c   -o o-optimize/test.o test.c
In file included from /home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/thread.h:36:0,
                 from /home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/heap.h:22,
                 from /home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/rtems/types.h:26,
                 from /home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems.h:31,
                 from test.c:5:
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h: In function '_Timestamp_Divide':
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h:219:12: error: incompatible types when assigning to type 'struct timespec' from type 'int'
   _ts_left = sbttots( *_lhs );
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h:220:13: error: incompatible types when assigning to type 'struct timespec' from type 'int'
   _ts_right = sbttots( *_rhs );
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h: In function '_Timestamp_Get_nanoseconds':
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h:261:7: error: incompatible types when assigning to type 'struct timespec' from type 'int'
   _ts = sbttots( *_time );
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h: In function '_Timestamp_Get_as_nanoseconds':
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h:281:7: error: incompatible types when assigning to type 'struct timespec' from type 'int'
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h: In function '_Timestamp_To_timespec':
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h:299:14: error: incompatible types when assigning to type 'struct timespec' from type 'int'
   *_timespec = sbttots( *_timestamp );
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h: In function '_Timestamp_To_timeval':
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timestamp.h:313:13: error: incompatible types when assigning to type 'struct timeval' from type 'int'
   *_timeval = sbttotv( *_timestamp );
In file included from /home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timecounter.h:27:0,
                 from /home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/score/timecounterimpl.h:26,
                 from /home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/rtems/clock.h:37,
                 from /home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems.h:40,
                 from test.c:5:
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/sys/timetc.h: At top level:
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/sys/timetc.h:72:2: error: unknown type name 'u_int'
  u_int   tc_flags;
In file included from /home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/confdefs.h:326:0,
                 from test.c:32:
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/imfs.h: In function '_IMFS_get_time':
/home/alan/rtems/bsps/5/sparc-rtems5/leon3/lib/include/rtems/imfs.h:343:18: error: storage size of 'now' isn't known
   struct bintime now;
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180912/99635f0a/attachment-0001.html>
